Автор Тема: Corvette C7  (Прочитано 123200 пати)
2014 Chevrolet Corvette C7 Stingray Debuts in Detroit
« Одговори #90 на: 14 Јануари 2013, 09:50:03 am »
The seventh generation of the Chevrolet Corvette has just made its world debut in Detroit and we have to tell you that this is way more than just a generation change. GM has turned to the "Stingray" designation, one that it only uses for special models, for the C7 and the company promises massive upgrades both in terms of sheer performance and feel.
Under the sculpted hood, we find GM's new LT1 V8 unit. This marks the debut of the Gen 5 range of Small Block engines, which means that it's packed with technology.
The powerplant makes use of features such as direct injection, continuously variable valve timing and cylinder deactivation. The V8 has a displacement of 6.2 liters, delivering 450 hp and a peak torque of 450 lb-ft (610 Nm). In addition to that, the torque curve is phenomenal - for example, at 2,000 rpm the unit is already delivering 295 lb-ft (400 Nm).
Customers can choose between a seven-speed manual and a six-speed automatic with paddles. The manual offers rev matching on both downshifts and upshifts and also adapts to the gear you're shifting into, whichever one you choose. What's more, the engineers have not managed to make the cylinder deactivation work together with the manual gearbox.
The unit allows the C7 Corvette to complete the 0 to 60 mph (96 km/h) sprint in under 4 seconds. For the sake of comparison, we'll tell you that the C6 'Vette needed 4.2 seconds for the job.
Despite the increase in performance, the C7 is less thirsty, as it comes with a highway fuel efficiency of 26 mpg (9 liters per 100 km).
The body structure is 60 % stiffer and 99 lbs (45 kg) lighter compared to the C6's one, thanks to solutions like aluminum construction for the chassis, as well as the use of carbon fiber for the hood and removable roof panel. As for the distribution of the weight, the new Corvette offers the ideal 50/50 setup.
The Corvette now uses an electric power steering system and to make sure that it offers the right feel, engineers have increased the stiffness of the system by an incredible 500 percent.
The car incorporates a Drive Mode Selector which allows one to choose one of the five settings available: weather, eco, tour, sport, track. This controls the magnetic ride control suspension, valve-fitted exhaust, throttle pedal map, ECU map, steering assistance, active fuel management, as well as the way in which the stability and traction control act.
There's also a Z51 Performance Package, which comes fully loaded with an electronically-controlled limited slip diff, a dry sump system, custom gear ratios, larger brakes, as well as Bilstein dampers that use magnetic ride control and extra coolers for the diff, transmission and brakes. On the skidpad, this achieves up to 1 G of lateral acceleration, a value that places it in the same league as the C6 Corvette Grand Sport.
The Corvette Stingray rides on new 18x8.5-inch front and 19x10-inch rear wheels, and if you go for the aforementioned Z51 Performance Package you'll get 19 x 8.5-inch front and 20 x 10-inch rear forged aluminum wheels.
The 2014 Chevrolet Corvette C7 is scheduled to land is US showrooms in the third quarter of the current year, but the pricing hasn't been announced yet.
http://www.autoevolution.com/news/2014-chevrolet-corvette-c7-stingray-debuts-in-detroit-photo-gallery-53861.html
Одг: Corvette C7
« Одговори #91 на: 14 Јануари 2013, 09:51:04 am »
Не ми се свиѓа воланот... Али и тоа би и’ простил ;)
Ми се свиѓа што се мењаат брзини фино-лепо со рачка, а не со палки на волан :)
mislam deka amerikancite nikogas nema da go napustat stickot. zadnicata seuste mi e ruzna.
  • Пораки: 30816
Одг: Corvette C7
« Одговори #92 на: 14 Јануари 2013, 09:59:24 am »
Bravo za brzata reakcija!
Благодарам. :)
Текстот е спремен уште од промоцијата, ама немаше поента да го објавуваме во 2 наутро.
