Автор Тема: Opel и неговите модели  (Прочитано 984823 пати)
  • Пораки: 45266
Одг: opel и неговите модели
« Одговори #270 на: 15 Мај 2012, 10:20:10 am »
Може некое следно корсиче ГСИ? :)
  • Пораки: 34562
« Одговори #271 на: 15 Мај 2012, 10:21:33 am »
Сакам ваков мотор во Алегра
  • Пораки: 22425
« Одговори #273 на: 15 Мај 2012, 11:38:50 am »
 ^ Maximum torque is up to 300 N·m (221 lb-ft) and is already available at 1,700 rpm.
Peak power of up to 200 hp (149 kW) is reached at 4,700 rpm.
Compared to the predecessor 1.6-liter turbocharged gasoline engine, fuel consumption and CO2 have been cut by 13%.
Opel.
Wir leben das drehmoment.
Отсутен Rakun4e
  • Пораки: 9200
  • Аstra la vista baby !
« Одговори #274 на: 15 Мај 2012, 16:36:13 pm »
Here are further details:
The first new engine to be introduced is a turbocharged 1598 cc, four-cylinder gasoline unit with direct injection and Start/Stop. The emphasis was on torque with the engineers achieving up to 187.5 Nm per liter of displacement – a benchmark for gasoline engines produced in high volume.
- Maximum torque is up to 300 Nm and is already available at 1,700 rpm.
- Peak power of up to 200 hp is reached at 4,700 rpm.
- Compared to the predecessor 1.6 liter turbocharged gasoline engine, fuel consumption and CO2 have been cut by 13 percent.
The new Astra OPC will be powered by the latest version of this engine offering an output of 206kW/280 hp.
More details will follow soon :)
И малку убавини за очи  :-*
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #276 на: 17 Мај 2012, 20:36:09 pm »
The most powerful four-cylinder gasoline engine on the European market in terms of highest specific torque comes from Opel. The turbocharged, direct-injection, 1998 cm3, all-aluminum unit in the new Astra OPC not only has a maximum power output of 280 hp; with 200 Nm per liter, it has higher specific torque than any of its rivals, more even than super sports cars.
  • Пораки: 11180
« Одговори #277 на: 18 Мај 2012, 11:29:51 am »
Тууу 400Nm на предни тркала... А ќе треба и да врти..
  • Пораки: 30862
« Одговори #278 на: 18 Мај 2012, 11:31:43 am »
Опел објави дека следната генерација на Astra ќе се прави во Elsemere Port. Тоа не се добри вести за фабриката во Бохум.
  • Пораки: 55354
« Одговори #279 на: 18 Мај 2012, 16:43:30 pm »
Дур не објави дека има погон на задни...
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #280 на: 18 Мај 2012, 20:25:32 pm »
Ова веќе 6 месеци врти на предни тркала:
http://forum.carclub.mk/index.php/topic,2368.30.html
и сеуште не е со погон на задни... :D
  • Пораки: 11180
« Одговори #281 на: 18 Мај 2012, 21:23:23 pm »
Да ама, подолго е, потешко е, поголемо меѓуоскино...
Ми мириса на подуправливост :)
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #282 на: 18 Мај 2012, 22:16:57 pm »
Тежината лесно ќе ја решиме.Ќе ги качиш овие двајца и ќе добиеш на стабилност... ;D
  • Пораки: 11180
« Одговори #283 на: 18 Мај 2012, 22:38:16 pm »
;D ;D
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #284 на: 23 Мај 2012, 09:45:30 am »
