Автор Тема: Body Building, Fitness, P90X, MMA, Boxing i slicno...  (Прочитано 1022047 пати)
  • Пораки: 22430
« Одговори #3975 на: 16 Јуни 2015, 16:41:45 pm »
Ај успорете малку и двајцата.
Here are the pros and cons of free weight and machine training:
Free Weight Advantages
Less stable (less degrees of freedom) = more stability function (proprioception, balance, sensorimotor coordination, etc.)
Way more affordable
Portable and takes up less space
Have natural bar paths
Represent more natural movement patterns compared to many machines (ex: leg press, leg extension, leg curl) – they better replicate real life movement
More specific to powerlifting and Olympic weightlifting
Work well in concordance with bands and chains (accommoБлокирано resistance)
More versatile, provide for plenty of variation
Well suited for maximizing spinal strength and stability
Better suited for lower body ballistics (ex: jump squats)
Better suited for complex, highly integrated lifts
Barbell exercises can be more metabolically demanding
Seem to transfer better to machines compared to how machines transfer to free weight strength
Machine Advantages
More stable = more prime mover activation
Easier to learn (easier to stabilize) and more comfortable for certain lifters
Can use to groove unique motor patterns (ex: smith machine for more upright squat)
Fixed bar paths can prevent acute injury subsequent to lack of stabilization
Certain machines maintain more constant tension on the muscles by utilizing variable resistance (ex: CAMs, plate-loaded, etc.)
Can take spinal stability out of the equation to focus on the legs (ex: leg press, lying squat)
Can be performed after heavy barbell lifts when stabilizers are fatigued to further tax the prime movers
Better suited for targeted, more isolative lifts
Well suited for initial stage rehabiliation
Well suited for training the elderly
Well suited for training beginners who lack confidence in free weights
No spotters required
Are self-contained (no additional equipment required)
Isokinetic dynamometers are well suited for data collection and eccentric or isometric training
The smith machine can be used for ballistics (ex: bench throws)
Better suited for circuit training
Free Weight Disadvantages
Certain lifts are awkward for certain body types
Higher rates of acute injury
Some lifters learn to rely on excessive momentum
More correlated with sloppy form and contorting the body to accomplish a lift
Many lifts have torque-angle curves and strength curves that stress a particular ROM but lighten up at the opposite ROM (ex: squats, good mornings)
Certain lifts require spotters or rack supports
Not always well suited for rotary and lateral vector movements
Loading and unloading plates is cumbersome for strong lifters
Machine Disadvantages
Certain machines don’t feel comfortable for certain body types
Can have unnatural paths which can lead to pattern overload
Higher rates of chronic injury
Costlier to purchase and for maintenance
Not always portable and takes up more space
Less variety and versatility
Aren’t always well-suited for particularly tall or short lifters
Can lend themselves more to left/right imbalances
Often weight stacks don’t accommodate advanced individuals
But it All Depends on the Machine…
As I mentioned previously, it all depends on the machine. A lever squat and hammer strength squat-lunge machine are very similar to the barbell counterparts. I’ve tested the muscle activation in both and the lever variations actually produced higher activation in certain primary muscles.
Lever squat machine = машината за чучањ за која зборам јас.
Отсутен TheForce
  • Пораки: 546
« Одговори #3976 на: 16 Јуни 2015, 17:17:29 pm »
Да де, на истата вежбав и јас. Ти вежбаш повеќе горен дел, јас повеќе  долен, па затоа можам да кажам кај мене кое било поефективно. Од сите advantages кај машината може да се сумира дека е полесно да се вежба. Не реков дека е лоша машината, сум пробала и неколку варијанти како поинаку да ја искористиш  и супер е. Сепак со слободна шипка (не smith) имаш контрола и вежбање на core, quadri, hamstrings, gluteus па и грб. Е сеа коленцата страдаат, и да, можда понеправилно ќе ја правиш, но и ќе научиш како треба.
  • Пораки: 20408
« Одговори #3977 на: 16 Јуни 2015, 17:53:07 pm »
На машините со фиксни патеки на движење се губи многу битна ствар, не вежбаш стабилност никаква и е многу полошо да се вежба така. Мене колената најмалце ми страдаат на чучњеви, одма после вежбата осеќам колку е лоша за колена со оглед на тоа дека левото колено почнува да ми се укочува и трне, на чучњеви тоа не ми се случува додека на преса и оваа другава машина ми се случува. Слободните тежини далеку повеќе ги оптоваруваат мускулите отколку машините со фиксно движење.
