Автор Тема: Corvette C7  (Прочитано 129605 пати)
  • Пораки: 55367
Одг: Corvette C7
« Одговори #45 на: 24 Октомври 2012, 09:07:20 am »
Да, да тоа е така. Сепак 130кг олеснување не е воопшто малку, за стандарден модел. Може нема да е толку на крајот, ама и 100кг е голем чекор во правата насока. НЕ се сомневам дека тоа ќе резултира со драстично подобрени времиња.
  • Пораки: 45338
Одг: Corvette C7
« Одговори #46 на: 24 Октомври 2012, 10:37:36 am »
Еве фришки вести:
YUP! Кабриолетче паралелно со купето ;) Сепак, ружниот ауспух очигледно оди во продукција :(
http://wot.motortrend.com/spied-2014-chevrolet-corvette-convertible-spotted-testing-with-porsche-911-280227.html
2014 Chevrolet Corvette C7 to pack at least 450hp, 27mpg with new LT1 V8
« Одговори #47 на: 26 Октомври 2012, 10:11:51 am »
Yesterday we brought you the news that General Motors had unveiled the new LT1 small block V8 that will serve as the powerplant of the upcoming “C7” 2014 Chevrolet Corvette and today, we take a look at the specifics of that new engine – beginning with the fact that the C7 Corvette will offer at least 450 horsepower and 27 miles per gallon.
We have known for some time that the seventh generation (C7) Chevrolet Corvette would feature an all new V8 engine when it arrives for the 2014 model year but rumors suggested that the new Corvette engine would be smaller in displacement (5.5 liters) possibly with forced induction (twin turbocharging). However, the new LT1 V8 sports the same 6.2 liters as the 2013 Chevrolet Corvette base engine while making more power and achieving better fuel economy than the current LS3 V8.
The new LT1 V8 engine that will power the 2014 Chevrolet Corvette ushers in the 5th generation of the fabled GM small block and with this new engine lineup comes more technology than has ever been utilized on a GM V8 – which GM claims will help the C7 Corvette offer at least 450 horsepower, 450lb-ft of torque and 27 miles per gallon. For comparison, the base 2013 Corvette (C6) offers 430 horsepower and 424lb-ft of torque while reaching 26 miles per gallon so the 2014 Corvette will pack so the next generation Corvette and LT1 V8 engine will make about 5% more power while also being more fuel friendly. Granted, these figures for the new 2014 Corvette engine are preliminary and actual production numbers could vary but we can fully expect that the C7 Corvette will have more horsepower, more torque and better fuel economy than the C6 Corvette.
General Motors has stated that the “entry level” 2014 Chevrolet Corvette will dash from 0-60 in under 4 seconds. That is incredibly impressive considering that the 505 horsepower Corvette Z06 (C6) moves out from nil to 60 in 3.8 seconds.
The rumors surrounding the 2014 Chevrolet Corvette V8 engine suggested that GM would go to a smaller 5.5L engine with twin turbocharging to help allow the C7 Corvette offer better fuel economy. This would allow the Corvette to have less negative impact on the automaker’s overall fleet fuel economy figures that will have to meet the government’s strict CAFÉ laws. Instead, the new LT1 V8 engine features a larger 6.2 liters of displacement fitted with plenty of high tech engine controls to improve the fuel economy of this powerful engine.
“Our objective for the development of the all-new LT1 was to raise the bar for performance car engines,” said Mary Barra, senior vice president, global product development. “We feel that we have achieved that by delivering a true technological masterpiece that seamlessly integrates a suite of advanced technologies that can only be found on a handful of engines in the world. What makes this engine truly special is the advanced combustion system that extracts the full potential of these technologies. The art and science behind that combustion system make the Corvette LT1 one of the most advanced V-8 engines in the world,” said Barra.
The 2014 Chevrolet Corvette’s high tech combustion setup
The new LT1 V8 engine powering the 2014 Chevrolet Corvette begins with a new direct injection system, variable valve timing and General Motors’ active fuel management system. GM spent a whopping 10 million hours of analysis on this new engine program with 6 million of those hours being devoted to the high performance, fuel friendly combustion system. While this might be a high performance engine fitted in one of the most well known performance cars in American motoring history, the millions of hours of planning helped to make the LT1 V8 more powerful without compromising efficiency thanks to features that were previously reserved strictly for improved fuel economy.
