Автор Тема: Здравје, медицински установи, опрема и стручност на персоналот  (Прочитано 2011084 пати)
  • Пораки: 22393
https://www.reuters.com/article/us-health-coronavirus-cuba/cuban-doctors-head-to-italy-battle-coronavirus-idUSKBN219051
Communist-run Cuba said it dispatched a brigade of doctors and nurses to Italy for the first time this weekend to help in the fight against the novel coronavirus at the request of the worst-affected region Lombardy.  Its doctors were in the front lines in the fight against cholera in Haiti and against ebola in West Africa in the 2010s.
Yet with the 52-strong brigade, this is the first time Cuba has sent an emergency contingent to Italy, one of the world’s richest countries, demonstrating the reach of its medical diplomacy.
https://m.off.net.mk/vesti/svet/kako-putin-go-iskoristi-penalot-namesten-od-eu
Куба, па Русија.
  • Пораки: 55347
Куба, па Русија.
http://www.fpp.co.uk/Hitler/docs/Mannerheim/recording_040642_dt.html
Hitler: Absolutely, This is - they had the most immense armaments that, uh, people could imagine. Well - if somebody had told me that a country - with...(Hitler is interrupted by the sound of a door opening and closing.) If somebody had told me a nation could start with 35,000 tanks, then I'd have said: "You are crazy!"
Mannerheim: Thirty-five?
Hitler: Thirty-five thousand tanks.
Another Voice In Background: Thirty-five thousand! Yes!
Hitler: We have destroyed - right now - more than 34,000 tanks. If someone had told me this, I'd have said: "You!" If you are one of my generals had stated that any nation has 35,000 tanks I'd have said: "You, my good sir, you see everything twice or ten times. You are crazy; you see ghosts." This I would have deemed possible. I told you earlier we found factories, one of them at Kramatorskaja, for example, Two years ago there were just a couple hundred [tanks]. We didn't know anything. Today, there is a tank plant, where - during the first shift a little more than 30,000, and 'round the clock a little more than 60,000, workers would have labored - a single tank plant! A gigantic factory!
Отсутен darkomic
  • Пораки: 382
Колку си сигурен дека се познати само 2 подтипови на вирусов. Дали знаеш дека вирусите мутираат. Инаку ако не мутираја досега на пример грипот, кој е истотака вирус, ќе беше искоренет. Си прочитал некои написи кои не ги разбираш затоа што не си ни биолог ни медицинско лице.  И сега ти се јавуваш како фактор и сам носиш заклучоци кои ги наведуваш подолу. Дали си свесен дека со својот дилетантизам можеш да предизвикаш голема штета?
Познати се два главни подтипови од вирусот и не е познато точно дали прележување на едниот подтип дава имунитет за другиот. Дури има и случај каде во ист пациент се најдени двата подтипови. Не се знае ни дали истовремено заразување од двата подтипови влијае на шансите за оправување. Многу работи тек треба да се изучат.
https://academic.oup.com/nsr/advance-article/doi/10.1093/nsr/nwaa036/5775463
http://www.youtube.com/watch?v=FYPZHA-UjUY
Интересна колумна:
https://www.theatlantic.com/ideas/archive/2020/03/china-trolling-world-and-avoiding-blame/608332/
Мислам дека нема да знаеме што е што додека не видиме cui bono... Тоа би се видело на крајот, ако и тогаш - а далеку сме од крајот.
Инаку нормално дека во западен медиум ќе напишат онаква содржина, веројатно во Кина имаат целосно спротивна перспектива. Вистината којзнае што е.
Но како што велат, на затекнатите во пожар не им менува многу кој ја запалил шумата (или дали гром удрил).
Отсутен Van
  • Пораки: 5405
  • VW Golf MK3 1.9 TDI
Колку си сигурен дека се познати само 2 подтипови на вирусов. Дали знаеш дека вирусите мутираат...
Aко повнимателно прочиташ ќе видиш дека напишав „два главни подтипови“. ОК?
Познати се два главни подтипови од вирусот...
Ок. Веројатно погрешно си разбрал што е напишано.
Инаку информацијата е точна до времето на истражувањата со кои се утврдила таа информација. Ако знаеш нешто ново биди љубезен па сподели овде.
Вирусот се разбира дека има безброј СЛИЧНИ форми, но сите тие се делат во еден од двата ГЛАВНИ подтипови, типот L и типот S.
Ако сакаш да одиш подетално, повели овде ги ажурираат сите достапни анализирани и секвенцирани примероци:
https://nextstrain.org/ncov?d=tree&p=full&r=country
Подредени се според држава.
Што?  :D
Што зборуваш бе другар?
Не те разбирам, каков фактор, какви заклучоци... Јас само пренесов информации од научни истражувања.
Каква тоа „штета“ предизвикувам?
И што е со антагонизмот?  ???
  • Пораки: 22393
Ван, под итно да се произнесеш на темава..
http://forum.carclub.mk/index.php/topic,730.14235.html
  • Пораки: 20400
https://telma.com.mk/zabrana-za-dvizhene-od-16-do-05-chasot-za-vreme-na-vikendite/
Забрана за движење од 16 до 05 часот за време на викендите
Се претерува.
  • Пораки: 7846
Ако, ако, подобро така за побрзо да се врати нормалниот живот, да му се дај време на луѓето да си ја сработат работата и да измислат третман за срањето наречено корона.
