Автор Тема: Каков е принципот на работа на ECU  (Прочитано 4321 пати)
« на: 24 Јуни 2012, 01:00:01 am »
The ECU "learns" about your engine as you drive the car. The "learning" is actually a process that the ECU uses to track the tolerance changes of the sensors and actuators on the engine. Two examples of these values are the position of the idle-air bypass valve (automatic choke) at idle with the A/C on, and the trim gain on the injectors. The ECU stores these "learned" values in battery backed-up RAM so that it doesn't have to start from scratch the next time you turn your engine over.
"Resetting the ECU" is the process of clearing all the long term memory from the ECU's memory. These variables trim idle speed, fuel, spark, and more. The ECU will also store trouble codes for diagnostic capability. By resetting the ECU, the trim values will be set to some neutral default value and all of the trouble codes will be cleared.
How-To
To "reset" the ECU, all you have to do is remove the source of backup power. To keep the memory alive while the car is off, the ECU has a direct line, through a fuse, that goes right to the battery. This is usually the same line and fuse that supplies backup power to your radio so it doesn't forget all of its settings. Your ECU has now lost all of its long term memory values and will "reset" them all to defaults when it next powers on. By the way, the factory radio's memory lasts for a minute or two, so you probably will not lose your saved stations.
Myth
There is quite a bit of mythology revolving around resetting the ECU. Many people mistakenly believe that they need to reset the ECU after installing major engine modifications. Others believe resetting will resolve engine problems. Neither are correct.
Reality
The ECU is always tracking the engine's sensors and actuators. Resetting the ECU does not cause the ECU to learn engine changes any faster. The ECU is always tracking the gradual changes in the engine sensors and actuators. The ECU never gets satisfied with a setting, and is always upБлокирано the trim values. It will discover whatever change you made to your engine and make the appropriate changes. In fact, unplugging the ECU will most likely increase the learning curve of the new part.
There are only two reasons why you would want to reset your ECU. One is to clear a CHECK ENGINE light or error code after fixing the problem that caused the error. The other is to reset the spark advance trim value. The advance trim controls how much the timing is retarded from what the factory engineers considered optimum. This particular trim value is the only one the ECU "resets" to a non-neutral MAX value. If you are driving on low grade gas, the pinging picked up by the knock sensor causes this trim value to be lowered, and your timing to be retarded. If you go to the track and put good gas in the tank, you might not want to wait for the ECU to learn about the new gas and advance the timing. So resetting the ECU in this case makes sense. However, in the process, you will lose your idle and fuel trims (probably not too important for drag racing, though).
Questions
Won't clearing the trouble codes make the car run better? If the ECU notices a problem with a sensor, it will flag a code and possibly turn on the CHECK ENGINE light. Should the problem go away, the ECU will turn off the light and start using the sensor as normal once again. The code will be stored inside for later diagnostic retrieval. But that code being stored does not affect the ECU operation in any way.
I reset the ECU, and now the car runs rough! Why? The engine may run rough or idle poorly right after ECU reset. The ECU now has default numbers in its trim memory - it has to adjust them to match the tune of your engine and its sensors and actuators. It might take a day or two of driving in traffic before the engine will settle down again. Now you know why the ECU remembers these values in the first place!
tundrasolutions.com
Одг: Каков е принципот на работа на ECU
« Одговори #1 на: 24 Јуни 2012, 15:06:26 pm »
"Something is causing a large power gain when I reset the ECU. I know you shouldn't drive the car hard right after an ECU reset, and I normally wouldn't, but this was for the sake of testing exactly what the results of doing this would be. Alot of people install parts and reset the ECU and then revel in the huge power gain. I had a thought that it might be (in part) due to the ECU itself, and not the new part.
I was operating the dyno myself, it's a brand new Dynocom DC1800SZ inertial dyno. It's very repeatable between runs and has built in weather correction.
I brought the car in after a 15 minute drive, strapped it down, set the fans up (one large high volume one in front, one high speed/medium volume strapped right to the TMIC, hood up). Did 3 runs to stabilize temps, with 10 minutes between runs. Did a baseline run, cleared the ECM by disconnecting the battery for a few minutes, then did another run. All runs were 10 mins apart. Power was nearly identical, within 3 whp on the first 4 runs. It improved a bit from the first run to the 4th run due to the ecu "learning" the load of the dyno. The ECU reset run was drastically different. The power curve both changed shape and had a drastically different peak power. The car also sounded deeper and more powerful, and the run took less time than the first run.
Here's the dyno chart of the 4th and 5th runs. I didn't include the warm up runs because they are irrelevant.
The red run is the ECU reset run."
mazdas247.com
  • Пораки: 6219
« Одговори #2 на: 24 Јуни 2012, 16:49:57 pm »
А бе ај што постираш информации, ама барем да се потрудеше да ги преведеш...
