Автор Тема: Матични, SSD, HDD, RAM, тајминзи и рандом IT ствари...  (Прочитано 1755208 пати)
  • Пораки: 20408
« Одговори #3405 на: 18 Јули 2013, 19:17:44 pm »
инаку ддр4 колку што имам читано дури во 2016/17 освен ако не се сменило нешто во последниве неколку месеци
Отсутен Vasil
  • Пораки: 3759
« Одговори #3406 на: 18 Јули 2013, 19:28:34 pm »
2014 ќе излезат првите процесори на Интел со поддршка за DDR4.
Leaked slides suggest that Intel‘s Haswell-E will ship in the back half of 2014, with support for the nascent DDR4 standard, 40 lanes of PCI-Express 3.0 connectivity (likely in an x16/x16/x8 configuration), and, in a first for Intel, up to octal-core CPUs.
The figures above are given in clock cycles, not nanoseconds, which means that there’s crossover at a certain point — 5 clock cycles at 3200MHz is less latency than four clock cycles at 2133MHz. At the same speed, however, DDR3 will have lower latency than DDR4. Keep in mind, the graph above shows the relationship between DDR3 and DDR4 without using LRDIMMs, which add their own 2-3 cycles of latency.
Since desktop workloads are far more sensitive to latency than bandwidth, DDR4 likely won’t offer much benefit here until clock speeds rise well above 2133MHz. That doesn’t make DDR4 a bad thing, most memory standards launch at rough parity with the product they replace, but it means users shouldn’t look to the new memory to provide an immediate performance boost over the old.
http://www.extremetech.com/computing/158824-haswell-e-to-offer-ddr4-support-up-to-eight-cores-in-2014
  • Пораки: 20408
« Одговори #3407 на: 18 Јули 2013, 19:45:13 pm »
подршка за ддр4 и пуштање во продажба на ддр4 матични и рам не е исто
Отсутен Vasil
  • Пораки: 3759
« Одговори #3408 на: 18 Јули 2013, 20:22:56 pm »
РAM-от е готов веќе долго време.
http://hothardware.com/News/Samsung-Waves-Around-Industrys-First-16GB-DDR4-Memory-Modules/
веста е од јули 2012-та
Samsung said it's sampling both 8GB and 16GB DDR4 memory modules, which it produces using a 30nm-class process technology. These aren't the first DDR4 modules, however, as Samsung unveiled 2GB DDR4 memory sticks way back in December 2010.
http://www.behardware.com/news/11425/hynix-produces-its-first-ddr4-modules.html
Се чека на процесорот и нормално нова генерација на матични што излегуваат заедно со секоја нова генерација на процесори.
Прво се учекува да излезат Haswell-E со DDR4 поддршка, ама тоа е во серверскиот сегмент. Првите процесори со DDR4 за широките маси се очекува да излезат 2014 или евентуално 2015. Кога би ги прашале Интел, би чекале до 2015, ама има притисок од многу страни да забрзаат.
  • Пораки: 34567
« Одговори #3409 на: 19 Јули 2013, 15:09:48 pm »
А кој е бенефитот од DDR4?
Отсутен Vasil
  • Пораки: 3759
« Одговори #3410 на: 19 Јули 2013, 15:41:00 pm »
Пониска потрошувачка на енергија (околу 40%), ќе бидат изработени со помодерни литографски техники и ќе се добие поголема густина, со што ќе бидат многу поевтини. Исто така ќе се зголеми брзината. Најбавните ќе бидат како најбрзите DDR3 модули, само со мало покачување на латенцијата.
Секој модул ќе биде во посебен канал, што ќе ја искомплицира изработката на матични и ова може на почеток да ги умрси малку работите.
од статијата на ExtremeTech:
Compared to DDR3, DDR4 offers lower power consumption and higher transfer rates. Unlike DDR3, it makes major changes to the internal RAM topology. Where DDR3 used a multi-drop bus that allowed multiple DIMMs to sit on the same memory channel, DDR4 virtually requires the use of a point-to-point bus with a maximum of one DIMM per RAM channel.
That would leave dual-channel systems limited to two DIMMs, with quad-channel systems limited to four. While that’s not an impossible solution, it would further inflate the cost of moving to DDR4, given that RAM manufacturers tend to charge premiums for both new RAM technologies and higher capacity DIMMs. It would also require SoC developers to build wider RAM interfaces if they wanted to address more than a single DRAM chip.
The solution may be to adopt load-reduced DIMMs, or LR-DIMMs. LR-DIMMs use an on-package buffer to re-drive the data signal to all attached chips. This significantly increases potential RAM density and reduces cost. Unfortunately, this type of configuration adds additional memory latency — and DDR4 latencies are already expected to be higher than their DDR3 counterparts.
