Автор Тема: Mobil, Total, Elf или какво масло ?  (Прочитано 2251923 пати)
Отсутен FilipM
  • Пораки: 3999
  • Turbo
« Одговори #825 на: 17 Август 2012, 21:34:28 pm »
За Synthoil сигурно, тоа треба да е 100% синтетичко, јас би играл на тоа..не се разбирам многу во ЛМ, нека се искажи Џиџи :)
http://www.liqui-moly.de/liquimoly/web.nsf/id/pa_domb8dgeye.html страна 25
« Последно менување: 17 Август 2012, 21:45:40 pm FilipM »
Отсутен Lazarus
  • Пораки: 536
  • drive it like you stole it!
« Одговори #826 на: 17 Август 2012, 21:55:31 pm »
oк, фала ти за одговорот.
Отсутен FilipM
  • Пораки: 3999
  • Turbo
« Одговори #827 на: 17 Август 2012, 21:58:11 pm »
НП :D
You can largely ignore what's printed on the bottle. For something to qualify as a 0w40, there's a range of kinematic viscosities it can have. So it is entirely possible for there to be a "thin 0w40" and a "thick 0w40". There are some 5w30s that are so thick they're only 5% thinner than some 5w40s, for example. It's a sliding scale.
The reason I say you can ignore what's on the bottle is that the HTHSV (high temp high shear viscosity, sometimes shown as just HTHS) is the true "operational viscosity" of an oil. HTHS is basically the oil's kinematic viscosity at 150 C, a temperature you will see in the bearings and other high-stress areas. Judge an oil's viscosity by the HTHS value, not the printed viscosity on the label. The VW 502/505 (and ACEA A3/B3 spec upon which it is based) calls for HTHS to be at least 3.5. You will see a whole host of oils right around there: 0w30s, 5w30s, 0w40s, and 5w40s.
Here's a good example: Castrol Syntec 0w30 and Liqui-Moly Synthoil Energy 0w40 both have HTHSV of 3.6. This means that for all intents and purposes, these two oils will have the same viscosity during normal operation. This is despite one appearing to be thinner! Another good example: Red Line 5w30 and Mobil 1 0w40 both have HTHSV of 3.8. Again, both of those oils will have the same viscosity during normal operation....yet one is 5w30 and the other 0w40!
Here's another doosy that will really illustrate it well: Motul 300V 5w40 offers HTHSV of 4.51. Castrol Syntec 5w50 offers HTHSV of 4.3...so which oil is thicker? The Motul is, despite being labeled as a 5w40 and appearing to be thinner.
One more in case you still aren't getting it: Red Line 5w20 has HTHSV of 3.3. Pennzoil Ultra 5w30 has HTHSV of 3.1...so the Pennzoil is thicker because it's a 5w30, right? Wrong, the Red Line is thicker since it has a higher HTSV.
Where people get into trouble is assuming that all 0w30s, for example, are the same viscosity. They aren't. Mobil 1 Advanced Fuel Economy 0w30 has an HTHSV of only 3.0 -- it is considerably thinner than Castrol Syntec 0w30 (3.6). The M1 would be some 17% thinner in operation despite being labeled as the same viscosity! Certain boutique oils for racing/high-performance apps, like Red Line and Motul 300V, have abnormally high HTHSV for their grade. Red Line's 5w30, as I said above, is as thick as many 5w40/0w40s! This is a result of the special group V basestocks they use.
Pick an oil with HTHSV 3.5-4.0. Anything higher than 4.0 is unnecessary in most of our cars and will just sap power and generate more heat (and change oil pressure slightly). Anything under 3.5 is a gamble that would result in more power/better fuel economy but provide considerably less protection.
http://www.audizine.com/forum/showthread.php/480344-Oil-Why-5W-40
« Последно менување: 17 Август 2012, 22:21:33 pm FilipM »
« Одговори #828 на: 18 Август 2012, 01:35:03 am »
Ја би одбрал Top Tec 4100 5 W-40. Top Tec е најдоброто (по мене) од LM ! 590 ден ти е литар или 2.650,00 ден 5 l. Од Synthoil би одел на Energy, a не на Hightec, иако Longtime го рачунаат за најдобро...
