Автор Тема: Formula 1 - Season 2013  (Прочитано 389206 пати)
Одг: Formula 1 - Season 2013
« Одговори #1395 на: 20 Јуни 2013, 16:33:24 pm »
Статистиката е средство за манипулација со податоците.
Аха, особено кога податоците не одат во прилог на паушалните тези.
Или, како што знаеше да каже еден професор по социологија: „кога теоријата не се совпаѓа со фактите, тогаш тешко си им на фактите“ :-)
  • Пораки: 7282
« Одговори #1396 на: 20 Јуни 2013, 16:42:57 pm »
Најдобриот на сите времиња:
Schumacher holds the following Formula One records:
Championship titles - 7 (1994, 1995, 2000, 2001, 2002, 2003, 2004)
Consecutive titles    - 5 (2000–2004)
Championship won with most races left - 6 (2002)
Largest championship-winning margin(pre-2010 points system) - 67 points (2002)
Race wins - 91
Consecutive wins - 7 (2004, Europe–Hungary)
Wins in a season - 13 (72%) (2004)
Wins in a season for a runner-up - 7 (2006)
Wins at Monza (Formula One)   - 5
Wins at Spa (Formula One) - 6
Wins in Canada (Formula One) - 7
Wins with one team - 72 (Ferrari)
Wins at the same Grand Prix - 8 (France)
Different Grands Prix won - 22
Longest time between first and last wins - 14 years, 32 days
Total years with a win - 15 (1992–2006)
Consecutive years with a win   - 15 (1992–2006)
Second places - 43
Consecutive top two finishes   - 15 (Brazil 2002–Japan 2002)
Podiums (Top 3 finishes) - 155
Podium finishes in a season - 17 (100%) (2002)
Consecutive podium finishes - 19 (US 2001–Japan 2002)
Championship points - 1,566
Points finishes - 221
Consecutive points finishes - 24 (Hungary 2001–Malaysia 2003)
Races / Laps / Distance led - 142 races / 5,111 laps / 24,144 km[197]
Pole positions - 68
Front row starts - 116
Fastest lap - 77
Fastest laps in a season - 10 (2004)
Doubles (Pole and win) - 40
Hat tricks (Pole, win and fastest lap) - 22
Hat tricks in a season - 5 in 2004
Races with one team - 181 (Ferrari)
https://en.wikipedia.org/wiki/Michael_Schumacher
Отсутен Dekio7
  • Пораки: 2601
« Одговори #1397 на: 21 Јуни 2013, 14:34:16 pm »
Еве каков ќе биди звукот на моторите в година.
http://www.renaultsport.com/Come-on-feel-the-noise,2630.html?lang=fr
Отсутен Vasil
  • Пораки: 3759
« Одговори #1398 на: 21 Јуни 2013, 15:02:36 pm »
Ц Ц Ц го срушивте renaultsport.com :)
Многу добар .pdf со детално објаснување за новиот мотор:
http://media.renault.com/download/media/specialfile/49473_1_5.aspx
THE RENAULT ENERGY F1- 2014: NEW TERMINOLOGY FOR A NEW ERA
‘‘The next generation of F1 cars will be powered by a turbocharged 1.6-litre V6 internal combustion engine of around 600 bhp plus around 160 bhp of electrical propulsion from the energy recovery system, meaning the term ‘engine’ will no longer fully describe a car’s source of propulsive power. It is more relevant to refer to the complete system as a ‘Power Unit.’’ Rob White, Deputy Managing Director (technical)
V6
V6 is shorthand for an internal combustion engine with its cylinders arranged in two banks of 3 cylinders arranged in a ‘V’ configuration over a common crankshaft. The Renault Energy F1 V6 has a displacement of 1.6 litres and will make around 600bhp, or more than 3 times the power of a Clio RS.
TURBOCHARGER
A turbocharger uses an exhaust driven turbine to drive a compressor to increase the density of the intake air consumed by the engine and so make more power for a given displacement.
The residual heat energy contained in the exhaust gases after expansion in the cylinders of the engine is converted to mechanical shaft power by the exhaust turbine. The mechanical power from the turbine is used to drive the compressor, and also the MGU-H (see below).
As the turbocharger speed must vary to match the requirement of the engine, there may be a delay in torque response, often known as turbo-lag. One of the great challenges of the new Power Unit is to
reduce this to near zero to match the instant torque delivery of the current V8 engines.
WASTEGATE
A wastegate is often used in association with a turbocharger to control the system. It is a control device that allows excess exhaust gas to
by-pass the turbine, to match the power produced by the turbine to that needed by the compressor to supply the air required by the engine.
DIRECT FUEL INJECTION
With direct fuel injection (DI), fuel is sprayed directly into the combustion chamber rather than into the inlet tract upstream of the inlet valves. The fuel-air mixture is formed within the cylinder, so great precision is required in metering and directing the fuel from the injector nozzle. This is a key sub-system at the heart of the fuel efficiency and power delivery of the Power Unit.
