Автор Тема: Alfa Romeo vs Everything Else!  (Прочитано 1937550 пати)
Одг: Alfa Romeo vs Everything Else!
« Одговори #2235 на: 04 Август 2012, 13:23:56 pm »
Сите ST-a се со истиве перформанси, а не се твин спарк... :P
  • Пораки: 45371
« Одговори #2236 на: 04 Август 2012, 13:50:19 pm »
Ама се со турбо :P
« Одговори #2237 на: 04 Август 2012, 14:58:41 pm »
Honda колку титули освои ?
  • Пораки: 7310
« Одговори #2238 на: 06 Август 2012, 10:02:03 am »
@Jovanovmk, дека аутоск не се баш „најефтиниот“ сервис на свет, сите знаеме :D Мене за ова (брава за врата) Ми бараа 12.000 денари :)
Не е само водна пумпа причина за хорор прикаските што ги читаш и слушаш. На TS моторие барем се покажала доста добро, повеќе скинати ремени се поради заглавени затегачи.
Еве уште еден сајт (од алфа сервис) што вика за каиши:
Timing belts!   Very important! Timing belts require changing at the following intervals!
Timing belt replacement especialy on alfas is a minefield with garages cutting corners and previous owners cutting costs if you have just bought an Alfa and dont have it in writing when the timing belt was last changed you would be well advised to get it changed ASAP. we have also had cars in that have had a cambelt change but the car has been running poorly due to the job not having been done correctly.
147,156,Gtv,Gt 1.6/1.8/2.0Ts &Jts  Require changing at 36,000mls or 3 years.
147,156,Gt 1.9/2.4Jtd Require changing at 48,000mls or 3 years.
Brera, 159 1.9/2.4Jtd Require changing at 60,000mls or  4years.
159: 1750 tbi Require changing at 72,000mls or 3 years
Mito 1.6Jtdm Require changing at 63,000mls or 4 years.
Mito 1.4 & 1.4TB Require changing at 72,000mls or 4 years.
Please note the above intervals are our advised intervals not Alfa Romeos official intervals, In our opinion due to numerous early timing belt failures we have seen Alfas official intervals remain to high.
We insist on replacing the water pump while replacing the timing belts as follows, TS engines every 72,000 i,e every second cambelt change, V6 with every cambelt change and JTD engines with every cambelt change and Mito waterpumps at every belt change.
The only other thing to be aware of while carrying out Timing belt replacements on Twin spark and Jts engines is a noisey variator, this can start to happen at any time during the cars lifetime, when it is starting to get worn it will start to rattle on start up  it will make a (Diesel) type noise then go as the oil pressure rises, as the variator wears more it will start to be noisy all the time, as replacement of the variator requires removal and replacement of the timing belts to change it, if your car is showing signs of variator wear then it would be silly not to change it at the same time as the Timing belt replacement, To replace a variator while changing the timing belt is just the cost of the part currently £110 no extra labour is charged.
Мислам дека за ЈТД моторите си е 5 години, водната пумпа била проблем со фабрички вградената на 16 в мотори, така да откако ќе се смени еднаш може да се менува на секои 2 сервиси.
http://www.alfaworkshop.co.uk/alfa_147_156_GT_service_schedule.shtml
Да не шириме непотребно FUD, пукање на каиш не секогаш е заради нередовно одржување, секогаш постои статистичка грешка ;)
Еве ви еден добар одговор околку мистеријата и рекла-казала за каиште кај ТС и ЈТД како и 8 и 16 в мотори.
http://www.alfaowner.com/Forum/engines-ts-jts-jtd-and-v6/133792-147-jtd-cambelt-change-when.html#post2078347
Отсутен cuoresportivo159
  • Пораки: 4194
-J.Clarkson
  • Пораки: 15399
« Одговори #2240 на: 07 Август 2012, 15:16:08 pm »
  • Пораки: 4194
« Одговори #2241 на: 07 Август 2012, 15:17:50 pm »
Alfista be, so rakavici :D
-J.Clarkson
  • Пораки: 45371
« Одговори #2242 на: 07 Август 2012, 15:29:48 pm »
Ти да ќутиш :P
  • Пораки: 15399
« Одговори #2243 на: 07 Август 2012, 15:37:38 pm »
:D
Отсутен Sportex
  • Пораки: 7879
  • Иштван Беќар Пецарош
    • camouflage.mk
« Одговори #2244 на: 07 Август 2012, 15:44:42 pm »
;D
Отсутен ngocevski
  • Пораки: 484
« Одговори #2245 на: 07 Август 2012, 15:50:17 pm »
Алфисти, што би рекле за 1985 Спајдер 2000 Велоче 2.0 (хард топ)
  • Пораки: 4194
« Одговори #2246 на: 07 Август 2012, 15:53:51 pm »
Legendaren avtomobil u prava smisla na zborot. Cena?
-J.Clarkson
  • Пораки: 45371
« Одговори #2247 на: 07 Август 2012, 15:57:35 pm »
Легендарно ауто, само да е во добра состојба...
  • Пораки: 15399
« Одговори #2248 на: 07 Август 2012, 15:58:46 pm »
Јас само едно знам вакво во Скопје, црна боја секогаш беше паркирано кај Соборна :)
Отсутен ngocevski
  • Пораки: 484
« Одговори #2249 на: 07 Август 2012, 15:59:41 pm »
3500, супер состојба НО има знаци на рѓа треба да се санира