Одг: Corvette C7
« Одговори #93 на: 14 Јануари 2013, 10:02:37 am »
abe trebalo, kolku pobrzo tolku poprofesionalno. jas si legnav pred 1, pa ste me prevarile :)
  • Пораки: 30816
Одг: Corvette C7
« Одговори #94 на: 14 Јануари 2013, 10:06:41 am »
Нема никој да го прочита во 2 наутро. Ние сме ориентирани кон Македонската публика, а најголем процент од Македонската публика во 2 наутро спие. :)
2014 Chevrolet Corvette: The Stingray Goes High Tech
« Одговори #95 на: 14 Јануари 2013, 10:26:43 am »
Materials have been significantly upgraded over the previous Corvette, which basically required an upgrade to the optional leather package to be adequate. Now, the standard package is much more detailed, and build quality is noticeably improved--leather-wrapped surfaces and high-quality plastics abound.
more..
Одг: Corvette C7
« Одговори #96 на: 14 Јануари 2013, 10:34:17 am »
Additionally, that new seven-speed manual comes with Active Rev Matching, which is a system that anticipates gear selections and automatically rev matches engine speeds for the most optimal shifts.
Overview:
Model:   2014 Chevrolet Corvette Stingray
Body styles / driveline:   2-door hatchback coupe with removable roof panel; rear-wheel drive
Construction:   composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
Manufacturing location:   Bowling Green, Ky.
Engine:
LT1 6.2L V-8
Displacement (cu in / cc):   376 / 6162
Bore & stroke (in / mm):   4.06 x 3.62 / 103.25 x 92
Block material:   cast aluminum
Cylinder head material:   cast aluminum
Valvetrain:   overhead valve, two valves per cylinder
Fuel delivery:   direct injection
Compression ratio:   11.5:1
Horsepower / kW:   450 / 335 (est.)
Torque (lb-ft / Nm):   450 / 610 (est.)
Transmissions
Type:   seven-speed manual with Active Rev Match   six-speed paddle-shift automatic
Chassis/Suspension
Front:   short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite spring, monotube shock absorber
Rear:   short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite spring, monotube shock absorber
Active handling:   Magnetic Selective Ride Control (avail. with Z51)
Traction control:   StabiliTrak, electronic stability control
Brakes
Type:   front and rear power-assisted discs with four-piston fixed front and rear calipers (slotted rotors with Z51)
Rotor diameter (in / mm):   front: 12.6 / 320 (13.6 / 345 with Z51)
rear: 13.3 / 338
Wheels/Tires
Wheel size:   front: 18-inch x 8.5-inch (Stingray)
front: 19-inch x 8.5-inch (with Z51)
rear: 19-inch x 10-inch (Stingray)
rear: 20-inch x 10-inch (with Z51)
Tires:   Michelin Pilot Super Sport run-flat
front: P245/40R18 (Stingray)
front: P245/35R19(with Z51)
rear: P285/35R19 (Stingray)
rear: P285/30R20(with Z51)
Dimensions
Exterior
Wheelbase (in / mm):   106.7 / 2710
Overall length (in / mm):   177 / 4495
Overall width (in / mm):   73.9 / 1877
Overall height (in / mm):   48.6 / 1235
Weight distribution
(% front / rear):   50 / 50
More...
Одг: Corvette C7
« Одговори #97 на: 14 Јануари 2013, 10:40:15 am »
Under the hood is a new LT1 6.2 litre “Small Block” V8 with 450 hp and 610 Nm. GM points out that the LT1 makes 68 Nm more low-end torque than the previous 6.2 V8, matching the 7.0 litre LS7 engine from the 2013 Corvette Z06 from 1,000 to 4,000 rpm. Power-to-weight ratio is better than the Porsche 911 Carrera and Audi R8, GM says.
The LT1′s performance comes from combining tech like direct injection, Active Fuel Management and continuously variable valve timing with an advanced combustion system. It’s backed by a choice of active exhaust systems that are less restrictive than the previous gen, due in part to an increase in diameter from 2.5 to 2.75 inches.