  • Пораки: 55357
« Одговори #3978 на: 16 Јуни 2015, 17:56:42 pm »
На машините со фиксни патеки на движење...
...зголбовите (и особено рбетот) трпат несекојдневни напрегања во неприродни насоки, и лесно се  изместуваат и повредуваат.
Затоа и не треба да се користат за ниту една вежба во која се оптеретува р'бетот.
  • Пораки: 6641
« Одговори #3979 на: 16 Јуни 2015, 18:08:27 pm »
Не кажа, колку кила имаш дигнато најмногу?
  • Пораки: 55357
« Одговори #3980 на: 16 Јуни 2015, 18:12:22 pm »
3 х 117.5кг на чучњеви со слободна шипка, правилно со паралелни бутови и земја, во животов. Со помош на стронглифтс програмата http://forum.carclub.mk/index.php/topic,2762.msg134157.html#msg134157
Отсутен Filip_90
  • Пораки: 1839
  • VW Golf 5 1.9 TDI
« Одговори #3981 на: 16 Јуни 2015, 18:16:17 pm »
А има ли негде да се види каков треба да е односот на тежините за правилна градба на телото?
На пример еве јас 80 дигам на бенч па колку треба да дигам на вежбите за бицепс, трицепс, нозе,, рамо, грб...
Или на се дигаш колку можеш?
  • Пораки: 20408
« Одговори #3982 на: 16 Јуни 2015, 18:20:30 pm »
Дигаш колку можеш на се дур не станеш пропорционален, ако ти фали пропорција го вежбаш делот што е помал повеќе.
« Одговори #3983 на: 16 Јуни 2015, 20:52:24 pm »
znae nekoj so mesti izmesteni muskuli? kaj grbot kaj srceto em stega koga sum navalen na leva strana i koga zemam vozduh dlaboko.. Valja e muslul xD
  • Пораки: 22430
« Одговори #3984 на: 17 Јуни 2015, 09:28:46 am »
Еве што јас вежбав за стабилност, кор мускули и слично.. пред 3-4 години.
Сега во теретана не ме занима толку тоа, настојувам да вежбам со поголеми тежини  и пред се гледам да не се повредам, па цела година "труд" да отиде у вода....
Не сум ја 20 години, постаро аро сум. ;D
  • Пораки: 20901
« Одговори #3985 на: 17 Јуни 2015, 17:50:58 pm »
Зашто калории се многу потешки за горење отколку за внесување?
Отсутен Vasil
  • Пораки: 3759
« Одговори #3986 на: 17 Јуни 2015, 21:53:07 pm »
Зависи од човекот. На некој му е тешко да се здебели, на друг да ослебе.
  • Пораки: 55357
« Одговори #3987 на: 17 Јуни 2015, 21:55:14 pm »
Процентуално гледано тие на кои им е тешко да се здебелат се помалку од 1% и слободно може да се занемарат комплетно од равенката.
Зависи од термодинамика.
Отсутен Vasil
  • Пораки: 3759
« Одговори #3988 на: 17 Јуни 2015, 22:05:22 pm »
Убаво се чувствуваш кога си најаден, некогаш ти е тешко откако ќе се прејадеш, но додека се прејадуваш исто така ти е многу убаво, а и нелагодноста брзо поминува.
Не се чувствуваш убаво кога си гладен, вежбањето е напорно, а исто така е тешко да оддолееш на лапачка по напорен тренинг, кога си гладен и уморен и мислиш дека си заслужил убаво да се најадеш.
Внесување на повеќе калории одколку што ти е потребно не е напорно, ниту физички, ниту психички. Обратното е многу тешко и бара голема дисциплина и посветеност.
  • Пораки: 20901
« Одговори #3989 на: 17 Јуни 2015, 22:35:50 pm »
Абе фино све тоа, само што не ми беше тоа поентата (дека ти е убаво да јадеш, и дека треба дисциплина за да вежбаш).
Муабетот ми е, зашто еве рецимо, денеска по извозени ~12 км на тачак, за ~45 минути, Ендомондо ми вика дека сум поарчил ~530 калории, кои рака на срце, можам да ги вратам у рок од 5 мин. ако опнам чоколадо или нешо позамашно, а да не е благо.
