Оваа сезона е:
Најинтересна во последниве 10 години
8 (19.5%)
Најдосадна во последниве 10 години
19 (46.3%)
Исто е интересна како и другите сезони
14 (34.1%)
Вкупно гласови: 41
Автор Тема: Formula 1 - Season 2014  (Прочитано 360252 пати)
Отсутен Vasil
  • Пораки: 3759
Одг: Formula 1 - Season 2014
« Одговори #1065 на: 26 Јуни 2014, 20:31:22 pm »
Којзнае колку се компјутерски неписмени, тие што ги склопуваат правилава.
« Одговори #1066 на: 26 Јуни 2014, 20:45:53 pm »
Се сомневам. Дури и ако извршните пенкала се неписмени, сигурно консултираат прилично писмени.
Присутен Skywalker
  • Пораки: 4454
« Одговори #1067 на: 26 Јуни 2014, 22:54:36 pm »
Ова е од правилникот на ФИА.
2.6 The calculation used for the declaration of the 8 week Aerodynamic Testing Period shall be carried out as below.
TotFLOPS = (MFPPC * CCF * NCU * NSS ) / (604,800 * 8 * 1000)
Where :
TotFLOPS = The total number of TeraFLOPs used per CFD solve run.
MFPPC = Peak double precision floating point operations per cycle per core of the Processing Unit (excluding AVX if declared under 2.5(d) or using natural precision operations under 2.5(e) if the core is not double precision capable).
CCF = Peak Processing Unit clock frequency in GigaHertz achieved during the CFD solver run. This will be the peak frequency theoretically achievable during the run based on one of the following :
a) The standard clock frequency value from the Processing Unit Manufacturer's specification sheet (if overclocking or enhanced modes are not used in the run).
b) The maximum “turbo”, “HPC” or other enhanced mode frequency value.
c) The maximum overclocked frequency value.
NCU = Number of Processing Unit cores used for the run.
NSS = Number of solver wall clock seconds elapsed during the run. NB Message passing time during calculation should be included.
All information required for auditing should be present in the output from the run including the CCF value.
For the avoidance of doubt, any offload processing for example FPU, FPGA, GPU/GPGPU, VFP, softfp etc. should be included and calculated using the same method as above.
  • Пораки: 55354
« Одговори #1068 на: 28 Јуни 2014, 19:28:52 pm »
Што кој фалус е овој циркуз? Од глупо поглупо само прават. Псуј, псуј не се до псујува. Катастрофа, сега тактики ќе се прават со кршење на поспориот болид, за да може да ги стигне конкутентниот. Страва и ужаса. А ова со компјутериве и пресметковна моќ искрено не се ни потрудив да го разберам, ме мрзи. Сигурно ќе има некоја ревизија па тогаш ќе го студирам.
  • Пораки: 45266
« Одговори #1069 на: 28 Јуни 2014, 21:11:21 pm »
Отсутен Sase_91
  • Пораки: 4256
« Одговори #1070 на: 28 Јуни 2014, 21:20:25 pm »
Ништо чудно и да им забранат од 2016 во пит стопот да користат компјутери со ССД и над 8ГБ рам.
Отсутен cuoresportivo159
  • Пораки: 4194
« Одговори #1071 на: 28 Јуни 2014, 22:23:49 pm »
Буквално незнаат кај тераат.
-J.Clarkson
« Одговори #1072 на: 30 Јуни 2014, 10:14:01 am »
 Уште не им е касно да ја прекинат сезонава и колку толку летово да го направат поинтересно..
Присутен FiLo
  • Пораки: 7295
« Одговори #1073 на: 02 Јули 2014, 00:45:57 am »
Монца згаснува од Ф1 календарот!
Овој Берни незнае кај тера.
„Не верувам дека ќе постигнеме нов договор, бидејќи според актуелниот, гледано од комерцијален аспект е речиси неисплатливо да се натпреваруваме таму“, изјави сопственикот на комерцијалните права на Формула 1, Берни Еклстоун.
  • Пораки: 55354
« Одговори #1074 на: 02 Јули 2014, 09:16:24 am »
Пусто името да му остане.
  • Пораки: 55354
« Одговори #1075 на: 04 Јули 2014, 18:48:22 pm »
Отсутен Vasil
  • Пораки: 3759
« Одговори #1076 на: 04 Јули 2014, 21:47:27 pm »
  • Пораки: 7856
« Одговори #1077 на: 04 Јули 2014, 23:34:34 pm »
Lotus leaves Renault
Lotus will end its long relationship with Renault at the end of this season to be powered by Mercedes from next year.
The agreement has been concluded between the two parties and will be announced in the coming days.
With the departure of McLaren Honda at the end of this year, Mercedes was looking for a new customer team for 2015.
German turbo V6 is more efficient and less costly than the propellant designed by Renault, Lotus did not hesitate to jump at the chance to live in the hope of a better season in 2015.
The association between the Enstone based team and Renault started in 1995 with the title of world champion Michael Schumacher obtained.
http://www.f1i.com/infos/lotus-quitte-renault-mercedes/
Баш да видиме дали ќе му биди подобра 2015.
  • Пораки: 34562
« Одговори #1078 на: 05 Јули 2014, 01:06:58 am »
Секако дека ќе биде. Погледни како сите што возат мерцедес се пред другите.
  • Пораки: 7856
« Одговори #1079 на: 05 Јули 2014, 02:45:51 am »
Самите кажаја, нема да има голем напредок се до 2015, пошто е забранет развојот во текот на сезоната. Само Мерцедес АМГ се пред Ред Бул
