Автор Тема: Mobil, Total, Elf или какво масло ?  (Прочитано 2362273 пати)
  • Пораки: 6707
« Одговори #6810 на: 12 Септември 2018, 09:36:09 am »
https://www.sae.org/publications/technical-papers/content/2007-01-4133/
Engine oils are subjected to a series of industry standard engine dynamometer tests to measure their wear protection capability, sludge and varnish formation tendencies, and fuel efficiency among several other performance attributes before they are approved for use in customer engines. However, these performance attributes are measured at the end of tests and therefore, do not provide any information on how the properties have changed during the tests. In one of our previous studies it was observed that engine oil samples collected from fleet vehicles after 12,000 mile drain interval showed 10-15 % lower friction and more importantly, an order of magnitude lower wear rate than those of fresh oils. It was also observed that the composition of the tribochemical films formed was quite different on the surface tested with the drain oils from those formed with fresh oils. The objective of this investigation is to demonstrate how the friction and wear performance changed with oil drain intervals. A fleet of three vehicles was run in Las Vegas and oil samples were collected at various drain intervals from 3000 miles to 15000 miles. As in the previous study, the results showed that the aged engine oils provide lower friction and much improved wear protection capability. These improvements were observed as early as the 3000 mile drain interval and continued to the 15000 mile drain interval. The composition of tribochemical films formed on the surface with the 3000 mile drain interval is similar to that formed with the 12000 mile drain interval as seen before. These findings could be an enabler for achieving longer drain interval although several other factors must to be considered.
  • Пораки: 1083
  • Best Motors Worldwide
« Одговори #6811 на: 13 Септември 2018, 20:15:36 pm »
BP nema proizvodstvo na maslo vo Slovenija. Neka ne ve lazzat.
mozebi se polni (cisto sumnjam, najverovatno se nosi od avstrija kade castrol ima sediste)
no proizvedeno e sigurno vo germanija vo Hamburg-Neuhof.
bp prodava vo evropa godisno 43m t masla od koi 25m t vo germanija, taka da koga mozze da proizvedat 30m nema logika da ne gi proizvedat i ostanatite isto vo germanija.
ako e original e germansko proizvodstvo. Castrol e brand na BP i gi koristi rafineriite na bp za baznite masla.
vo vw moraat da toccat castrol 5w30 long life za 504/50700 toa e masloto za site motori na vw ag za tie specifikacii.
---Best Motors Worldwide---
       (Oo=[][]=oO)
  • Пораки: 7400
« Одговори #6812 на: 14 Септември 2018, 13:54:05 pm »
Масло за 2.0TDI PD BKD код 103kW, бара барем 502 спецификација, без ДПФ.
Селекторот на ликви моли не го вади Leichtlauf High Tech 5W-40, a има VW 502/VW 505
А го вади TOP TEC 4100 5W-40, исто со VW 502/VW 505, шо е разликата  :-\
ова погорново на форумов е многу клањато, а цената е слична, ова подолново понечини?
  • Пораки: 1083
« Одговори #6813 на: 14 Септември 2018, 19:09:51 pm »
spored moe skromno znaenje mislam deka samo za nekolku specificni v6 i R5 motori kade sto treba striktno posebna specifikacii se drugo pokriva 504/50700 no ovaa e long life i e najskapa specifikacija. ovaa specifikacija ima Hths >3,5 i jaki derivati taka da ispolnuva long life intervali. mnogu retko ke najdes masla so 504/507 od LM toa e Top Tec 4200
502/505 se poeftini se menjaat fiks 1x godisno
Najsiguren oil finder spored mene e na kroon oil:
https://www.kroon-oil.com/de/produktberatung/pkw/volkswagen-eu-vw/golf-v-1k1/golf-v-20-tdi-103-kw/27203/142497/23/4/#!/component:142497/
       (Oo=[][]=oO)
Отсутен damjanku
  • Пораки: 301
« Одговори #6814 на: 14 Септември 2018, 23:06:39 pm »
За PD мотори како што знам е 505 01 или 504/507 за longlife интервал. Затоа второто уље што има 505 01 спецификација ти го вади на LM сајтот.
