Автор Тема: Body Building, Fitness, P90X, MMA, Boxing i slicno...  (Прочитано 1025512 пати)
  • Пораки: 55357
« Одговори #465 на: 30 Март 2012, 20:47:23 pm »
  • Пораки: 7685
« Одговори #466 на: 30 Март 2012, 20:52:21 pm »
Некој од билдериве да ми каже некоја вежба за моноцебс?
Благодарам
« Одговори #467 на: 04 Април 2012, 21:57:04 pm »
  • Пораки: 6219
« Одговори #468 на: 04 Април 2012, 22:09:26 pm »
Битно е да има добар фат :))
Отсутен Nakolce
  • Пораки: 2310
  • Имигрант
« Одговори #469 на: 04 Април 2012, 22:09:45 pm »
Оваа му ја предлагаш за инструкторка ?
« Одговори #470 на: 05 Април 2012, 08:43:20 am »
LAS VEGAS — Alistair Overeem failed a drug test in Nevada, putting plans for a scheduled UFC heavyweight championship matchup in jeopardy, a regulator said Wednesday.
The Dutch kickboxing champion can take a second urine test, but will need Nevada Athletic Commission approval for a license to fight UFC heavyweight champion Junior Dos Santos as scheduled May 26, commission executive Keith Kizer said.
(Eric Jamison, File/Associated Press) - FILE - In this Dec. 30, 2011, file photo, Alistair Overeem, of the Netherlands celebrates his fvictory over Brock Lesnar after a UFC heavyweight mixed martial arts match in Las Vegas. Overeem failed a drug test in Nevada, putting plans for a scheduled heavyweight championship matchup in jeopardy.
Overeem tested unacceptably high for testosterone, Kizer said. His license expired after his last bout on Dec. 30.
Overeem has denied past allegations of steroid use. His representatives did not immediately respond Wednesday to a message left through Overeem’s Las Vegas lawyer, David Chesnoff.
Chesnoff represented Overeem in a March 27 plea deal that could erase a misdemeanor battery charge stemming from an allegation that Overeem shoved a woman early Jan. 2 at a Las Vegas Strip casino.
Overeem, 31, made no admission of guilt while agreeing to perform 50 hours of community service, complete an anger management course and stay out of trouble for 90 days, Chesnoff said. Overeem faces 90 days in the Clark County jail if he fails to comply.
The incident that led to his court summons occurred just days after the 6-foot-5, 263-pound Overeem knocked out heavyweight Brock Lesnar in the first round of UFC 141 in Las Vegas.
Copyright 2012 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.
http://www.washingtonpost.com/sports/ufc-heavyweight-overeem-fails-drug-test-needs-nevada-commission-approval-for-may-26-bout/2012/04/04/gIQAlLG1vS_story.html?tid=pm_sports_pop
  • Пораки: 22431
« Одговори #471 на: 05 Април 2012, 11:02:19 am »
TRT a?
Kaj ima kaj nas da se puknam edna doza da vidam kako e? ;D
Stvarno steta ako zaradi ova se otkaze borbata so JDS.
« Одговори #472 на: 05 Април 2012, 11:08:43 am »
vo sekoj klub za vezbanje, na crno sekako.
  • Пораки: 55357
« Одговори #473 на: 05 Април 2012, 11:21:15 am »
HRT moze da ti prepise bilo koj lekar.
« Одговори #474 на: 05 Април 2012, 11:44:45 am »
Treba da imas medicinski problem, odnosno nedostatok na testosteron.
  • Пораки: 22431
« Одговори #475 на: 05 Април 2012, 12:01:28 pm »
While steroid use is most often documented in the media as a illegal use for performance enhancement, there are legitimate medical uses for steroids.
Males who are good candidates for testosterone replacement therapy have many problems that are often embarrassing to admit. These include a loss of libido, night sweats, achy muscles, swelling joints, tinnitus, fatigue and slow healing of cuts and scrapes. These symptoms often occur as a result of low testosterone levels – sometimes also called male menopause. It’s similar to how the female body goes through menopause with a decrease in production of sex hormones.
As males age, it’s not abnormal for their levels of testosterone production to decline. In fact, it’s very normal for this to happen. When males have abnormally low levels of testosterone, however, they can get help with regular testosterone supplements, otherwise known as hormone replacement therapy or testosterone replacement therapy. There have also been studies that show that men who experience high levels of stress may exhibit low levels of testosterone as well and the main symptoms have to do with difficultly performing their job.
While the testosterone replacement therapy can help men find relief of these symptoms, they might also notice other changes as well. Testosterone replacement therapy actually helps reduce obesity and increases sex drive.
  • Пораки: 55357
« Одговори #476 на: 05 Април 2012, 12:07:28 pm »
:D Само тоа е многу примитивен начин на употреба од спортисти. Многу детектабилен. Инаку за просечниот човек е одлично. Порано кога се базираше на тестостерон, види какви тела имаа натпреварувачите. Откога HGH е главна компонента, само со тоа стомаците се шетаат, мевој ко трудници.
  • Пораки: 22431
« Одговори #477 на: 05 Април 2012, 12:19:43 pm »
Deni, obrazlozi.
Porano imalo pokvalitetni steroidi..sega se ckart ili sto?
Ete go, Overeem pogore e dzver so six pack.
  • Пораки: 55357
« Одговори #478 на: 05 Април 2012, 12:23:30 pm »
Порано немало Инсулин (не се детектира, прво официјално користење Дориан) ниту HGH (не се детектира), и двете го дујат стомакот заради зголемени внатрешни органи и внатрешна маст.
Порано се користел паметен менаџмент на користење на продукти со долг и краток живот, сега сите се бутаат од денес за утре со свашта. Инаку за квалитет, мање више - имало и тогаш квалитет, има и сега.
Прати го мевот.
  • Пораки: 22431
« Одговори #479 на: 05 Април 2012, 14:23:21 pm »
Transformers.