Отсутен Bojan j
  • Пораки: 3063
« Одговори #829 на: 18 Август 2012, 20:27:42 pm »
djidji, во сервис во Форд ми ставаат вакво масло http://www.european-parts.net/catalog/images/IMG_0329.JPG , видов на сметката од првиот сервис, 1л масло е 309 ден... Е сега сакам на нареден сервис да си купам сам и некое подобро и поквалитетно од ова... Што ми препорачуваш ти и кое? И Денис треба да зима бтв... Мене во кола ми собира 3.7 л масло, они ми наплаќаат за 4л, можда не звучи многу ама ми смета... Следно мењање треба за 7 000 км, ама ќе биде и порано пред зимата таму почеток на октомври...
« Одговори #830 на: 18 Август 2012, 20:37:46 pm »
Bojan j ова уље не ти го препорачувам,за брзо време поцрнува и ги губи својствата,земи си Top Tec 4100 5 W-40 нема да згрешиш
Отсутен Bojan j
  • Пораки: 3063
« Одговори #831 на: 18 Август 2012, 20:41:04 pm »
Баш затоа прашувам за мислење...зашто по сервисиве гледаат да заштедат ... иначе после сервисот проверив до каде е уљето, значи одма после сервисот...беше скроз на минимум... многу дубари се прават... затоа следна промена кај пријател со мое уље и филтер и се што треба... Има време до промена ама да си знам од сега кое стварно вреди за парите
« Одговори #832 на: 18 Август 2012, 20:52:20 pm »
За Денис најбоље е Тотал 9000, а за тебе (према спецификациите од оригиналното) ова:
http://www.ardecausa.com/products/motor-oil/syn-tec-dx-5w30.php
Пробај, па ќе частиш ;) btw нели сега стави Кератек ... почекај 3000 км, па мењај. Не ти требаат други адитиви ако го мењаш еднаш годишно или на 10000 км. Ако претежно возиш у град - мењај на 7000 км.
Отсутен Bojan j
  • Пораки: 3063
« Одговори #833 на: 18 Август 2012, 20:55:24 pm »
САМО во град возам :D Жити летово што ја издував до Ох. и назад...ќе почекам уште некои 2000км, ако треба ќе земам пак кератек и пола шишенце ќе ставам... Фала сепак :D
Бтв каде го има ова и која цена за литро ако знаеш ?
« Одговори #834 на: 18 Август 2012, 21:00:41 pm »
Незнам кој е увозник за МК - ме мрзи да барам, ама знам дека и marsher го има стално у сервис (цената му е дилерска, плус и ќе ти го замени стручно ...). Нема потреба пак да ставаш Кератек.
Отсутен Bojan j
  • Пораки: 3063
« Одговори #835 на: 18 Август 2012, 21:02:01 pm »
Ете и мајстор се најде... топ! Фала, па ќе частам пијачки на свадба догодина :D
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #836 на: 18 Август 2012, 22:48:08 pm »
Ако ти ја враќаат кантичката со остаток од маслото, тогаш може да ти наплатат за 4л, меѓутоа ако е на точење, треба да ти наплатат толку,колку што наточиле...Меѓутоа за нашиве временски прилики би ти препорачал 5w40..
Отсутен Bojan j
  • Пораки: 3063
« Одговори #837 на: 18 Август 2012, 22:49:36 pm »
Не ја вратиле...
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
« Одговори #838 на: 18 Август 2012, 22:55:05 pm »
Треба, или целата фирма е вмешана во тој стил на работа или мајсторите си тераат своја политика... ;D
Отсутен Bojan j
  • Пораки: 3063
« Одговори #839 на: 18 Август 2012, 22:59:27 pm »
Не е битно, не им одам веќе за такви мали работи да ме јебат :D
Го имаш ли ти маслово што ми го препорача Џиџи кај тебе ? Цена ако не е тајна ? :D
