Автор Тема: Дешаванки со кола ( тумбања, судари, несреќни моменти, одвратни искуства... )  (Прочитано 4317812 пати)
  • Пораки: 20898
Мешаш ESP со TCS :)
Колку што знам, TCS можеш да го исклучиш, ESP не можеш.
Отсутен RikiRulz
  • Пораки: 10640
  • *** UNDERCOVER ***
Да, тоа е тоа... :)))
Моја грешка :)
Се извинувам :)
Отсутен Tommy
  • Пораки: 7911
Мешаш ESP со TCS :)
hmm, ме подзамисли и ке разгуглам после, дека кај мене баш има ESP OFF копче, како на сликата...
Рачна не може да кренеш во кривина со вклучен ESP...
  • Пораки: 20898
Еве тука убаво објаснување... (TCS = DTC; ESP = DSC)
Dynamic Traction Control (DTC) allows more wheel slip and thus a more dynamic driving style with higher wheel traction and DSC controlling stability. A small amount of spin on the drive wheels improves traction when pulling off from a standstill in snow or on loose terrain.
Dynamic Traction Control (DTC) is a sub-function of the Dynamic Stability Control (DSC) system that can be turned on and off. DTC has two major roles: to regulate traction and to enable sports-style driving while providing active stability control.
When the drive wheels start losing traction the DSC automatically begins stabilisation measures. The Dynamic Stability Control system curbs the engine output and stops slip on the wheels. In exceptional situations, however, a small amount of wheel slip can be an advantage.
When driving in deep snow, slush or on loose terrain a small amount of wheel spin improves traction. For these occasions, as well as those when the drivers want a sportier driving style, the DTC can be activated by pressing a button and this allows more slip and reduces the DSC’s curbing of the engine. The result: better traction and more thrust.
The DTC also makes driving on snow and ice-free roads more dynamic. When activated, the DTC allows sporty drivers more room to manoeuvre around curves than the Dynamic Stability Control and even permits controlled drifts. The driver retains complete control over the vehicle in every situation and the Dynamic Stability Control’s stabilising measures remain active even when the DTC is activated.
DTC
DSC
Отсутен Drive-r
  • Пораки: 7477
  • FB Vlecna Suzba Niko-m
Tommy
За рачната не сум знаел.
Отсутен Tommy
  • Пораки: 7911
Tommy
Лошо се изразив, технички можеш, ама колата ке си тера по свој терк... Не е препорачливо воопшто...
Отсутен ARMEX
  • Пораки: 3616
Пак пресечи ми пат
Отсутен Prof. Greenthumb
  • Пораки: 4115
  • MadaFunker
Типов мислам го имаше на Мотика, над 100 сообраќајки има намерно ги удира ако му пресечат пат..
Има и интервју  :D http://motika.com.mk/index.php?option=com_content&view=article&id=38409:2013-02-25-12-03-16&catid=1&Itemid=13
New blood of old school
Отсутен RikiRulz
  • Пораки: 10640
Мешаш ESP со TCS :)
Добро тогаш на кочење кај мене... пример, еве во кривина... што се активира, и светка на шал табла жолто едно како траги од шлајфување...
Отсутен ARMEX
  • Пораки: 3616
ESP веројатно.
  • Пораки: 20898
  • Пораки: 18210
На раскрсницата кај Соборна пак некој бил далтонист и мислел дека црвеното е зелено.
Застава Скала и Ленд Ровер Фрилендер1, како и очекувано Заставата распадната.
  • Пораки: 15265
  • Пораки: 7282