Отсутен ogledalo
  • Пораки: 615
« Одговори #6816 на: 17 Септември 2018, 23:01:44 pm »
Стигна пресна роба денес во Бис Оил,како што кажа changetheoil savethecar маслото се увезува од регионалниот дистрибутер од Словенија,истото е произведено во некој од фабриките на Кастрол а во која зависи за кој тип на масло се работи,база,адитиви и слично.
Отсутен IdeuX
  • Пораки: 763
  • Пораки: 1083
« Одговори #6818 на: 18 Септември 2018, 00:26:51 am »
A, kroon oil ulje go biva li?
Gledam mnogu niska cena drzi, mene ova me interesira 1900den 5 litra
http://autofilter.mk/index.php?route=product/product&path=33_81&product_id=268
da, go biva zimaj bez strav. toa maslo ne e na nivo na 504/507.00 ama e mnogu blisku do nego ako go menuvas 1x godisno poln pogodok.
koga tuka davam preporaki ne navlguvam vo detalite dali masloto e kradeno, pretocuvano vo aracino, svercano od albanija i takvi diskusii. zboruvam za brendot i proizvodot kako originalen, baznimasla i dodatnite derivati po specifikacija.
kroon oil e top firma za masla imaat mnogu jaki  derivati koj go cistat motorot.
isto taka treba da imas vo obzir kolku km ima pominato motorot i kako ja vozis kolata. Ako vekje gradacijata e utvrdena 5w30 togas Kronkata ti e bingo...  koja gradacija si ja voel dosega?
pozdrav
       (Oo=[][]=oO)
Отсутен Indigo
  • Пораки: 464
« Одговори #6819 на: 18 Септември 2018, 10:50:20 am »
што мислите за engine flushing (10 минути работа во лер) со ефтино минерално масло 20w50 на мотор што треба да носи 10w40 ? купив 2 години стоена кола па би сакал внатрешно да го „исперам“ моторот со овој метод.
  • Пораки: 45189
« Одговори #6820 на: 18 Септември 2018, 10:52:50 am »
Ништо нема да му биде на моторот...Ја би му дал повеќе од десет минути, барем добро да загрее, па уште едно 20-30 минути работа.
  • Пораки: 6707
« Одговори #6821 на: 18 Септември 2018, 10:56:41 am »
Све е ова фалц, се познава по картонот.  ;D
Отсутен ogledalo
  • Пораки: 615
« Одговори #6822 на: 18 Септември 2018, 12:02:34 pm »
pozdrav
Do sega samo 5w30, so dexos2 mi treba, 95.000km ima pominato.
Momentalno sum vo Grcija i sakam da vidam sto ceni imaat po benzinskite ovde, shell i bp.
Jas mislam deka sigurno ke zemam Liqui moly engine cleaner pred menuvanje ovoj pat. 350 den e aditivot, se stava vo motorot i po 200 km normalno vozenje se menuva masloto.
  • Пораки: 1083
« Одговори #6823 на: 18 Септември 2018, 23:31:04 pm »
stavi mu 10w40 i smenigo na pola interval ti e najpametno. i posle stavas novo i prodolzzisi so normlaen interval.
jas bi ti go preporacal polytech 10w40 od kroon oil.
       (Oo=[][]=oO)
  • Пораки: 1083
« Одговори #6824 на: 18 Септември 2018, 23:34:13 pm »
pozdrav
ne ti treba cleaner nemas potreba, toa se stava kaj motori sto ne se odrzzuvani redovno, ostaveni onaka na milost nemilost, ulje sekoj dve godini od najeftinoto i filter sekoj vtor pat..takvi pricci..
       (Oo=[][]=oO)