“The Corvette LT1 represents the most significant redesign in the Small Block’s nearly 60-year history – building on its legacy to make one of the world’s best engines even better,” said Sam Winegarden, vice president, Global Powertrain Engineering. “More than just great horsepower, the LT1 has been optimized to produce a broader power band. Below 4,000 rpm, the torque of the Corvette LT1 is comparable to that of the legendary, 7.0L LS7 out of the current Corvette Z06. The LT1 is a sweetheart of a power plant and drivers will feel its tremendous torque and power at every notch on the tachometer.”
The 2014 Chevrolet Corvette LT1 V8 is a “pushrod engine”, meaning that the camshaft is located in the engine block rather than in the cylinder heads like Ford’s dual overhead camshaft V8 engines – similar to past GM small blocks – but that is where similarities between the LT1 and LS3 engines end. The direct injection system is the most significant addition to the new engine lineup, allowing the engine to use the fuel more efficiently while also helping to keep the new engine cool. The LT1 has a smaller combustion chamber and sculpted pistons that present a surprisingly high compression ratio of 11.5 to 1. High compression creates more heat but the direct injection system helps to subdue that heat – with this system also helping to cut engine emissions by roughly 25%. The new variable valve timing system helps to further optimize the engine output while decreasing emissions while the Active Fuel Management system allows this high performance engine to shut down 4-cylinder during light load driving.
In addition to the smaller combustion chambers, the 2014 Chevrolet Corvette LT1 V8 cylinder heads have reversed intake and exhaust valve positions along with spark plugs that reach further into the combustion area. Having the plugs further into the combustion chamber places the electrode (and the spark that ignites the fuel) in the middle of the combustion area rather than in the outer edges of it – furthering the efficiency of the new C7 Corvette engine.
The LT1 V8 is all-new from top to bottom
Aside from the advanced fuel delivery and combustion system, the 2014 Chevrolet Corvette V8 engine is equipped with items to make it more powerful and more efficient – along with some features working to keep the weight as low as possible. It should be noted that the LT1 is actually heavier than the current LS3 due to the addition of the things like the direct injection system but GM has made up for that extra weight in other areas.
First, the Gen 5 GM small block features an all aluminum engine block and oil pan design that helps reduce weight without compromising strength with the help of six-bolt cross bolted main bearing caps. Iron bearing caps help to further increase the strength of the 2014 Corvette engine while also helping to reduce engine noise.
Helping to improve the durability of the 2014 Corvette engine is an advanced dry sump oiling system complete with piston cooling oil sprayers. This system is driven by a new variable displacement oil pump that can adjust to the driving conditions for optimal engine oiling under both calm and high performance driving. The piston cooling system sprays the underside of each piston and the cylinder walls which reduces friction and cools the combustion chambers but this system is only active during startup and while the engine is under heavy load. The dry sump oiling system prevents the oil from sloshing around during hard acceleration or cornering for optimal lubrication under any condition.
A new tri-lobe camshaft has been fitted into the new 6.2L LT1 V8, which allows the 2014 Corvette camshaft to control both the intake and exhaust valves along with the new high pressure fuel pump of the direct injection system. The camshaft of the LT1 has an .551 intake lift, a .524 exhaust lift, a 200 degree intake duration, a 207 degree exhaust duration and a 116.5 degree love separation.
The LT1 that will power the 2014 Chevrolet Corvette will be topped by a set of unique valve covers that do way more than just cover the valve stems. These valve covers house a new integrated PCV ventilation system and the coil on plug ignition system while also having three times the oil to air separation of the LS3 thanks to built in baffles between each coil pack.
Finally, the 2014 Corvette LT1 engine features a new intake manifold with integrated runners mated to an 87mm throttle body while four to one exhaust manifolds help to move exhaust gases away from the combustion chambers much like an aftermarket “header” setup would.
In closing, I should point out that the specifications of the 2014 Chevrolet Corvette “base” LT1 V8 are not official right now so production figures could vary. However, now that GM has put the figures of “at least” 450hp, 450tq and 27 miles per gallon – we can expect that the C7 Corvette that we meet next January in Detroit will offer at least those numbers. By the way, when you consider the fact that GM expects that the C7 Corvette in base form will be as fast from 0-60 as the current Z06 – it is clear that GM has done way more with the next generation of the fabled Corvette than just dress up the outside and add a new engine.
