Автор Тема: Opel vs Honda  (Прочитано 159094 пати)
Одг: Opel vs Honda
« Одговори #420 на: 02 Февруари 2012, 20:49:43 pm »
bravo be, uspea da izdriftas so 40 konjcinja :)))
pamet u glava, ako ti dojde kola od drugata strana ke se zalapate
Присутен kimi makedonski
  • Пораки: 3528
  • Хюндай Тюсон
Одг: Opel vs Honda
« Одговори #421 на: 02 Февруари 2012, 22:09:34 pm »
kimi makedonski ти си луд! :D :D :D Алал да ти е, кај е снимено ова?
Ова е старо видео снимено на локален пат кон едно село али незнам како се вика
  • Пораки: 22425
Одг: Opel vs Honda
« Одговори #422 на: 03 Февруари 2012, 09:05:31 am »
Си ги бира информациите и си ги штелува како му одговараат, навикнати сме на него.. :)
Првиот коментар доволно кажува..
Bravo..
Znaci za NSX da bide  pobrz od eden Opelov hathcback so full oprema, potrebni se slednive modifikacii na stock NSX....::)
Ova ne se docituva...
Weight reduction...
Honda engineers started with a base NSX coupe and embarked on an aggressive program of weight reduction. Sound deadening, the audio system, spare tire, air conditioning system and traction control along with some of the electrical equipment was removed. The power leather seats were replaced with lightweight carbon fiber racing seats manufactured for Honda by Recaro. However, electric windows and fore/aft electric seat adjusters were retained. The stock forged alloy wheels were replaced with lighter forged aluminium wheels produced by Enkei, which reduced the car's unsprung weight. The stock leather shift knob was replaced with a sculpted titanium piece. Overall, Honda managed to remove approximately 120 kg (265 lb) of weight, giving the NSX-R a final weight of 1,230 kg (2,712 lb).
Suspension..
Tuning to the suspension, it was well known by 1992 that the NSX, due to its mid-engine layout and rear-end link travel, was susceptible to a sudden oversteer condition during certain cornering maneuvers. While this condition rarely occurred during spirited street driving, it was much more prevalent on race tracks where speeds were much higher. To address the problem and improve the NSX-R's cornering stability at the limit; Honda added one aluminum bracket under the front battery tray and added one aluminum bracket in front of the front radiator to add more chassis rigidity then replaced the entire suspension with stiffer front sway bar, stiffer suspension bushings, stiffer coil springs and stiffer dampers.
Springs...
The stock NSX has a rear bias in its spring rates, where the rear springs are stiffer than the front. On hard deceleration upon corner entry, the softer front springs allow weight transfer to the front wheels, increasing front grip and thus improving steering response. However, the weight transfer also takes weight off of the rear wheels, causing them to lose grip. The net result is a tendency toward oversteer, as the rear wheels are more likely to break traction and cause a fishtail or spin. For the NSX-R, Honda reversed the spring bias, placing stiffer springs on the front suspension along with stiffer front sway bar. This had the effect of preventing weight transfer to the front suspension under hard braking. This way, the rear tires would remain firmly set when entering the corner. Of course, by keeping weight off of the front wheels, front grip was reduced and the change therefore had the negative effect of increasing the understeer tendency of the car. This change required better driver skill to manage. Overall, the NSX-R uses much stiffer front sway bar along with stiffer springs than the stock NSX (21.0mm xt2.6mm front sway bar :F 3.0 kg/mm—R 4.0 kg/mm for the NSX versus F 8.0 kg/mm—R 5.7 kg/mm for the NSX-R).
Final drive ratio
Honda also changed the final drive ratio by lowering to a 4.235:1 ring and pinion gear in place of the 4.06:1 stock unit which moved the NSX-R's gear shifting points higher into the powerband at higher rpm's. This change greatly improved acceleration at the expense of top speed and higher (percentage) locking limited-slip differential was installed. Also, the NSX-R 3.0 liter DOHC VTEC V-6 engine has a blueprinted and balanced crankshaft assembly which is exactly the same labor-intensive high precision process done for Honda racing car engines built by highly qualified engine technicians.
The lightest of all NSX variants at 1,230 kg (2,712 lb), the First-Gen NSX-R is capable of blistering track performance, though the ride can be jarring and noisy due to the stiff suspension bushings, stiff spring rates and lack of sound insulation.
Limited edition od 483 primeroci...
Beginning in late November 1992, Honda produced a limited number of 483 NSX-R variants exclusively for the Japanese domestic market (JDM)
Ne deka autovo ne go biva..
Zatoa pak ke kazam..ou kej.  :)
« Последно менување: 03 Февруари 2012, 09:20:57 am Stratro »
  • Пораки: 34562
Одг: Opel vs Honda
« Одговори #423 на: 03 Февруари 2012, 10:07:22 am »
55 коњчиња
Одг: Opel vs Honda
« Одговори #424 на: 03 Февруари 2012, 10:52:49 am »
Ne mislev deka orizarite se tolku ocajni, pa mora da go vadat R modelot na NSX za da pobedat eden hatchback na Opel, koj cini 20 pati pomalku :)
Sepak vistinska konkurencijaq na Astra OPC e Civic type R. Znae nekoj zosto e tolku spor? Verojatno oti nema turbo, standardniot izgovor  ;)
  • Пораки: 34562
Одг: Opel vs Honda
« Одговори #425 на: 03 Февруари 2012, 11:32:42 am »
Ама затоа има VTEC
Одг: Opel vs Honda
« Одговори #426 на: 03 Февруари 2012, 15:45:32 pm »
Опеловиот хечбек не ни постоел нити бил во план да постои кога се возел нсх-ов. А и не ми е целта да споредувам легенда како nsx со нешто недоквакано како astra opc (не дека е лоша, ама не заслужува споредба од тој тип)
Unbelievable. Took a look at recent records at the 'ring - It takes 12+ years and 100+ more HP to beat the NSX. A tribute to having a racing driver provide input into a car's handling.