Еве јас на пример не разбирам полски, и сеа како да знам што си прекопирал од интермец...
Дај бар на некој наш близок јазик преведи ако више не можеш македонски...
« Одговори #3 на: 24 Јуни 2012, 16:56:23 pm »
Јебига ме мрзи да преведувам, а нашиве интелектуалци нешто слабо пишуваат на овие теми... Кој има мака ќе се потруди бар  да го копира и пејстне на гугл транслејт ;) btw децава само теми за цициња и рекла казала ги интересира :) Ако некој фосил не започне тема од технички карактер, форумов ќе треба да се прекрсти у Палавковци :D
  • Пораки: 6219
« Одговори #4 на: 24 Јуни 2012, 16:57:08 pm »
Кој ке биде Фарина?
:D :D :D :D :D :D
Одг: Re: Каков е принципот на работа на ECU
« Одговори #5 на: 24 Јуни 2012, 19:34:36 pm »
Sportex..... on najmal e...
« Одговори #6 на: 24 Јуни 2012, 21:39:56 pm »
скоро 10кс добил со ресетирање на ECU
« Одговори #7 на: 24 Јуни 2012, 21:49:42 pm »
Kaj секоја кола различно се манифестира. ECU учи и направил „грешка“ па излегол од границите на оптималното у моментот, кога сфатил дека не треба така, компараторот ги дискриминирал одредени параметри и на следното Дино (после еден месец) дал „само“ 5 коња повеќе. Како и да е, зависи од стилот на возење и дефинитивно ECU треба да се ресетира после секоја модификација или купување на половна кола. Генерално у почетокот дава послаби перформанси пошто работи под dеfault, а податоците кои му се битни ги чува у non-volatile memory, па така не е ништо страшно истиот повремено да се ресетира. Throttle body position и spark advance trim value влијаат на throttle response, ако не друго чувството е друго, а и потрошувачката нели :)
Отсутен mmm121
  • Пораки: 3799
« Одговори #8 на: 24 Јуни 2012, 22:03:02 pm »
A kako  se resetira ECU?
« Одговори #9 на: 24 Јуни 2012, 22:22:42 pm »
Има три начина. Едниот е да ја извадиш минус клемата од акумулаторот и да ја споиш со плусот, вториот да го извадиш осигурачот за напојување на ECU (у овој случај не мораш да го преподесуваш радиото, прозорите, саат, дата...) и со ELM327 или сличен уред за бришење на грешки.
Ако ги вадиш само клемите од акумулаторот, свирни на свирката, притисни и држи ја кочницата или слично за да се испразни кондензаторот од ECU.
Отсутен proff
  • Пораки: 1441
  • no comment at the moment
« Одговори #10 на: 14 Мај 2014, 23:23:13 pm »
Ресетирање на ECU на Аstra G и забрзување на времето за "учење" на ECU-то
Just a little trick that has been shown to accelerate the factory ECU's ignition timing learning process.
Background: There is something called "Ignition Advance Multiplier". It represents, by some complicated algorithm, the average learned positive knock correction applied to the ignition maps. It's represented in 1/8th degrees increments. 1 being the lowest and 16 being the highest (1/8 to 2 degrees in absolute terms).
The "happier" (knock free) the car is, the higher the number will be. Conversely, the lower it is, the more knock prone it is. This number, after ECU reset ore ECU swap defaults to 8 and usually creeps up to 16 (if well mapped) through normal driving. Depending on driving characteristics, this can happen within a few hours or a few weeks. Well, here's a way to make it happen in about 5 seconds  ....
First: With the car fully warmed up, reset the ECU. This can be done by killing power the ECU or by simply pulling off the neg. battery terminal and pressing the brake pedal for a couple of seconds.
Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower
« Одговори #11 на: 14 Мај 2014, 23:48:40 pm »
Хмм... ако стиснеш педал за гас и стиснеш кочница после тоа заедно со гаста, ќе отиде во fuel cut-off... Нели?
  • Пораки: 45230
« Одговори #12 на: 14 Мај 2014, 23:59:01 pm »
Не.
Отсутен proff
  • Пораки: 1441
« Одговори #13 на: 18 Мај 2014, 09:59:14 am »
Незнам кај оди но не функционира кажаното... Газиш на кочница и колата не прима гас.... Проверено и кај мене и кај ФилипМ... исто кај две различни возила :(
« Одговори #14 на: 18 Мај 2014, 21:46:41 pm »
Па тоа кажав де. Ако ти е стисната педалата за гас, па стиснеш и кочница во исто време тогаш го прекинува доводот на гориво и престанува да прима гас.
