Автор Тема: Вести од Автомобилскиот Свет  (Прочитано 502102 пати)
Одг: Вести од Автомобилскиот Свет
« Одговори #420 на: 21 Февруари 2013, 17:56:32 pm »
Пишав и порано за новиов дизел од хонда, ама еве некое потазе текстче што го начекав.
They love a good engine at Honda. F1 fans still get misty-eyed at the memory of Senna and Prost wiping the floor with everyone back in 1988, thanks in no small part to the RA168E Honda motor in the McLaren. Top Gear, meanwhile, spent much of the Nineties trying to make various high-revving Honda VTEC units explode, and failing.
So you can't help thinking that E
urope's diesel predilection must baffle Honda's boffins. Low revs, fat mid-range torque, high compression ratios... what lunacy is this? Actually, I once watched a Honda diesel being assembled in the Swindon factory - more exciting than it sounds - and had a crash course in thixotropic casting, which alters the molecular structure of aluminium so that it can be spread like butter. Clever.
This new 1.6-litre turbodiesel has an aluminium block, and a very compact 'charger, so the cleverness continues. Really, this is all about the numbers, so here are the headlines, or at least as many as Honda will confirm: average fuel consumption should be around 75mpg, and its emissions should dip just below the magic, road tax-exempt 100g/km threshold. Competitive stuff.
Here are a few others: 118bhp and 221lb ft of torque. Yes, in days gone by it would have been the other way round in any self-respecting Honda, but there we are. Besides, that torque figure beats all similarly sized rivals. The 1.6 diesel will slot in below the existing 2.2-litre when it arrives in the UK next autumn, and TG recently enjoyed a secret-squirrel preview at Honda's Motegi test track.
Well, I say enjoyed. Honda claims this new unit is the lightest diesel in the world (it weighs 170kg), but it's certainly not the most refined. Your operating window is a fairly slender 2,000-4,000rpm, so you'll be working the Civic's thankfully precise six-speed 'box if you want to make any progress. But it'll pull subterranean revs at motorway speeds quietly enough, which is probably a more pertinent test.
I rather like the rest of the new Civic. It looks good, it's nicely made, the cabin is the right side of barmy to engage the driver, and it rides a lot better than the old one thanks to fluid-filled bushes and tweaks to the rear torsion-beam suspension. Not a natural Honda, then, but a perfectly decent one.
Jason Barlow
The numbers
1600cc, 4cyl, FWD, 118bhp, 221lb ft, 75mpg, 99g/km CO2, 0-62 in 11.0secs, 120mph, 1300kg
Интересни бројчиња морам да признаам. Што би рекол еден професор "знаете дека што фатиле јапонците да прават, направиле".
« Одговори #421 на: 21 Февруари 2013, 20:58:56 pm »
This made me laugh!
Отсутен Bu$aV MeGaNe
  • Пораки: 1857
  • Renault Megane R26
« Одговори #422 на: 21 Февруари 2013, 23:38:49 pm »
Очигледно дека хонда најака страна и е бензинот и најдобро тоа да си остане така.Овие бројки на дизелов се далеку од интересни,дизелашите отидоа мноооогу понапред од ова.
На пример
1.6 Dci       Power Output   96kw/130hp@4000
                  Torque         320nm@1750
                   0-62 in 9.8 secs
  • Пораки: 15273
« Одговори #423 на: 21 Февруари 2013, 23:41:39 pm »
Се мислев шо е толку ‘направено‘ на дизел моторот од Хонда.Според бројките ништо револуционерно,но не го прочитав текстот па реков да не има нешто скриено во него,затоа не коментирав.
« Одговори #424 на: 22 Февруари 2013, 00:15:03 am »
Интересна ми беше потрошњата и леснотијата на моторот. Па може затоа бев понесен и го пишав тоа, иако читав друг текст (во овој што сум го ставил ги нема).
Не замеравајте. ;D
« Одговори #425 на: 02 Март 2013, 08:41:30 am »
Отсутен Sportex
  • Пораки: 7879
  • Иштван Беќар Пецарош
    • camouflage.mk
« Одговори #426 на: 02 Март 2013, 09:56:38 am »
Сакам !
Отсутен DENDE - ARTEONED
  • Пораки: 5839
« Одговори #427 на: 02 Март 2013, 15:11:32 pm »
HMMMM...interesno.
Отсутен Sportex
  • Пораки: 7879
    • camouflage.mk
« Одговори #428 на: 02 Март 2013, 15:40:47 pm »
Acord  e Acord, горе-долу познато што се нуди ама моторчево ме мами!   :)
« Одговори #429 на: 02 Март 2013, 19:31:25 pm »
Детален тест имате во број 21
http://autoiq.hr/arhiva/
Едино цената неможам да ја сварам..
« Последно менување: 02 Март 2013, 21:26:17 pm Cuore Sportivo »
Отсутен Sportex
  • Пораки: 7879
    • camouflage.mk
« Одговори #430 на: 04 Март 2013, 11:07:28 am »
Cu*rence, онли фор ју, број 6 страна 22 !!! ;D
http://issuu.com/autoiq/docs/autoiq_0062/27
« Одговори #431 на: 04 Март 2013, 11:12:34 am »
Предница је мало агресивна, може послужити за плашење мале деце, лош мењач, седишта не пружају довољно страничне потпоре, лелеее, абе одма би го фрлил око да не ми трепне ;D
  • Пораки: 30929
« Одговори #432 на: 04 Март 2013, 20:14:09 pm »
http://www.carclub.mk/2013/03/04/volkswagen-golf-e-evropski-avtomobil-na-godinata-za-2013/
Голф е Европски Автомобил на Годината за 2013.
Фала, фала, се потрудивме.
  • Пораки: 55367
« Одговори #433 на: 04 Март 2013, 20:16:10 pm »
Нормално.
Отсутен Ipkisija Meskosa
  • Пораки: 9267
« Одговори #434 на: 04 Март 2013, 20:19:52 pm »
Салам победа. Дупло поќе гласој од второпласираниот. Браос :)