Also helping efficiency is a lighter aluminum block. Chevy says the LT1 is 40 pounds lighter than “a competitor’s twin-turbo 4.4-liter, DOHC V8 with similar output,” probably a reference to the engine BMW uses in the 5 Series, M5, and other models.
The lighter block should also give the C7 an ideal 50/50 front/rear weight distribution, and an improved power-to-weight ratio.
The 2014 LT1 is actually the third engine to bear that alphanumeric name; two previous versions were released in 1970 and 1992. The new LT1 will be built at GM’s Tonawanda, New York engine plant, while the rest of the Corvette will continue to be built in Bowling Green, Kentucky.
The video below offers us all our first example of what the 2014 Chevrolet Corvette will sound like – or at least what the new GM Gen 5 LT1 V8 sounds like on an engine dyno. We can expect plenty more information from The General over the next two months as the world eagerly awaits the January 13th 2013 debut of the C7 Corvette.
http://www.torquenews.com/106/2014-chevrolet-corvette-c7-pack-least-450hp-27mpg-new-lt1-v8
Inside The V8 LT1 Engine In The 2014 Chevrolet C7 Corvette
« Одговори #48 на: 31 Октомври 2012, 08:31:39 am »
Besides the fact that it would debut in Detroit this January, we really didn’t know much about the upcoming 2014 Chevrolet C7 Corvette. Would they head in a new direction with a more fuel-efficient turbo V6 engine? Would it be mid-engined? Would it fly or swim underwater or run on rainbows and smiles?
Forget all that. Chevrolet has released tons of information about the all-new 6.2-liter V8 engine that will power the C7 Corvette, and there is plenty to discern about both the powerplant and the entire car as a whole. Let’s dive right in.
Chevrolet says that the 6.2L V8, codenamed the LT1, will boast an astounding 450 horsepower and 450 lb.-ft of torque in the standard Corvette. That’s a lot of muscle for a base trim, and it makes us wonder what the Z06 and ZR1 versions will look like… but let’s stay on topic. Those numbers may change slightly once the car comes to production, but Chevrolet also expects a 0-60 mph time under four seconds and at least 26 mpg on the highway, which would be the best fuel efficiency rating for any Corvette ever. The new C7 is not messing around.
Chevrolet is well aware of what they’ve accomplished with the LT1 V8 engine, and are even taking shots at their competitors. The press release says that the LT1 is about 40 lbs. lighter than a competitor’s twin-turbo 4.4L V8, which is clearly talking about the 560-horsepower monster in the BMW M5. It’s also four inches shorter, from top to bottom, than that engine, which reveals an interesting caveat about the C7 Corvette as a whole.
Chevrolet says the shorter engine allowed them to drop it for a lower center of gravity, and also allowed them to create a lower hoodline. Corvettes have always been low cars, so expect the C7 Corvette to continue that trend with a small profile that stays stuck to the ground. Combine that with the hints we got when Chevrolet revealed the new logo last week, and you can almost envision a smaller, nimbler, sharper design to the 2014 C7 Corvette.
In many ways, the LT1 is a revolutionary engine for General Motors. It is the first of the new generation of Gen 5 small blocks, plus the first Corvette engine to ever feature direct injection and active fuel management (AFM). Also armed with continuously variable valve timing (CVVT), GM selected all three of those technologies to achieve their ultimate goal: improve combustion for better performance and efficiency.
The result is pretty impressive. Direct injection creates a cooler combustion chamber, and the CVVT is tuned to support it even further, which makes it possible to boost the compression ratio all the way to 11:5.1 and cut hydrocarbon emissions by 25%. Under light driving, the AFM will shut down four of the eight cylinders to save fuel, and they will kick back up the second you find the gas pedal.
Inside, there are all kinds of technological goodies. The intake ports are shaped with a slight twist, so when the sculpted pistons run through them it enhances mixture motion. The spark plugs protrude farther into the chamber, putting the electrode closer to the center of combustion for quicker response. The oil pan and cylinder block are all-aluminum to save weight, the intake manifold uses “runners in a box” like the Mustang Boss 302, and a four-in-one exhaust manifold provides more direct power like the Mazda SKYACTIV-G. Best Corvette engine ever? Shoot, this might be the most advanced engine on the market right now.
