Автор Тема: Го видов овој „ѕвер“ од ауто на нашите улици..  (Прочитано 2567994 пати)
Отсутен DasAuto.
  • Пораки: 4595
  • ~ Full of soul ~
« Одговори #8475 на: 08 Јануари 2015, 00:04:33 am »
645i , страхотно воило :)
↯↯ Don't try to follow me ↯↯
Отсутен cuoresportivo159
  • Пораки: 4194
« Одговори #8476 на: 08 Јануари 2015, 00:14:07 am »
Незнам дали е 4.4 или 4.6. Разликата е осетлива,доста пожив,поеластичен,поексплозивен е вториот.
-J.Clarkson
  • Пораки: 20378
« Одговори #8477 на: 08 Јануари 2015, 00:43:44 am »
645Ci
The 645Ci was the earliest BMW E63/E64 model available. The engine is a 4.4 litre V8 producing 329HP and 330 lb-ft of torque. The engine code is N62B44. The 645Ci did not get a facelift, as the 645Ci was only present in the BMW lineup for only 2 years - 2004 and 2005, before being replaced by the bigger and quicker 650i in 2006. The 645Ci came in Coupe and Convertible models (like all BMW 6 Series's after 2004). 21,040 645Ci's were sold in its first year of production. Very early 645Ci models did not feature a Cupholder. In 2004 and 2005 645Ci's were the only available 6 Series model available (with the exception of the M6) in the US at the time.
Не пишува на вики ништо за 4.6л 645.
650i
The 650i replaced all 645Ci models in 2006. The engine was a 4.8L V8 producing 360HP and 360 lb-ft of torque, which is more than the 645Ci. The 650i came in Coupe and Convertible models (like all the other E63/E64's), and (like the 645Ci), was the only available 6 Series at the time of production (with the exception of the M6). The 650i did feature the Standard Facelift in September 2007 (like all models with the exception of the 645Ci), but still featured the same amount of power as before the facelift.
Заменето е со 650, кое има 4.8л мотор.
  • Пораки: 4194
« Одговори #8478 на: 08 Јануари 2015, 00:50:30 am »
Не зборував конкретно за 6-ка,у др каросерии сум ги искусил,затоа и пишав дека незнам кој го ставале.
-J.Clarkson
  • Пораки: 20378
« Одговори #8479 на: 08 Јануари 2015, 00:54:14 am »
Аха ок, мислев за 6ка само зборуваш.
  • Пораки: 6642
« Одговори #8480 на: 08 Јануари 2015, 00:54:36 am »
Трајко имаше X5ка со 4.6 мотор, неговата ли ја имаш пробано?
  • Пораки: 4194
« Одговори #8481 на: 08 Јануари 2015, 00:56:54 am »
Не ја знам таа,друга имам пробано.
-J.Clarkson
  • Пораки: 22304
« Одговори #8482 на: 22 Јануари 2015, 13:34:15 pm »
Отсутен DejzY
  • Пораки: 1004
« Одговори #8483 на: 22 Јануари 2015, 14:35:49 pm »
Не барам многу, само едно од овие да поседувам ;D
Е сега ако можам да бирам, ферари нека биди или мустанг, или корвета, абе  шо сака нека биди ;D
Отсутен nikolaben
  • Пораки: 881
« Одговори #8484 на: 22 Јануари 2015, 15:31:40 pm »
Kul, fotkite od macedonia tuning, pola od niv moi so trgnat potpis :P
Отсутен acekovac
  • Пораки: 199
« Одговори #8485 на: 22 Јануари 2015, 19:25:10 pm »
сигурно и на торент ги има за симнување  ;D
Отсутен darko mk5
  • Пораки: 3600
« Одговори #8486 на: 23 Јануари 2015, 14:14:10 pm »
што не ги тужиш? :)
Отсутен nikolaben
  • Пораки: 881
« Одговори #8487 на: 23 Јануари 2015, 17:50:57 pm »
Знам како ќе биде "Не е тоа до нас, преку facebook copyright infringement решете го проблемот" иначе уште утре ќе ги пријавев, доколку мислиш дека имам некоја шанса посоветувај ме во инбокс, радо би се тужел :)))
  • Пораки: 20894
« Одговори #8488 на: 23 Јануари 2015, 17:53:08 pm »
Па ако де, пријави ги и до администрацијата на Фејсбук.
Ако имаш доказ дека се твои и имаш некаде соодветна информација кој ти ги објавува фотографиите без твоја согласност, имаш секое право да тужиш и да добиеш, поради прекршување на авторски права и индустриска сопственост.
  • Пораки: 15993
« Одговори #8489 на: 23 Јануари 2015, 18:19:22 pm »
јас колку што знам, чим си гипостирал сиките јавно, тогаш има право да ги користи кој и како сака, само тоа треба да биде линкувано и НИКАКО да се симне водениот или каков и да е печат на сликата.. тоа е казнивото и за кое можеш да ги тужиш...
