Автор Тема: НАУКА (Астрономија)  (Прочитано 298975 пати)
  • Пораки: 34565
Одг: НАУКА (Астрономија)
« Одговори #1021 на: 03 Декември 2018, 23:09:57 pm »
https://kajgana.com/ekspedicija-kje-ja-reshava-najgolemata-podvodna-misterija-golemata-sina-dupka
https://a1on.mk/archives/983876
Нека ја истражат па после нека ја нарекуваат мистерија. Морони.
Исто ко верверицине, Господ бил мистериозен, а ништо не презеле да испитаат и истражат освен вообичаените зомби активности.
Отсутен Van
  • Пораки: 5405
  • VW Golf MK3 1.9 TDI
« Одговори #1023 на: 06 Декември 2018, 17:04:35 pm »
Kajгана fake news...  ;D
https://www.space.com/42575-see-comet-64p-wirtanen-earth-flyby-december-2018.html
If 46P were reasonably large, it would likely put on a dazzling show around the time of its closest approach.
Instead, what we are dealing with is a very small and intrinsically faint comet; ground-based observations combined with images taken with the Hubble Space Telescope in 1996 revealed the nucleus of 46P to have a diameter charitably estimated to be around seven-tenths of a mile (1.1 km) — one of the smallest cometary nuclei to be measured so far. That's only about one-tenth the size of Halley's Comet and perhaps only one-thirtieth the size of Comet Hale-Bopp.
And it should also be pointed out that 46P is not expected to grow much of a tail — if there is any tail to be seen at all. Big, bright comets usually spawn tails composed of highly reflective dust particles that make for long and eye-catching appendages. But tails from tiny comets like 46P tend to be composed mostly of gases and are often long, thin, quite faint and rather hard to see. More likely, the comet will look like a fuzzy and diffuse ball of light, which may be quite difficult to see against the backdrop of a light-polluted sky. So, if you hope to catch sight of this cosmic vagabond, you most definitely will need to travel far from city lights. The darker your sky, the better. And certainly, binoculars or a telescope will enhance your view. Around the time when it is passing closest to Earth, the comet's head will likely swell in apparent size to more than double the size of the moon.
But again, in order to see that, you will need to "turn up the contrast" and be under a very dark sky.
Отсутен Van
  • Пораки: 5405
« Одговори #1024 на: 09 Декември 2018, 12:53:37 pm »
« Последно менување: 14 Декември 2018, 11:08:30 am NUME »
« Одговори #1026 на: 14 Декември 2018, 13:46:14 pm »
Отсутен Van
  • Пораки: 5405
« Одговори #1027 на: 15 Декември 2018, 01:15:06 am »
« Одговори #1028 на: 28 Декември 2018, 19:05:17 pm »
  • Пораки: 45272
« Одговори #1029 на: 31 Декември 2018, 19:17:20 pm »
« Одговори #1030 на: 01 Јануари 2019, 17:38:38 pm »
« Одговори #1031 на: 04 Јануари 2019, 23:00:38 pm »
  • Пораки: 20406
« Одговори #1032 на: 05 Јануари 2019, 02:15:12 am »
https://a1on.mk/archives/997557
Дај пушти уште некоја ствар за кој ги измислил микропроцесорите, ова е премногу забегано.
« Одговори #1033 на: 05 Јануари 2019, 02:35:19 am »
Nesporno e deka IMA ogromen bum vo tehnologija odednas, isto  kako sto odednas se pojavil i zivot na planetava...
  • Пораки: 34565
« Одговори #1034 на: 06 Јануари 2019, 12:30:45 pm »
Животот на планетава не се појавил одеднаш. Поминале стотици милиони години пред вистинска форма на живот да се појави и да биде способна да се размножува.
Sent from my Redmi Note 6 Pro using Tapatalk