Quicker, lighter, faster and more efficient. In a time where automakers are switching to small turbo engines to combine power and efficiency, Chevrolet accomplished exactly what they wanted with a whopping 6.2L V8 – in the process, the LT1 engine establishes a new precedent for General Motors and sports cars everywhere. This is an exciting time for the auto industry; when you can make engines that are not just slight improvements in some areas but significantly better in every single aspect. We can’t wait to see what the total package looks like, and what this means for the future.
http://www.youtube.com/watch?feature=player_embedded&v=owOp9PWjQY0
Corvette C7 Teaser
« Одговори #49 на: 02 Ноември 2012, 09:22:52 am »
2014 Corvette Trailer 1: CONCEPTION
« Одговори #50 на: 16 Ноември 2012, 13:50:59 pm »
Not a valid youtube URL
  • Пораки: 20911
Одг: Corvette C7
« Одговори #51 на: 16 Ноември 2012, 13:55:16 pm »
Зашо „2014“??
Одг: Corvette C7
« Одговори #52 на: 16 Ноември 2012, 13:58:23 pm »
Planirano e da izleze 2013ta, sto vo Amerika se oznacuva kako model 2014
  • Пораки: 20911
Одг: Corvette C7
« Одговори #53 на: 16 Ноември 2012, 13:59:27 pm »
  • Пораки: 22455
Одг: Corvette C7
« Одговори #54 на: 16 Ноември 2012, 14:28:27 pm »
Istoto i jas go prasuvav za Nisan GTR.
  • Пораки: 20911
Одг: Corvette C7
« Одговори #55 на: 16 Ноември 2012, 14:37:23 pm »
:D :D :D :D :D :D :D
GM Talks More About the 2014 Corvette C7's Design and New 6.2-liter Small Block
« Одговори #56 на: 24 Ноември 2012, 00:18:47 am »
It's going to be a painfully long wait for Corvette and car enthusiasts alike until Chevrolet pulls the covers off the seventh generation of America's most famous sports car series on Sunday, January 13, 2013.
GM is making sure we don’t forget about it with a steady release of bits and pieces of information and imagery that continues today with some details about the C7's aerodynamic properties and the new Gen 5 small block V8 that will power the base models.
Beginning with the design, GM's people state that the every line, detail and surface on the 2014 model has been "optimized for performance".
Tadge Juechter, Corvette chief engineer, elaborates:
“The all-new Corvette integrates more high-performance aerodynamic features than ever before, many taken directly from Corvette Racing,” he said. “For example, the front grill and radiator flow paths reduce lift, improving vehicle stability at high speeds by keeping the car pressed to the pavement. In addition, functional vents increase track capability by channeling air to the brakes, as well as heat exchangers for the transmission and differential.”
Kirk Bennion, Corvette exterior design manager supports the same adding that the C7 will be exciting to look at as well:
“Its sculpted design excites in all the ways that a Corvette has for six decades, with elements carefully shaped in the wind tunnel to increase airflow potential and improve cooling for a system that is as efficient as possible,” stated Bennion. “It’s said that form follows function, but in the case of the aerodynamic 2014 Corvette, form and function work cohesively to produce beautiful purpose.”
Besides the news on the 2014 Corvette's styling, GM also dropped a new video from the presentation of the new 6.2-liter V8 engine.
Dubbed 'LT1', the Gen 5 unit churns out 450HP and 450 lb-ft (610 Nm) allowing the base coupe version of the C7 to hit 60mph (96km/h) in under 4 seconds, with the automaker also stating that it will return more than 26mpg on the highway.
http://carscoop.blogspot.com/2012/11/gm-talks-more-about-2014-corvette-c7.html
  • Пораки: 16810
Одг: Corvette C7
« Одговори #57 на: 09 Јануари 2013, 23:27:22 pm »
Еве го финалниот изглед на C7
« Последно менување: 10 Јануари 2013, 07:55:59 am zeroSignal »
Одг: Corvette C7
« Одговори #58 на: 09 Јануари 2013, 23:30:09 pm »
Претерано ми личи на гтр во некои делови, а богами и на вајперот нов...
  • Пораки: 22455
Одг: Corvette C7
« Одговори #59 на: 10 Јануари 2013, 00:12:27 am »
..na prvata slika pogotovo...;D