Отсутен Van
  • Пораки: 5405
Немам никакви замерки таму.  ;)
  • Пораки: 22393
Излагањето на профата го преведоа на југословенски јазик..
Убави коментари за читање.
Бикоз...
Зошто екс-југословенските земји подобро се справуваат со пандемијата од Западот.
Еден современ словенечки  филозоф многу пластично ја опиша состојбата на економијата и пандемијата. – Кина го жртвуваше бизнисот да ги заштити луѓето, ЕУ и САД  штедат  капитал на сметка на луѓето. Затоа Кина ја сопре пандемијата која во ЕУ и САД продолжува драматично да се шири.
Професорот П.Дамјан  изјави дека многу брзо ќе дојде денот кога шефовите на државите ќе мора да изберат помеѓу спас на економијата и бројот на жртвите. Британскиот новинар Џереми Ворнер дури напиша дека коронавирусот би можел да му помогне на човештвото бидејќи ќе му помогне да се реши од постарата популација.
Томас Малтус, класичар на капиталистичката политика за население, пресмета дека населението пребрзо се размножува со зголемувањето на производството на храна. Зошто? Бидејќи луѓето имаат многу храна  на располагање, ако јадат премногу, тие се репродуцираат премногу. Решенија: Војни, повремено создавање војна, присилување на сексуална апстиненција - и, се разбира, појава на  болести кои ги погодуваат болните и непродуктивните.
Професорот Богомир Ковач (Младина, 20 март 2020 година;) е на линија со Дамјан и Малтус : „Не можеме да се бориме против пандемија со запирање на економските текови во името на заштитата на луѓето, затоа што на крајот состојбата ќе биде многу полоша.“
Многу интересна е состојбата со екс-југословенските земји кои многу полесно се справуваат со пандемијата од водечките земји на ЕУ.
Триесет години капиталистички „економски текови“ во фармацевтската индустрија, во продажба на опрема, во приватизацијата, го зашеметија екс-југословенското јавно здравство. Но за среќа тоа не го уништи: бидејќи јавното здравство е единствено способно да се бори со вакви закани како корона-вирусот. Тито и Југославија изградија силно и квалитетно јавно здравство кои и покрај бројните обиди за уништување со приватизацијата уште е здраво наспроти замјите од ЕУ.
Доказ е  Италија, во ова време држава со апсолутно најголем број на загинати: во 1975 година во Италија имало 10,6 болнички кревети на илјада жители во Италија, сега 2,6; Помеѓу 2009 и 2017 година, таму беа укинати 46.500 работни места во здравството. Тие им дадоа приоритет на „економските текови“ - сега тие ги губат луѓето, а полека запираат и економските текови.
Ова е само потврда дека цената на либералниот капитализам во оваа пандемија што земјите ќе ја платат ќе биде голема и во жртви и во капитал.
Катастрофална е логиката еден спортист како Роналдо или Меси да заработуваат десетици милиони евра месечно наспроти еден врвен доктор специјалист чија плата е под 10 илјади евра на месец. Да не говориме на скромните речиси минимални средства што се одвојуваат за научни установи каде научниците од кои сега очекуваме да најдат вакцина или лек за коронавирусот се минимално платени за што еден италијански научник рече : „Сега Роналдо нека им помогне на болните кога еден научник зема плата од 1300 евра“.
Светот е исправен пред голема дилема во времето на пандемијата. Јасно е дека нема ништо да биде исто понатаму но колку државниците ќе имаат сила да превземат нови мерки за реконструкција на капитализмот кој во слободна функција се заканува сам да ни ја исече гранката на која седиме со фатални последици за човештвото. Еколозите ќе речат , планетата земја сама се прочистува благодарение на пандемијата. Можеби тоа го заслуживме но ако извлечеме заклучоци Природата и Луѓето може заеднички да победат за посветла иднина.
https://sitel.com.mk/zoshto-eks-jugoslovenskite-zemji-podobro-se-spravuvaat-so-pandemijata-od-zapadot
  • Пораки: 45229
Се мислам дали да искоменитрам со „Супер.“, или со „Ај, ај, ај...“ :) Бирај.
  • Пораки: 22393
Ни едното ни другото.
"Хеј словени" на рипит само.
  • Пораки: 45229
БОЉЕ НЍ БЕШЕ ВО КОМУНИЗМОТ!
  • Пораки: 22393
БОЉЕ НЍ БЕШЕ ВО КОМУНИЗМОТ социјализмот
  • Пораки: 11178
Ете пак добри вести, читам дека во родната ти Италија денес нема нови случаи.
Бројот на жртви моментално е 10.082. Далеку од мал и греота за луѓето.
А ја и ти се читаме темава пак бааарем кога оваа бројќа ќе достигне 44.000, односно кога коронава ќе одземе исто толку животи на светско ниво, колку обичен сезонски грип на ЕУ ниво.
Дотогаш, помалку паника и повеќе оптимизам не е на одмет.
Ciao.
(Фотографијата е скриена. Кликни тука за да ја прикажеш..) (Фотографијата е скриена. Кликни тука за да ја прикажеш..)
и уште безмалку 6 часа од денот
само 6 дена требаше за да дуплираат бројот на заболени и починати
Отсутен Molec
  • Пораки: 4786
  • (Oo\(|||)°(|||)/oO)