Ќе го почекаме новиот nsx :)  А тие времиња што ги правеле некои новинари на ринг, не ми се ич релевантни. Баш разгледував по времињата, разликата меѓу nsx 3.0 1991 год. возен од страна на јапонските возачи и nsx 3.2 1997 год возен од спортауто е 22 секунди (во корист на јапонците). А civic-от го немаат возено некои прочуени шофери на ринг, така да немам никакво мислење помеѓу него и астрата.
Одг: Opel vs Honda
« Одговори #427 на: 03 Февруари 2012, 15:52:34 pm »
Игор, навикнати сме веќе на споредби од овој тип
Ако се разгори битката очекувајте дека ќе се најде некоја Хонда како гори. ;D :D
  • Пораки: 22425
Одг: Opel vs Honda
« Одговори #428 на: 03 Февруари 2012, 15:54:13 pm »
Ej,ej.. nemoj da se vregame sega, kvakano nedokvakano. ;D
Rekov bravo..ali zivees vo vreme koga "nedokvakan" opelov hatchback na koj rabotele luge od Opel e pobrz od stock NSX na koj rabotel Ariton Sena i nekoj Amer...zalam toa e realnosta...site cekame nov asalen model na Honda koj ke gi opravda site postovi na stara slava.
Na Civic Type R ne mu ide bas najdobro..dajte drugo dete. :D
..Ricer excuses..ne ti trebaat  koga veke pisuvas za nekakva si superiornost i dominacija.
I za kraj, da te pozdravam so videovo za koe seuste cekame nekakov odgovor od Honda. :)
  • Пораки: 11905
Одг: Opel vs Honda
« Одговори #429 на: 03 Февруари 2012, 15:57:08 pm »
Лелееее пак истотооо...........
Лелеее ова ќе не снајдиии...........
http://www.projectnsx.co.uk/Images/Blog/brands-hatch-honda-nsx-fireBIG.jpg
Одг: Opel vs Honda
« Одговори #430 на: 03 Февруари 2012, 15:59:35 pm »
Ne mesajte babi i zabi. Nikoj ne go sporeduva NSX-ot so Astra, tuku vremeto na staza na NSX i Astra. Civic Type R e konkurencija na Astra OPC, samo nesto ne go biva, ne ode.
Одг: Opel vs Honda
« Одговори #431 на: 03 Февруари 2012, 16:08:41 pm »
Мислев на ново (со тоа недоквакано), а кола со 5-6 години стаж неможе да се здобие со епитетот Легенда. Во креирањето на астрата не учествувал човек како Сена, нити пак е по нешто претпознатлива. Од друга страна, nsx-от е првата кола со шасија 100% изработена од алуминиум (си знаеш, немора да кажувам вакви работи) :)
Реков несакам да ги споредувам civic- от  и astra-  та поради тоа што не ми се релевантни времињата на ринг за ниедна кола, а камоли па и за овие 2. Најтазе се деси со Дарко Божиловиќ (кога поседуваше opel astra superproduction) која му зададе огромни проблеми, и  изјави дека астрата нема да проработи, он се откажува скроз и најверојатно ќе купува хонда цивик. Инаку тоа е човек кој има прилично богата тркачка кариера (а сега ќе речеш тоа е поради лош тјунинг, човекот е пун пари и има широки познанства во тјунерскиот свет). Не дека неговата изјава ми е пресудна, ама говори нешто околу тие две марки на возила во тркачкиот свет.
Па не е логично усовршената кола да касни 20+ секунди, па макар и првата да ја возел господ. Тоа ми кажува дека си ги темпираат колите овие новинариве, во зависност од тоа кој колку ќе плати. За инсигниата немам лоши зборови, (само малку од напред ми е како зината, но тоа е ствар на вкус) интересно би било да се заинтересираат да одговорат на инсигниата.. Останува да почекаме .. :)))
  • Пораки: 22425
Одг: Opel vs Honda
« Одговори #432 на: 03 Февруари 2012, 16:26:09 pm »
Ajde malku seriozno.. :)
Za inferiornosta na Civic Type R vo odnos na OPC, vremeto na  Nurburgrnig e samo eden od faktite..
Istiot Nurburgring e dokaz za odlicnite vozni karakteristiki na NSX koj nikoj ne gi osporuva.
Zatoa, tuka e i golata sporedba na brojki na megu Civic Type R i OPC..
http://www.zeperfs.com/en/duel1347-1595.htm
Kraj kraeva i sam kaza deka FN2 e utnat model... i apsolutno si vo pravo bidejki negoviot prethodnik EP3 vadi podobri brojki vo sekoj pogled..sto e vo najmala raka nezamislivo i smesno :)
Licno..hatchback ( bilo OPC ili Type R) odamna ne mi e po kejf...nitu koliste kako Insignia OPC..
No osekam deka ke mi se dopadne nejzinata trovratna verzija, ako voopsto ja napravat...
  • Пораки: 3528
  • Хюндай Тюсон
Одг: Opel vs Honda
« Одговори #433 на: 03 Февруари 2012, 16:52:13 pm »
55 коњчиња
40 се не се 55 :D
Или поточно во регистрација пише 29 киловати
Присутен MecheTo
  • Пораки: 15269
Одг: Opel vs Honda
« Одговори #434 на: 03 Февруари 2012, 16:57:35 pm »
39.44 :D
