Автор Тема: Specialized Crosstrail  (Прочитано 2532 пати)
Отсутен MartinK_2
  • Пораки: 39
  • Сите реки водат накај море, сите улици кон дома...
« на: 04 Јуни 2018, 18:06:47 pm »
Specialized Crosstrail XL 2017
FRAME   Specialized A1 SL Premium Aluminum, Fitness Geometry, rack and Plug + Play fender mounts
FORK   SR Suntour NEX, aluminum V-brake lower, coil spring, hydraulic lock-out w/Multi-Circuit Damping, 60mm of travel
FRONT HUB   Specialized, loose ball bearings, 32h, 9mm QR
REAR HUB   Specialized, loose ball bearings, 8-/9-speed cassette body, 32h, 9mm QR
SPOKES   Stainless, 14g
RIMS   700c, 6061 aluminum double-wall
INNER TUBES   SPECIALIZED SV STANDARD BULK ROAD
FRONT TYRE   Trigger Sport Reflect, 700x38mm, 60TPI, wire bead
REAR TYRE   Trigger Sport Reflect, 700x38mm, 60TPI, wire bead
CRANKSET   Stout, forged alloy w/chainguard
CHAINRINGS   48/38/28T w/chainguard
BOTTOM BRACKET   BSA, square taper, cartridge bearings
SHIFT LEVERS   Shimano EF500, EZ Fire Plus, 8-speed
FRONT DERAILLEUR   Shimano Tourney, top swing, for 7-/8-speed 31.8mm clamp
REAR DERAILLEUR   Shimano Altus, 8-speed
CASSETTE   Sunrace, 8-speed, 11-34t
CHAIN   KMC X8, 8-speed w/reusable MissingLink
FRONT BRAKE   V-brake, alloy, linear pull
REAR BRAKE   V-brake, alloy, linear pull
HANDLEBARS   Specialized, double-butted alloy, 9-degree backsweep, 31.8mm
GRIPS   Body Geometry Flow Set Control Grips, lock-on
STEM   3D forged aluminum, 7-degree rise, 31.8mm clamp
SADDLE   Canopy Sport, steel rails
SEATPOST   Alloy, 2-bolt, 12.5mm offset, 27.2mm
SEAT BINDER   Alloy, 2-bolt, 12.5mm offset, 27.2mm
PEDALS   Specialized Fitness Platform
XL големина за 185-197 цм.
Возен 200 км.
Купен од Проспорт - Скопје (30.500 ден.) со важечка гаранција и документи.
Опрема:
Ѕвоно (150 ден.),
Задно светло Topeak Redlite II (650 ден.) , Topeak modular cage држач за бидон (600 ден.) и SIGMA BC 16.16 километража (2.150 ден.) или вкупно 3.550 ден.
30.500 + 3.550 = 34.050 ден.
Се продава за 24.500 ден.
« Последно менување: 05 Јуни 2018, 12:01:50 pm MartinK_2 »
  • Пораки: 30868
Одг: Specialized Crosstrail
« Одговори #1 на: 04 Јуни 2018, 19:03:59 pm »
Ѕирни ги правилата за огласување.
Отсутен MartinK_2
  • Пораки: 39
« Одговори #2 на: 04 Јуни 2018, 19:14:54 pm »
Се извинувам, ќе корегирам дома од ПЦ...
Sent from my Mi A1 using Tapatalk
Отсутен MartinK_2
  • Пораки: 39
« Одговори #3 на: 10 Јуни 2018, 23:46:21 pm »
  • Пораки: 9601
« Одговори #4 на: 11 Јуни 2018, 10:59:43 am »
убаво точаче. со среќа продажба.
ако сакаш да го продадеш намали едно 50 евра, оти вака секој би рекол, дека за истите пари нов од продавница ќе си купи со 0 километри возени.
опремата задржи си ја за тебе ако купуваш нов
Отсутен MartinK_2
  • Пораки: 39
« Одговори #5 на: 11 Јуни 2018, 11:20:54 am »
22.000 ден. му барам само на велосипедот без опрема.
Мислам дека е фер и коректна цена.
  • Пораки: 9601
« Одговори #6 на: 11 Јуни 2018, 11:38:56 am »
епа топ цена
 ама пиши ја убаво цената, јас читајки сватив дека го продаваш 34к
оваа 22 тек сега ја видов, залутана ти е на втората сликла
Отсутен MartinK_2
  • Пораки: 39
« Одговори #7 на: 11 Јуни 2018, 11:58:16 am »
34k мене ме чинеше велосипедот со опремата, сега го продавам за 24.500 комплет или само велосипедот за 22.000 ден.
Се надевам сега е појасно и за другите.
Отсутен MartinK_2
  • Пораки: 39
« Одговори #8 на: 16 Јуни 2018, 14:04:14 pm »
20.500 ден. викенд цена...
Отсутен AUUU
  • Пораки: 7464
« Одговори #9 на: 16 Јуни 2018, 14:13:42 pm »
Одлична цена, ем ХЛ рамка, еве ти @Carpatian_lord добро точаче за твоја висина таман.
Да беше М или Л ја ќе си размислев.
Отсутен Ipkisija Meskosa
  • Пораки: 9248
« Одговори #10 на: 16 Јуни 2018, 14:17:18 pm »
Си купе тој точак :)
