Автор Тема: H7 Xenon HID vs H7 LED Cree???  (Прочитано 1728 пати)
Отсутен Vlado_78
  • Пораки: 228
« на: 25 Ноември 2014, 19:48:19 pm »
Zdravo, sakam da gi nadgradam farovite (spushteni svetla) na mojata Audi A4 (2003 so lupa) so nesto pojako. Se mislev da zemam Nightbreaker ali gledam deka iskaca mnogu skapo koga kje vidis kolku traat (max 1god.) pa se mislam da idam na HID, ali nekoj koj kje bide saglam a ne nekoe Kinesko gjubre.
Surfajki  vidov deka i pocnale da se proizveduvaat i H7 LED Cree shto se priblizno so ista jacina kako i HID -xenon...
Pa ima li nekoj iskustvo so novive LED H7 sijalici i mislenje okolu izborov???
Potocno se mislam  za ovie:
http://www.aliexpress.com/item/Canbus-HYLUXTEK-Free-Dropship-35W-9-32V-HID-xenon-kit-CNlight-HID-BULB-H1-H3-H7/1905572406.html
http://www.aliexpress.com/item/2014-New-2Pcs-1Set-2nd-Car-CREE-LED-H1-H3-H7-H8-H9-H11-9005-9006/32216908171.html
Poshto nikogash ne sum imal iskustvo so drugo osven Halogen-sko svetlo, preporaka okolu proizvoditelive na pristupacni xenon kit-ovi e dobrodojdena :)
Отсутен Dando
  • Пораки: 339
Одг: H7 Xenon HID vs H7 LED Cree???
« Одговори #1 на: 25 Ноември 2014, 20:01:32 pm »
Imam ksenon za prodavanje h7 6000k 5000den ako sakas zazal kaj mene ne mozam da go montiram inace ne bi go dal za ziva glava.
« Одговори #2 на: 25 Ноември 2014, 20:09:54 pm »
Ова со LED-ов ми изгледа интересно...
low-pressure sodium: 125 to 200 lm/W (typical 150 lm/W)
high-pressure sodium: 80 to 125 lm/W
HID: 65 to 110 lm/W
T-12 fluorescent: up to 90 lm/W (typical 60 to 80 lm/W)
T-8 fluorescent: up to 100 lm/W (typical 85 to 92 lm/W)
T-5 fluorescent: up to 104 lm/W (typical 95 to 100 lm/W)
CFL: 60 to 70 lm/W typical (includes ballast losses)
mercury vapor: 55 lm/W
xenon arc: 30 lm/W
incandescent: 15 lm/W typical (as low as 1 lm/W for small lamps, up to 40 lm/W for short-life bulbs)
white LED: 15 to 30 lm/W typical, up to 60 lm/W next year (current record 74 lm/W)
colored LED: 5 to 55 lm/W depending upon color (current record is 102 lm/W @ 618 nm)
For large amounts of white light HID in the larger sizes (400W to 1000W) is currently the most efficient. For residential and office use T-5 fluorescent is the most efficient option although T-8 comes fairly close. For small uses LED is generally more efficient than incandescent. For colored light LED is the best choice regardless of size.
