Автор Тема: VW vs OPEL  (Прочитано 73918 пати)
Отсутен bobi 903
  • Пораки: 135
Одг: VW vs OPEL
« Одговори #60 на: 20 Октомври 2011, 22:55:22 pm »
еве некоја сликичка од новата астра
Отсутен Rakun4e
  • Пораки: 9200
  • Аstra la vista baby !
Одг: VW vs OPEL
« Одговори #61 на: 21 Октомври 2011, 02:18:02 am »
Оваа е тјунирана од EDS
Перверзно добро нешто  ;)
One of the most powerful tuning packages for the Opel Astra hatchback comes from EDS Fahrzeugtechnik. Based on the Astra J Turbo, the car produces 360 bhp instead of the standard 180!
360 hp and a maximum torque of 480 Nm is a huge power for such a little car. It is also generally known as a recipe for chaos! To make sure it remains in check if not all, but most of the times they’ve equipped it with perforated brake discs in dimension of 356 x 32 mm with 8-piston calipers, and Schmidt Revolution 20-inch rims with Pirelli P.Zero 235/35ZR20 the front and 275/30ZR20 on the rear axle. These rims also look quite awesome.
But those are mere details really because that engine sits in  the middle like a giant anchovy on a mini pizza! The modifications are so deep and include Pressure reducing high-performance needle valve – 980 Euro, high-quality steel connecting rod – 550 Euro, HG Motorsport turbo manifold – 1200 Euro, EDS high-performance charge air cooler – 600 Euro, Garret GT28 turbocharger – 1000 Euro, 100 mm air-flow meter – 300 Euro, 550 cm3 injectors – 500 Euro, 70 mm down pipe with HJS 200CPSI Sport catalyst – 800 Euro, Friedrich Motorsport 70 mm stainless steel exhaust system – 800 Euro, 240 mm EDS Sport clutch kit – 1100 Euro and Quaife differential lock – 900 Euro plus engine adjustment by EDS Fahrzeugtechnik for 1000 Euros.
http://www.motorward.com/2011/02/eds-opel-astra-j-turbo/
Отсутен bobi 903
  • Пораки: 135
Одг: VW vs OPEL
« Одговори #62 на: 21 Октомври 2011, 18:16:14 pm »
фала за дополнувањето  ;D
Отсутен RikiRulz
  • Пораки: 10640
  • *** UNDERCOVER ***
Одг: VW vs OPEL
« Одговори #63 на: 22 Октомври 2011, 17:24:25 pm »
Новава астра, малце како да наличува на Леонот ?
Одг: VW vs OPEL
« Одговори #64 на: 22 Октомври 2011, 19:37:02 pm »
Новите сите наликуваат едни на други :)
  • Пораки: 20911
Одг: VW vs OPEL
« Одговори #65 на: 22 Октомври 2011, 19:44:06 pm »
Де бе Рики, ја откри Америка, шо се велиТ на нашки ;D
Поголема вистина од оваа, не се кажала долго време. Апсолутно се согласувам. Малтене само нијанси се во прашање, иако понекогаш токму тие нијанси, што би се рекло, живот значат.
  • Пораки: 9637
Одг: VW vs OPEL
« Одговори #66 на: 22 Октомври 2011, 19:51:36 pm »
тоа ти е нешто како кога ке речат има убави црти ама лошо/добро распоредени  :D :D :D
Отсутен RikiRulz
  • Пораки: 10640
Одг: VW vs OPEL
« Одговори #67 на: 22 Октомври 2011, 23:32:13 pm »
Веле, мене ептен ми личи целиот кроф од хауба напред... до позади браникот мислиш е скинат од Леон и наместен на Астра :)
Одг: VW vs OPEL
« Одговори #68 на: 23 Октомври 2011, 19:09:06 pm »
 Бизнис филозофија. Кој ќе понуди повеќе за помалце пари ќе биде најпродаван. Не ни ризикуваат повеќе со нови дизајни. Фаќаат сите еден правец и кому иде.
  • Пораки: 30926
Одг: VW vs OPEL
« Одговори #69 на: 23 Октомври 2011, 19:16:54 pm »
Па не е само тоа.. Многу повеќе удел имаат регулативите за безбедност, итн. Налагаат многу работи - рецимо на која висина треба/смее да биде хаубата, под кој агол треба/смее да биде хаубата во однос на предницата, итн итн.. Сето тоа има ефект.
  • Пораки: 34579
Отсутен Tommy
  • Пораки: 7954
Одг: VW vs OPEL
« Одговори #71 на: 27 Октомври 2011, 15:49:50 pm »
The performance upgrades give the hot hatch an estimated sprint from 0 to 62 mph in just 6.2 seconds, 0.6 seconds quicker than the GTI.
GTI DSG е 6.2 секунди ....
Корсава би требало да го јаде GTI-то со оглед на килажата што ја има, а имаат исто време 0-100 ...
За почит е со што со 1.4 извадиле толку коњи ...
Чисто колку за споредба, Астра ОПЦ Нирбургринг едиција е со 411 КС ...
Одг: VW vs OPEL
« Одговори #72 на: 27 Октомври 2011, 15:59:02 pm »
COrsata e postartna od GTI za 0.6 sekundi. Isto e startna so Golf GTI DSG, no ne treba so nego da se sporeduva, zatoa sto Corsata ima manuelen menuvac.
1.4 motorot e na Polo GTI 177ks, Corsata e 1.6
Отсутен Tommy
  • Пораки: 7954
Одг: VW vs OPEL
« Одговори #73 на: 27 Октомври 2011, 16:03:57 pm »
Се извинувам, не дочитав дека е POLO, се префрлив на Golf ...
Иначе, чудно ми е, пак ке споменам ...
Astra OPC Nirbugring беше со 411 КС .... Очекував Корсава да е барем 300 кс ...
Одг: VW vs OPEL
« Одговори #74 на: 27 Октомври 2011, 16:17:02 pm »
Greska da ne si?
