Автор Тема: Замена на фабричко озвучување  (Прочитано 51663 пати)
Отсутен DC
  • Пораки: 256
Одг: Замена на фабричко озвучување
« Одговори #120 на: 12 Јануари 2012, 00:27:49 am »
http://www.talkaudio.co.uk/index.php/index.html/_/reviews/speakers/jbl-gto-6528-coaxial-loudspeakers-r791
Види го линков, прочитај.
 ;D ;D ;D ;D ;D
With a product lifespan like high end studio monitors and awesome build quality, they were incredible.
T696s have an appetite for watts that I'm not sure many other ovals anywhere can match.
These speakers are perfect for those wanting extremely serious sounds in the back for passengers or simply require an enormous score in the “What the F's THAT?”
http://www.talkaudio.co.uk/index.php/index.html/_/reviews/speakers/jbl-t696se-coaxial-6x9-three-way-r120
Присутен Simo - Carrier159
  • Пораки: 45367
« Одговори #121 на: 12 Јануари 2012, 00:42:30 am »
Reduced nominal impedance
• The new GTO speakers have a nominal impedance of 2 ohms. Therefore, they extract all the power from amplifiers and head
units, which are normally designed to increase their power when driving 2-ohm loads. The actual minimum impedance of GTO
speakers is around 3 ohms, thus offering enough safety against potential overheating of low-quality BTL amps in less expensive
head units.
http://convoy.com.au/downloads/product-files/Specification%20Sheet%20-%20GTO%20Multielements%208%20range%20%28English%29_0a83.pdf
Сепак, прашајте ги JBL дали ќе гарантираат дека вашиот HU нема да цркне?
After reading JBL, Infinity, and Polks claim about 2 ohm speakers being safe for your 4 ohm headunit I decided to ask Kenwood and Pioneer what they thought.  Kenwood asked if Infinity was willing to warranty their decks since Infinity/JBL thinks it's okay.  They said it will shorten the life of your head units internal amp.  Pioneer said do not do it unless you run them off of an external 2 ohm stable amp.  The only thing keeping your head unit safe from 2 ohm speakers is the factory speaker wire in your car.  This is what Infinity/JBL's  "true 4 ohm philosophy" is premised on.  So until you decide to buy an amp do not ever ever install better speaker wire.  Maybe it is okay, but if it was how come Kenwood and Pioneer doesn't think so?? I would tend to think that they know more about their equipment than Infinity.
http://community.crutchfield.com/forums/p/11766/51766.aspx
Јас не викам дека не ги бива, јас планирам да ги купам за себе, ама ќе ги возам на појачало кое со сигурност може да поднесе 2 ома.
Отсутен Dzo
  • Пораки: 3030
  • GTI®
« Одговори #122 на: 12 Јануари 2012, 01:30:26 am »
2oma али да се возат на пионир кларион мислам со повисок квалтет .. рецмо PIONEER DEH-P 88RS :)
Отсутен vox centar
  • Пораки: 2
« Одговори #123 на: 14 Јануари 2012, 09:55:23 am »
Na tvojot lancer mozna e promenata na fabrickoto radio potrebno e da kupis adapter maska za lancer koja e malku poskapa okolu 50 eur i togas moze da postavis aftermarket ured kakov ti se dopaga. Konektorot na Lancer e isto ne standarden i toj e pozelno da se kupi za da ne se sece fabrickata instalacija.Nie maska vo Vox nemame vo momentov ali ke ja imame nekade vo II mesec  vtora polovina
Отсутен Dzo
  • Пораки: 3030
  • GTI®
« Одговори #124 на: 15 Јануари 2012, 00:00:44 am »
Некој да бил во допир со ова axton cac 218? Некои искуства совети?
Отсутен ZEC Electronics
  • Пораки: 101
    • www.zec.mk
« Одговори #126 на: 13 Септември 2012, 11:01:15 am »
2 ома звучници прават ЈБл со единстевена намена да кога ќе ги врзеш на појачало добиеш поголема “ галама“ во децибели...инаку не е препорачливо за било кое радио да се стави помалце од 4 ома звучници....а за информација импедансата не е еднаква на отпорност !!!!  значи додавањето на 2ома отпорник ?!?!?!?!?   како што ми кажа еден “стручњак“ апсолутно нема да ја направи импедансат 4ома.....доколку ставате 2 ома звучници МАСТ е да се стават на појачало....прегревањето на радиото во одредени моменти може да биде многу поголемо од фабрички пресметаната дисипација на ладилникот....и моменталните повратни удари се со многу повисока амплитуда......
Поздрав
Чичко ЗЕЦ В-)))
ZEC ELECTRONICS
ZASTAPNIK I OVLASTEN SERVIS ZA
PIONEER , JVC , ALPINE  GROUND ZERO, MTX AUDIO ,MAGNAT , MAC AUDIO , BLAUPUNKT , JAMO, ONKYO , LENCO , ION , PIONEER DJ , SHERWOOD , ELTAX , AMERICAN DJ I MN.DRUGI
INFO 02/3110-186
  • Пораки: 15281
« Одговори #127 на: 31 Октомври 2013, 17:33:47 pm »
