Автор Тема: Автомобилски Новитети  (Прочитано 3272153 пати)
  • Пораки: 15326
Одг: Автомобилски Новитети
« Одговори #9780 на: 07 Јули 2015, 14:05:45 pm »
Како и да е, убави модели ваѓаат Рено во последниве години. Свака част.
Е сеа изборот на мотор, секој со своето.
  • Пораки: 7847
« Одговори #9781 на: 07 Јули 2015, 14:43:52 pm »
Полека експерти, кога го возевте вие овај мотор па знајте колку имал од 0-100 и дали бил добар или не ?  ::)
New Energy dCi 160 Twin Turbo engine: the feel of a 2-litre engine, plus a 25% fuel-consumption saving
This 1,598cc block delivers 160hp and a generous 380Nm of torque, which catapults it into the domain of 2-litre engines in terms of performance
The first is a very low inertia turbo which provides high low-end torque for crisp pull-away and mid-range acceleration. To guarantee sprightly pick-up response at low revs and incisive acceleration, 90% of peak torque is available from 1,500rpm.
The second turbo assumes the reins at the higher-end and produces high power (100hp per litre) at faster engine speeds to ensure smooth, linear, dependable acceleration right the way up to maximum revs.
- A hi-tech unit boasting technology borne out of Renault’s F1 expertise
This expertise in the field of sophisticated turbochargers is not the only link between the 1.6-litre Renault Energy F1 Power Unit and the Energy dCi 160 Twin Turbo block which takes advantage of a number of technologies borne out of Renault’s know how in F1, notably in terms of cooling and friction reduction:
The transverse water flow system permits faster and more efficient cooling of the combustion chamber.
‘U’-section U-Flex piston rings adapt to changes in the form of the cylinder walls resulting from fluctuations in temperature and pressure to yield the optimum compromise between efficiency and friction.
Super-finishing also reduces friction.
The fuel injection system of the Energy dCi 160 Twin Turbo operates at a pressure of 1,800 bar to function with the twin turbocharger. It complies with Euro 6b emissions legislation and incorporates a NOx Trap and particulate filter regeneration system.
By dint of its efficiency, this engine is comfortably capable of powering larger vehicles, and will notably be available for Renault’s forthcoming top of the range models.
Како и да е ќе се покажи на тестот дали е добар или не.
  • Пораки: 45236
« Одговори #9782 на: 07 Јули 2015, 14:49:08 pm »
ААх сега ја решивме со издржливоста и перформанасите ;D
Присутен Luki Junior
  • Пораки: 5265
  • The Spartan General
« Одговори #9783 на: 07 Јули 2015, 15:19:02 pm »
Во Формула 1 од 1.5 машини вадеа по 1500 коњи, па сега за едно рено со 160 коњи е проблем.  ;D
Отсутен mmm121
  • Пораки: 3799
« Одговори #9784 на: 07 Јули 2015, 15:23:18 pm »
Ама 1500 коњи употребливи 1саат.
  • Пораки: 30839
« Одговори #9785 на: 07 Јули 2015, 15:52:58 pm »
Па толку се и тие 160 во обичните коли.
;D
Отсутен mmm121
  • Пораки: 3799
« Одговори #9786 на: 07 Јули 2015, 15:55:48 pm »
Викаш ке испушти душа ако го запнеш душмански 1-2 саати?
  • Пораки: 7847
« Одговори #9787 на: 07 Јули 2015, 16:38:03 pm »
А вистина заборајв јас, Алфа и Vw се пред нив во Ф1 :/
  • Пораки: 45236
« Одговори #9788 на: 07 Јули 2015, 16:42:21 pm »
Барем не се чаламат по новини со глупости од типот „1.6 дизелов исти ни` е ко` од F1" :D
  • Пораки: 7847
« Одговори #9789 на: 07 Јули 2015, 16:52:18 pm »
Па како да се чаламат кога само по сервиси ги има, во тој спорт се најдобри ;)
  • Пораки: 30839
« Одговори #9790 на: 07 Јули 2015, 19:02:53 pm »
http://www.carclub.mk/2015/07/07/maliot-108-gradskiot-voin-na-peugeot-pretstaven-vo-skopje/
Изгледа најмалку 27 пати подобро од Ајго.
  • Пораки: 7208
« Одговори #9791 на: 07 Јули 2015, 19:08:06 pm »
vo danska go gledam veke aktivno se vozi i interesno izgleda. tuka danokot na vozila e 150% pa skoro 80 procenti od vozilata se ovaa klasa
  • Пораки: 18204
« Одговори #9792 на: 07 Јули 2015, 20:32:00 pm »
Боље по сервиси ама 100% технички исправни отколку непосетување на сервис од инает. После се тепале луѓево по патишта...
« Одговори #9793 на: 07 Јули 2015, 22:59:32 pm »
Кога го ѕирнав во живо, колку смешно изгледа од позади со штоповите поголеми од гумите. Тоа бар можеле поубаво да го смислат. Вака од напред не е лошо.
  • Пораки: 7208
« Одговори #9794 на: 07 Јули 2015, 23:26:40 pm »
слични штопови има и последниот смарт, мислам дека зеро го нема претставено сеуште