  • Пораки: 20408
« Одговори #3411 на: 19 Јули 2013, 18:43:52 pm »
сепак латенцијата е побитна од брзината, а сите знаеме дека на почетокот ќе бидат 40% поскапи ддр4 од ддр3
Отсутен Boshe
  • Пораки: 5507
  • Пиши лаже
« Одговори #3412 на: 19 Јули 2013, 20:07:46 pm »
Исто размислувам и јас. :)
« Одговори #3413 на: 19 Јули 2013, 20:53:52 pm »
Игор, во Аугсбург се произведуваат само матични плочи, но само за сервери, компјутери и работни станици а не и лаптопи и тоа само за локалниот пазар бидејќи фабриката е многу мала.
Во Аугсбург само се склопуваат лаптопи и останат дел од consumer electronics. Но тоа не значи дека се произведени во Германија, туку само склопени.
http://www.slideshare.net/FujitsuTS/fujitsu-plant-5451511
Е сеа, пошто окружувањево е многу динамично ништо нема да е чудно да прешифтаат дел од производството на матични плочи и за лаптопи во Аугсбург, но генерално сега за сега не произведуваат лаптопи.
Не гледам како е поврзан постов со муабетот за гаранцијата на Dell. Или нешто пропуштив? :)
  • Пораки: 34567
« Одговори #3414 на: 19 Јули 2013, 21:29:25 pm »
Хахаха, абе не си прочитал :) Али нема везе. Темата беше дали лаптопите Fujitsu / Fujitsu-Siemens се навистина Made in Germany како што пишува нанив или не баш. Врска нема со гаранцијата на Dell ;D
« Одговори #3415 на: 19 Јули 2013, 21:31:45 pm »
Па не спомнав јас ништо за Fujitsu, јас Dell си имам. ;D
Отсутен Vasil
  • Пораки: 3759
« Одговори #3416 на: 19 Јули 2013, 22:17:18 pm »
Напротив. Се очекува да бидат многу поевтини. Исто како што DDR3 беше многу поевтина од DDR2 која беше многу поевтина од DDR која беше многу поевтина од SDR меморијата. Ова не е толку поврзано со DDR4 колку што е поврзано со напредокот на производниот процес што овозможува многу поголема густина на меморијата. Како што сега мејнстрим е 4GB, со DDR4 тоа ќе биде 8GB за иста, а можеби и помала цена.
Латенцијата нема многу да се зголеми, ете ви го графикот. Најбавната DDR4-ка ќе биде за нијанса полоша од најдобрата DDR3-ка, ама појаките модели ќе имаат повисока фреквенција и ќе надокнадат.
Да не го заборавиме и намалувањето на потрошувачката на енергија што е многу важно за преносните системи.
  • Пораки: 55357
« Одговори #3417 на: 19 Јули 2013, 23:05:22 pm »
Ddr4  naveduva i pobrzi magistrali, mozebi ne na pocetokot no ponatamu sigurno. I pred se poeftin RAM.
Отсутен Nakolce
  • Пораки: 2310
  • Имигрант
« Одговори #3418 на: 23 Јули 2013, 14:00:58 pm »
Имам еден проблем со HP mini 210 - 1011eg.
Со него доаѓа windows 7 starter налепница. Јас пред неколку месеци му ставив Xp бидејки кабелот за дијагностика во кола ми работи само со Xp.
Сега сакам пак да го вратам на windows 7 бидејки е со лиценца, и сакам да го носам накај европа кога ќе одам.. А таму законите за пиратерија се по строги од овде.
Е сега. По интернетов најдов многу врсти на седмици на германски јазик (лиценцата е на германски и добро ќе ми дојде и компјутерот да е на германски) има едно програмче од ултимејт верзија го двои на сите верзии на windows 7. и едноставно си инсталирам стартер.
НО имам еден проблем
Wi-fi имам првите 10 минути кога ќе го уклучам компјутерот. После тоа се гаси и никако неможам да го уклучам. Го рестартирам но пак неможам да го уклучам Wi-fi то.
Пробував со разни драјвери симнати од официјалната страна, пробував разни начини... Но едноставно несака да работи цело време.
Овој проблем со XP го немав. Сега ставив XP и се си е ок.
Повеќето на форумов работат со тоа. Па би ги замолил за совет.. Што да направам за да го оправам овој проблем ?
  • Пораки: 45292
« Одговори #3419 на: 23 Јули 2013, 14:12:34 pm »
Пробај го ова решение:
Update: I finally managed to get it working. Spent another few hours playing around with options on driver's advanced page. This is what I have now:
802.11n Preamble: Mixed Mode (this is a must if you are in mixed g/n network)
Afterburner: Disabled (not sure about this)
AP Compatibility Mode: Higher Performance (I have a standards-compliant router)
Bluetooth Collaboration: Disable (everything started working right after I disabled this one)
BT-AMP: Disabled (not sure about this)
Mixed Cell Support: Disabled (this is not needed for typical wifi networks)
XPress (TM) Technology: Disabled (not sure, this is something for g performance)
Исто така, прегледај го цел овој супорт  муабет, се однесува баш за проблемот што го опишуваш:
http://h30434.www3.hp.com/t5/Wireless-Internet-Home-Networking-e-g-Windows-8/HP-Mini-210-Windows-7-32bit-Broadcom-4313-wireless-fix-maybe/td-p/287836
