Автор Тема: Аудиo опрема  (Прочитано 423252 пати)
Одг: Аудиo опрема
« Одговори #1470 на: 09 Март 2024, 20:40:21 pm »
“When playing an audio CD, a motor within the CD player spins the disc to a scanning velocity of 1.2–1.4 m/s (constant linear velocity , CLV)—equivalent to approximately 500 RPM at the inside of the disc, and approximately 200 RPM at the outside edge.”
Никаква, ама никаква врска со брзина на режење, ниту квалитет на читање соодветен на брзина.
Отсутен nestor04
  • Пораки: 7079
Одг: Аудиo опрема
« Одговори #1471 на: 09 Март 2024, 23:44:19 pm »
Има, има.
Writing CDs (Compact Discs) at lower speeds is often associated with better quality for several reasons:
1. **Reduced Errors**: Writing data at lower speeds allows the laser to accurately create pits on the CD's surface, which represent the data. Higher speeds can introduce errors due to the laser being unable to precisely control the pit size and placement.
2. **Better Compatibility**: Lower speed burns tend to result in CDs that are more compatible with a wider range of CD players and drives. Some older or less advanced players may struggle to read CDs burned at high speeds, leading to skipping or playback issues.
3. **Less Jitter**: Jitter refers to variations in the timing of the data signal. Burning at lower speeds helps minimize jitter, leading to smoother and more consistent data retrieval.
4. **Improved Stability**: CDs burned at lower speeds often have a more stable structure, reducing the likelihood of physical imperfections such as bubbles or uneven layers that can affect readability.
Overall, while burning CDs at lower speeds may take longer, it typically results in a higher-quality end product with fewer playback issues.
Само не ми е до ЦД дојдено, некој ми го изгребал МЛ-от со клуч, отидов кај ТЕ-ЕН на полирање, вика дека е предлабоко и најде и на крилото гребнатини.
Отсутен vladic3110
  • Пораки: 6446
Одг: Аудиo опрема
« Одговори #1472 на: 09 Март 2024, 23:46:06 pm »
Чувам едно Creation 700mb уште во оргиналниот целофан седи неотпаковано од 2004та :D
Едно време колку шо имаше места на куќиштето толку режачи имав и уште толку вишак обични.
Отсутен Nandor The Relentless
  • Пораки: 9034
Одг: Аудиo опрема
« Одговори #1473 на: 10 Март 2024, 00:30:48 am »
Стари, не заебаај и ти сега...
Мислам во контекст на: драјвовите во автомобили.
За тоа се работеше, нели, дали ќе го чита тој драјв, а не било кој плеер...
  • Пораки: 9034
Одг: Аудиo опрема
« Одговори #1474 на: 10 Март 2024, 00:32:18 am »
Значи, три или четири... :D
И ти пират, а?
Не смеам да кажуем јавно, да не ме обеса на плоштад...
Кој ти знае, ќе излезе некој нов закон, ќе наебеме стварно.
Ќути си, режи си.
  • Пораки: 9034
Одг: Аудиo опрема
« Одговори #1475 на: 10 Март 2024, 00:34:55 am »
Не те бранам више.
Ме утепа со коментаров.
Идам Тома да пуштам...
Одг: Аудиo опрема
« Одговори #1476 на: 10 Март 2024, 08:08:59 am »
Ако не сум бил доволно јасен
брзината на режење нема никакво влијание на брзината на читање потоа.
Ниту па некаков квалитет на читање да варира соодветно на брзина на режење, односно квалитетот на читање (што и да значи тоа) е ист, ќе си прочита тоа што е нарежено.
Е сега брзината на режење, да, пожелно е да се намали троа од максималната можна, неколку пати ми се случило со (ДВД дискови)  да морам одново, па наместо да ќарам време, дупло да изгубам и да фрлам диск.
Оттогаш не сум се обидел со Макс брзина, всушност, веќе неколку години не сум имал потреба да речам, ништо чудно да идат у историја дисковите :)
Одг: Аудиo опрема
« Одговори #1477 на: 10 Март 2024, 13:07:32 pm »
Imat region na cd-ata.... ama pojma nema na kola kaj se mestit
« Последно менување: 10 Март 2024, 13:15:05 pm Bicikle »
Отсутен Ordevski
  • Пораки: 2115
Одг: Аудиo опрема
« Одговори #1478 на: 10 Март 2024, 17:24:25 pm »
Драги Перо, бавно ти пишувам оти знам дека ти бавно читаш...
Sent from my SM-S908E using Tapatalk
  • Пораки: 9034
Одг: Аудиo опрема
« Одговори #1479 на: 10 Март 2024, 17:27:46 pm »
100 поена!
Тачно причината зошто постарите автомобили не ги пуштаат таквите дискови.
Отсутен Jimny
  • Пораки: 3879
Одг: Аудиo опрема
« Одговори #1480 на: 10 Март 2024, 20:00:50 pm »
Каде можам да најдам вакво нешто за да можам звучници да конектирам на тв
https://www.youtube.com/watch?v=U9I8GiML2CM
  • Пораки: 55355
Одг: Аудиo опрема
« Одговори #1481 на: 10 Март 2024, 20:04:22 pm »
Мислам дека сепак нема да ти работи Volume. Затоа мора да се пази телевизорот да има 3.5мм џек, за да можеш да врзеш појачало кога сакаш (и да работи Volume)
Отсутен Jimny
  • Пораки: 3879
Одг: Аудиo опрема
« Одговори #1482 на: 10 Март 2024, 20:14:22 pm »
малите звучници се вклучени десно каде што се зголемува и намалува тонот главниот кабел коа ке го вклучам си работи нормално се вклучува плаво останува тоа зелено каде што неможе да се уштека у телевизорот како да се реши овој проблем ? и да се конектира на тв дали знае некој ? претходно ова беше конектирано на куќиште од компјутер
Отсутен Ordevski
  • Пораки: 2115
Одг: Аудиo опрема
« Одговори #1483 на: 10 Март 2024, 21:01:39 pm »
Ова од сликите е твое или бараш такво да купиш? Каков ТВ имаш, односно какви аудио излези има?
Ова е некое ефтино, го има на Алиекспрес, имам јас такво слично дополнително со Bluetooth. Не би го препорачал, прилично лош звук и многу е тивко, на пример ако на појачалото слушам нормално наместено на 20 од Макс 60, тогаш преку ова треба да ми биде на 40-45 за да го добијам истиот звук.
Колку си спремен да потрошиш, имам и добра препорака, да го најдам линкот ќе споделам.
Едит: Just found this amazing item on AliExpress. Check it out!
MKD6,697.95 | SMSL C100 USB MQA DAC AK4493S XMOS XU316 DSD512 32Bit 768KHZ CK-03 Clock Optical coaxial Bluetooth Decoder With remote control
https://a.aliexpress.com/_EuU3ach
Ова веќе е друга ѕверка :)
« Последно менување: 10 Март 2024, 21:07:08 pm Ordevski »
Отсутен Jimny
  • Пораки: 3879
Одг: Аудиo опрема
« Одговори #1484 на: 10 Март 2024, 21:10:00 pm »
Барам такво да купам од видеово е шо го споделив,имам самсунг тв