MGU
A motor generator unit (MGU) is an electrical machine. When operating as a motor, the MGU converts electrical energy to mechanical energy. When it operates as a generator the MGU converts mechanical energy to electrical. The 2014 Power Unit uses two MGUs; an MGU-H (H for Heat – exhaust energy recovery) and MGU-K (K for Kinetic – kinetic energy recovery during braking).
MGU-K
The MGU-K is connected to the crankshaft of the internal combustion engine and is capable of recovering or providing power (limited to 120 kW or 160 bhp by the rules). Under braking, the MGU-K operates as a generator to slow the car (reducing the heat dissipated in the brakes) and so recovers some of the kinetic energy and converts it into electricity. Under acceleration, the MGU-K is powered (from the Energy Store and/or from the MGU-H) and acts as a motor to propel the car.
MGU-H
The MGU-H is connected to the turbocharger. Acting as a generator, it absorbs power from the turbine shaft to recover heat energy from the exhaust gases. The electrical energy can be either directed to the MGU-K or to the battery for storage for later use. The MGU-H is also used to control the speed of the turbocharger to match the air requirement of the engine (eg to slow it down in place of a wastegate or to accelerate it to compensate for turbo-lag.)
ERS
The Power Unit’s ERS (Energy Recovery System) uses the MGU-H and MGU-K plus an Energy Store, plus some power and control electronics. Heat and Kinetic Energy recovered can be consumed immediately if required by the other MGU, or used to charge the Energy Store. The stored energy can be used to propel the car by the MGU-K or to accelerate the turbocharger by the MGU-H. Compared to 2013 KERS, the ERS of the 2014 Power Unit will have twice the power (120 kW vs 60 kW) and a performance effect 10 times greater
Ќе има и интеркулер што ќе биде поставен наместо ладилникот лево од возачот.
« Последно менување: 21 Јуни 2013, 15:17:50 pm V »
« Одговори #1399 на: 21 Јуни 2013, 19:16:01 pm »
bullshit
Присутен n1kola
  • Пораки: 7847
« Одговори #1400 на: 23 Јуни 2013, 01:25:08 am »
V6 1.6cc 750 hp  :)
Ко не напрат еден ваков за во Мегане РС :D
  • Пораки: 22394
« Одговори #1401 на: 23 Јуни 2013, 22:44:03 pm »
Ako rabotite prodolzat vo ista nasoka...
F1 Season 2021:
Отсутен kimi makedonski
  • Пораки: 3524
  • Хюндай Тюсон
« Одговори #1402 на: 23 Јуни 2013, 23:52:51 pm »
F1 Season 2021:
И куоро ќе дојде и ќе каже.“алонсо е најдобар шофер на сезона 2020“
А тој ти завршил прв од позади :D
  • Пораки: 22394
« Одговори #1403 на: 24 Јуни 2013, 11:32:17 am »
;D
Отсутен Pal Zileri
  • Сијка Пиштолова
  • Пораки: 2464
« Одговори #1404 на: 25 Јуни 2013, 17:22:09 pm »
Уште не можам да поверувам дека 1.6 ќе се користи во Ф1.
www.domitalia.mk
  • Пораки: 8540
« Одговори #1405 на: 25 Јуни 2013, 17:55:13 pm »
Па се планира најверојатно да има дизели. Мора да ги симнат бензинците. :)
Отсутен Sportex
  • Пораки: 7879
  • Иштван Беќар Пецарош
    • camouflage.mk
« Одговори #1406 на: 25 Јуни 2013, 18:02:21 pm »
Да ама После кога ќе си купиш Рено или Мерџан косилица со 1.6 мотор, ќе пишува на него F1 Technology !  ;D
Отсутен Pal Zileri
  • Сијка Пиштолова
  • Пораки: 2464
« Одговори #1407 на: 25 Јуни 2013, 18:06:47 pm »
Ништо од дизелите.Полека,полека и од Ле Ман ќе ги избацат како што ги избација и од WTCC.Се знае кое гориво се користи за трки,а кое за по дома ;D
www.domitalia.mk
Присутен Skywalker
  • Пораки: 4442
« Одговори #1408 на: 25 Јуни 2013, 18:21:13 pm »
Попрво ќе одат на електрични мотори одколку на дизел.
Отсутен Vasil
  • Пораки: 3759
« Одговори #1409 на: 25 Јуни 2013, 19:40:01 pm »
Користеле и помали со помалку цилиндри, ама со многу поголемо турбо, многу помал рок на траење.
http://www.gurneyflap.com/bmwturbof1engine.html
Сепак најголемиот проблем за следната година ќе биде ограничувањето на 100 литри за цела трка, а тоа се 33 литри на 100 км.
