Автор Тема: Opel Astra GTC  (Прочитано 16206 пати)
  • Пораки: 16807
Opel Astra GTC
« на: 07 Јуни 2011, 04:31:26 am »
Compared to the five-door Astra, the ride height of the GTC is lowered by 15 mm while the wheelbase grows by 10 mm, from 2,685 to 2,695 mm and both tracks are wider, at 1,584 mm (+ 40 mm) in front and 1,588 mm (+ 30 mm) in the rear.
Opel and its sister brand Vauxhall say the Astra GTC is a more driver’s car than the five-door model as the company’s engineers having made several changes to the chassis including the adoption of the HiPerStrut (High Performance Strut) setup used on the 325HP Insignia OPC / VXR instead of the standard McPherson suspension.
At the rear, the GTC continues to use a Watt’s link axle, while as an option, Opel offers the fully-adaptive FlexRide chassis control system with a choice of three settings - Standard, Tour or Sport.
Moving on to the available lineup at launch, the Astra GTC can be ordered now with a choice of four engines. However, Opel said more powertrains will be offered around its world premiere at the Frankfurt Motor Show adding that the sportiest versions including the future high-performance OPC model will follow in 2012.
For now, diesel options are limited to a 2.0-liter CDTI common-rail turbo unit delivering 165HP and 380 Nm of torque in overboost function. It is fitted with a diesel particulate filter and a six-speed manual transmission, plus a new Start/Stop system. With this engine, the GTC can reach 100 km/h (62mph) in 8.9 seconds en route to a top speed of 210 km/h (131 mph), while returning a combined fuel consumption of 4.9 lt/ 100 km (48 mpg US or 57.7 mpg UK) with corresponding CO2 emissions of 129 g/km.
The most powerful engine is a 1.6-liter turbocharged gasoline unit with 180-horses linked to a six-speed manual gearbox offering the GTC a top speed of 220 km/h (137 mph). A 1.4-liter turbocharged four-cylinder engine available with 120HP and 140HP completes the petrol lineup.
Отсутен Tommy
  • Пораки: 7905
Одг: Opel Astra GTC
« Одговори #1 на: 07 Јуни 2011, 05:06:18 am »
Ке видиме денеска што ке речат од Автокуќа околу цените на истава ... Нели, денес е официјалната промоција на истата во Македонишен...
Иначе наликува на фејслифтуван Леон,и за разлика од стара сега ГТЦ, оваа воопшто не претставува некој новитет кој е својствен по себе ...
Бојата е пријатно изненадување ...
Претпоставувам, истата од погоре, со 19-ки, навигација, полукожа, ладно ке чини 20 по глава + ...
Оправдано ги нема информациите за тежината на возилото кое во верзијата со 5 врата е потешко од своите противници во својата класа ...
Нема слика од задната клупа, конзолата се добива впечаток дека можела да се упорости, наместо да се има 30+ копчиња ...
Ке ја видиме у живо, па ке дадеме некој коментар плус ...
« Последно менување: 07 Јуни 2011, 05:35:03 am Tommy »
  • Пораки: 22390
Одг: Opel Astra GTC
« Одговори #2 на: 07 Јуни 2011, 09:17:15 am »
Hmmmmm... aj vaka..
1.Fancy....nesto sto bi i se dopadnalo na devojka so cel da ja uparkira pred Trend, a ne pred Marakana ili Havana, pogotovo so vakov bandaz..a mozam da zamislam kako ke izgleda so osnovna verzija so 16 ka.
2.Ubava, elegantna, nimalku sportska prednica  i nepotrebno oruzneta zadnica so Seat Leon like crna plastika...
3.If squillions of buttons and beeping and flashing things inside floats your boat, this is the car 4 you...not me, though.
4.Iako i fali sportska nota, sepak izgleda podobro od Gulieta, Megan, Leon i ostanati bubregoidni modeli..ali ne i od VW Scirocco ....duri i da ima OPC body kit kako optional extra, mada ne veruvam.