The standard system offers a 13% improvement in airflow and features a pair of butterfly valves that contribute to improved refinement at cruising speeds when the engine is operating in fuel-saving four-cylinder mode.
The V8 is mated to either a six-speed paddle-shift automatic or a Tremec TR6070 seven-speed manual with Active Rev Matching for upshifts and downshifts. The latter comes with a new dual-mass flywheel and dual-disc clutch.
Stopping duties are courtesy of standard Brembo brakes with four-piston fixed calipers, holding 320 mm front and 338 mm rear rotors. They have 35% more swept area than previous-gen brakes and stopping distance is improved 9%.
A Z51 Performance Package includes specific close-ratio gearing and an electronic limited-slip differential (eLSD), along with 45 mm piston Bilstein dampers (35 mm Bilsteins stock) and Magnetic Ride Control. It makes the Stingray capable of 1g in cornering acceleration. This track-oriented package also adds brake-cooling ducts, a unique rear spoiler and additional air deflectors.
http://paultan.org/2013/01/14/all-new-2014-chevrolet-corvette-c7-stingray-revealed/
  • Пораки: 30816
Одг: Corvette C7
« Одговори #98 на: 14 Јануари 2013, 10:41:48 am »
Ќе го препишеш секој текст?
Одг: Corvette C7
« Одговори #99 на: 14 Јануари 2013, 10:45:03 am »
Еее, ќе снесе јајце сега. ;D
Одг: Corvette C7
« Одговори #100 на: 14 Јануари 2013, 10:45:29 am »
ne, gi selektiram samo dobrite tekstovi kade sto ima novi informacii.
Ova e kolata sto ke ja imam nekoj den :)
Одг: Corvette C7
« Одговори #101 на: 14 Јануари 2013, 11:18:23 am »
 "Where is America's real, two-seat sports car like the ones the Europeans make?"
Early sales made it seem, though, that not many outside GM were asking that question.
"You can see why GM was doing some soul-searching" about whether Corvette was worth keeping, Warner says.
Forceful GM engineer Zora Arkus Duntov took over as Corvette chief engineer and the 1955 Vette got a V-8 to replace the six-cylinder. Duntov insisted on a four-speed manual transmission, to replace the two-speed Powerglide automatic. And he pushed for, and got, fuel injection starting in 1957, replacing the industry-standard carburetors. Fuel injection can deliver more power on less fuel but back then it was a costly and exotic system.
By the mid-1970s, in Schorr's view, the car "started getting soft; bigger, heavier, emasculated." Some of the small pickups of the time, with stick shifts, were more fun to drive, he says.
Chevy's Corvette history acknowledges that the C3, built from 1968 - 1982, was battered by "an upheavel in the auto industry." At the start of its run, C3 had a big-block V-8 rated 435 horsepower. By 1975, it was a pale shadow, featuring a small-block V-8 rated a paltry 165 hp, about 20% less that the Duntov's original 195-hp small-block V-8 in 1955.
more
Stingray
« Одговори #102 на: 14 Јануари 2013, 11:25:56 am »
At the same time, we have the return of a legendary name. The base 2014 model will be known as the Corvette Stingray-one word, as used from 1969 to 1977. The revival of that once-potent badge will have people asking, "Why now?" but Chevy is looking to double Corvette sales in coming years. GM's marketing-driven response is likely to be, "Why not?"
more
  • Пораки: 22378
Одг: Corvette C7
« Одговори #103 на: 14 Јануари 2013, 11:30:03 am »
May You, new C7 Corvette, continue GM`s tradition of wiping the floor with the competition on racing circuits and streets, as your legendary predecessors did in the past.
For thine is the torque, the power and the reliability.
Amen.
Одг: Corvette C7
« Одговори #104 на: 14 Јануари 2013, 11:31:16 am »
Amen!
