Choose your destiny!
Бензин
244 (58.8%)
Дизел
171 (41.2%)
Вкупно гласови: 415
Автор Тема: Diesel-ашишта vs Benzin-чиња  (Прочитано 2942414 пати)
« Одговори #840 на: 03 Мај 2012, 21:50:45 pm »
ova e se vo + za dizel.....
diesel is in principle easier to refine than gasoline, it needs to be cleaned from more pollutants to ensure that tailpipe emissions remain as low as possible. However, diesel contains more energy than petrol and the vehicle’s engine combustion process is more efficient, adding up to higher fuel efficiency and lower CO2 emissions when using diesel
a diesel engine is more efficient than a spark-ignited petrol engine having the same power output when the engines are installed in a vehicle having a similar mass.his results in the diesel having lower fuel consumption - a common margin is roughly 40% more km travelled for an efficient turbo-diesel engine
diesel fuel is denser than petrol and contains about 15% more energy by volume
efficiency of the diesel engine is still some 20% greater than the petrol engine, despite the diesel engine also being heavier
1kg of diesel burnt under ideal conditions will produce 2.68kg of CO2. 1kg of petrol burnt under ideal conditions will produce 2.3kg of CO2
Отсутен mmm121
  • Пораки: 3799
  • Пораки: 34579
« Одговори #842 на: 20 Мај 2012, 13:09:42 pm »
Од текстот што го прати ммм121 погоре:
„The diesel engine will run on anything which can lubricate and combust and we can already successfully create alternate fuels to power the current generation of diesels.“
Колку е ова само цинично напишано...
Отсутен mmm121
  • Пораки: 3799
« Одговори #843 на: 20 Мај 2012, 17:24:34 pm »
се што има доволно коњски сили може да биде fun. Зарем дизел со 200кс не е добро?
  • Пораки: 34579
« Одговори #844 на: 20 Мај 2012, 18:01:46 pm »
Ама има и Голф со 200кс а има и Хонда со 200кс VTEC. Што е позабавно? :)
  • Пораки: 55366
« Одговори #845 на: 20 Мај 2012, 18:09:37 pm »
Вози ги па кажи!!! :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :)
  • Пораки: 34579
« Одговори #846 на: 20 Мај 2012, 18:11:06 pm »
Сум ги возел и двете :) Не баш конкретно тие две ама ја имам доловено разликата :)
Отсутен Driver
  • Пораки: 371
« Одговори #847 на: 20 Мај 2012, 19:52:34 pm »
Добро е, али бензинец е подобро, повеќе би ти го направил кефот
Отсутен mmm121
  • Пораки: 3799
« Одговори #848 на: 20 Мај 2012, 20:15:41 pm »
Benzinec da ama so 30 40 ks poveke
Отсутен Driver
  • Пораки: 371
« Одговори #849 на: 20 Мај 2012, 20:19:53 pm »
Што има врска, исто ке одат, али бензинецот вади далеку подобар звук, прави повеке обратаи
« Одговори #850 на: 20 Мај 2012, 22:07:14 pm »
максимално исто ќе идат, но просечно дизелот поише ќе иде
  • Пораки: 55366
« Одговори #851 на: 20 Мај 2012, 23:08:53 pm »
За мерак сумаризација од филип.
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #852 на: 20 Мај 2012, 23:12:27 pm »
Сеуште споредувате турбо дизел со атмосферски бензинец?
« Одговори #853 на: 20 Мај 2012, 23:18:46 pm »
pa i so turbo benzinec ne e sporedliva ekonomijata so NM  ;D ;D ;D ;D ;)
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #854 на: 20 Мај 2012, 23:19:54 pm »
Економија, за тоа е дизел :)