5.2005 Astra GTC FTW. :D - more sporty, more distinctive,  simple inside, now cheaper and ....lighter.
« Последно менување: 07 Јуни 2011, 11:21:57 am Stratro »
Одг: Opel Astra GTC
« Одговори #3 на: 07 Јуни 2011, 09:43:26 am »
4.Iako i fali sportska nota, sepak izgleda podobro od Gulieta, Megan, Leon i ostanatai bubregoidni modeli..ali ne i od VW Scirocco...duri i da ima OPC body kit kako optional extra, mada ne veruvam.
Отсутен S16-HGT
  • Пораки: 4441
  • НУКЛЕАРЕН КОМАРЕЦ
Одг: Opel Astra GTC
« Одговори #4 на: 07 Јуни 2011, 09:47:46 am »
Сега кога ќе почнат да штанцаат вакви 1.4 за наш пазааааааар... :)
Одг: Opel Astra GTC
« Одговори #5 на: 07 Јуни 2011, 09:53:31 am »
Колава е сон. А особено е + тоа што е Опел со најдобри мотори во свет. (освен дизелот)
  • Пораки: 22390
Одг: Opel Astra GTC
« Одговори #6 на: 07 Јуни 2011, 09:55:24 am »
Mozes da ja kupis ovaa pogore od salon... a mozes i za slicna suma da zavrsis so vakvo nesto.
http://suchen.mobile.de/fahrzeuge/showDetails.html?lang=en&id=145742197&pageNumber=2&scopeId=C&sortOption.sortBy=searchNetGrossPrice&makeModelVariant1.makeId=19000&makeModelVariant1.modelId=5&makeModelVariant1.modelDescription=OPC&minFirstRegistrationDate=2005-01-01&damageUnrepaired=ALSO_DAMAGE_UNREPAIRED&export=ALSO_EXPORT&categories=SportsCar&tabNumber=2
14,999 EUR
VAT not reclaimable
Sports car/Coupe, Used vehicle
FR 05/2006
54,500 km
Petrol (E10-enabled)
177 kW (241 PS)
Manual gearbox
Stvar na ukus i izbor...
« Последно менување: 07 Јуни 2011, 10:02:18 am Stratro »
  • Пораки: 55347
Одг: Opel Astra GTC
« Одговори #7 на: 07 Јуни 2011, 11:46:26 am »
На ГТЦ обртомерот оди до 6000, а на 5 е црвено?! Ај дизелот е ваљда.
А кола со 180кс, има макс брзина од 220!? Абе отидени се.
Отсутен RikiRulz
  • Пораки: 10640
  • *** UNDERCOVER ***
Одг: Opel Astra GTC
« Одговори #8 на: 07 Јуни 2011, 12:06:03 pm »
Немам зборови... ова е дизел 1.3 цдти :)))))))
Одг: Opel Astra GTC
« Одговори #9 на: 08 Јуни 2011, 15:43:12 pm »
Одг: Opel Astra GTC
« Одговори #10 на: 08 Јуни 2011, 16:07:26 pm »
Ова е аутото за мене
  • Пораки: 16807
Одг: Opel Astra GTC
« Одговори #11 на: 08 Јуни 2011, 17:27:55 pm »
Убава е Астрава, верна на концептот, само тие браници гарант ги чуваат за OPC верзијата
  • Пораки: 30838
Одг: Opel Astra GTC
« Одговори #12 на: 08 Јуни 2011, 18:07:27 pm »
И мене ми изгледа добро. Ќе видиме како ќе се покаже кога ќе ја донесат. Вака на папир, ветува, али ваљда нема да биде 4 тона тешка.
Отсутен bubeqwerty
  • Пораки: 574
Одг: Opel Astra GTC
« Одговори #13 на: 08 Јуни 2011, 18:35:29 pm »
Damn it јака е :)
Отсутен Sportex
  • Пораки: 7879
  • Иштван Беќар Пецарош
    • camouflage.mk
Одг: Opel Astra GTC
« Одговори #14 на: 08 Јуни 2011, 19:02:44 pm »
И мене ми се свиѓа, единствено не можам да ги разберам 1001-то копче...шо е многу многу е ти треба да си носиш човек со тебе да ти ги притиска!
