Автор Тема: Mobil, Total, Elf или какво масло ?  (Прочитано 2440764 пати)
Отсутен Sportex
  • Пораки: 7879
  • Иштван Беќар Пецарош
    • camouflage.mk
« Одговори #2505 на: 09 Август 2014, 11:25:19 am »
Po preporaka za kolava odi Castrol Edge 5-30 ama nekako ne sum zadovolen od ova sto tuka go kupuvam.
Ne velam deka praam mucki ili nesto ama ednostavno ne e toj kvalitet sto treba da bide.
Vtor pat stavam od nego i koga ke podostare (posle 5.000 km) nekako pocnuva motorot poglasen da stanuva, sto ne bese slucaj pred toa.
Se konsultirav so luge sto imaat iskustvo vo ova i mi rekoa deka 99% e od masloto.
Eve, Moze i ne e do toa ama sum primetil deka se slucuva a ne gledam druga pricina?
Mislenje za TOTAL QUARTZ INEO ECS 5W30 ?
APPLICATIONS
Low SAPS synthetic technology oil specially designed for PEUGEOT and CITROËN engines. Its very high-tech
performance generates Fuel Savings and optimises the way in which anti-pollution systems - such as Particulate
Filters - operate.
 TOTAL QUARTZ INEO ECS 5W30 is a special second-generation Fuel Savings lubricant: it can be used with all
Diesel engines - older ones, as well as more recent ones. It is suitable for use with most petrol engines.
 TOTAL QUARTZ INEO ECS 5W30 is vital for ensuring the effective operation of particulate filters and is also suitable
for use with other post-treatment systems.
 TOTAL QUARTZ INEO ECS 5W30 is appropriate for use with the severest of maintenance cycles and the most
difficult driving conditions (motorway, dense urban traffic, etc.),
CLIENT BENEFITS
 Increased life of particulate filters: Maximises the efficiency of the Particulate Filter, preventing it from getting
clogged up prematurely (contains 50% fewer metal components than a standard technology oil).
 Fuel economy: Fuel Savings of up to 6% at start-up, Fuel Savings of an average of 3% during mixed operation
compared with an ACEA reference oil (tests carried out on a Citroën C4 1.6 HDi).
 Respect for the environment: “ECS_Emission Control System”: lower CO2 emissions and other pollutants. As well
as improving the efficiency of the Particulate Filter, lower fuel consumption means lower CO2 emissions. The low
levels of phosphorus and sulphur contained in this lubricant provide all the post-treatment components with excellent
protection, optimising their life cycle. NOx emissions are also managed and reduced.
 Optimum engine protection cleanliness: The detergent and specific dispersive additives provide the engine with
optimum protection against wear and prevent the formation of soot and sludge deposits.
Отсутен Allexxander
  • Пораки: 5859
« Одговори #2506 на: 09 Август 2014, 12:19:35 pm »
Од каде го купувате Кастролот? Оригинал е?
  • Пораки: 7278
« Одговори #2507 на: 09 Август 2014, 14:00:15 pm »
Спортекс, ти пиши во упатството што спецификации на уље треба па тогаш ќе видиме.
  • Пораки: 34566
« Одговори #2508 на: 09 Август 2014, 17:40:14 pm »
Господине, реченицава ја пишувате во охридски или скопски контекст? :D
  • Пораки: 7278
« Одговори #2509 на: 09 Август 2014, 18:04:20 pm »
Ahahahhaaha се видов што сум пишал ;D битно ме сфаќате нели :)
  • Пораки: 34566
« Одговори #2510 на: 09 Август 2014, 20:20:25 pm »
Ne znam ne znam :D
Отсутен bramovsk
  • Пораки: 4216
« Одговори #2511 на: 09 Август 2014, 22:54:35 pm »
Oва ми се врти у глава
http://www.valvolineeurope.com/english/products/engine_oils/synpower_xtreme/cid(7728)/synpower_xtreme_mst_c3_5w-40
Пишав и претходно, тргнав по Castrol, го видов ова и се мислев, се вратив дома и пак назад за да на крај купам Titan Fuchs :D
И? Пивна ли малце? Како иде, со кое мезе легнува? Се мсилам дали да се префрлам на следна тура на Fusch, иако со  Petronas-ов немам забелешки. Исто ми работи колата како со Selenia-та.
http://www.fuchs.com.mk/index.php/fuchs-2
Добро уљенце е, иако цената му е пониска од другите. Кај мене не пивна уште, ама не беше жедна ни со претходните, така да ни мезе немаше потреба да се придаде. Таква ми е скромна - мало једе, много троши, добро се носи ...
Џиџи, имаш нешто да кажеш за маслово комаративно во однос на друго што си ставал во иста кола? Сеа мислам да го пробам TITAN GT1 SAE 5W-40 ако е прифатлива цена.
Отсутен Drive-r
  • Пораки: 7477
  • FB Vlecna Suzba Niko-m
« Одговори #2512 на: 11 Август 2014, 23:26:19 pm »
@Drive-r, Нешто си читал, не си дочитал:
http://www.opieoils.co.uk/pdfs/tech-articles/Oil-The-Basics.pdf
http://www.opieoils.co.uk/pdfs/tech-articles/ACEA-Specifications-Current.pdf
http://www.opieoils.co.uk/pdfs/tech-articles/API-Engine-Oils-Specifications.pdf
http://www.opieoils.co.uk/pdfs/tech-articles/The-Advantages-of-Synthetic-Oils.pdf
http://www.opieoils.co.uk/pdfs/tech-articles/Oil-Additive-Package.pdf
Можно е...
Горе се малку постари информациите, тука ја има и најновата SN спецификација.
http://www.api.org/certification-programs/engine-oil-diesel-exhaust-fluid/~/media/Files/Certification/Engine-Oil-Diesel/Publications/MOM_GUIDE_ENGLISH_2013.pdf
Од API најдобро би било со SN спецификација или од ILSAC со GF-5.
По препорака се ставало од ова
http://www.shell.com/global/products-services/on-the-road/oils-lubricants/cars/find-right-car-oils/helix-fully-synthetic/ultra-5w40.html
Гледам масло за возила на плин, дпф, ова, она....
5W-40 со спецификација SN oд ист производител има неколку видови на масло, како да одберам квалитетно масло, фул синтетичко за бензинец атмосферец?
На што да се обрне внимание?
Отсутен Sportex
  • Пораки: 7879
    • camouflage.mk
« Одговори #2513 на: 12 Август 2014, 17:33:08 pm »
Mi Pisi upotrebuvajte maslo so slednava specifikacija VW 50501/50601, vrti suci pak VW :)
« Одговори #2514 на: 12 Август 2014, 17:46:09 pm »
Motul X-clean. Пичи слободно. Ако најдеш и Motul Specific може, имаат и за 506.01.
  • Пораки: 34566
« Одговори #2515 на: 12 Август 2014, 17:48:45 pm »
Ти стави го маслото со тие спецификации што е во средина со цена. Ни најскапото ни најевтиното... ко на пример Ликви моли :D
  • Пораки: 7278
« Одговори #2516 на: 13 Август 2014, 10:50:40 am »
@Sportex
Мотулот ти е една варијанта, јас исто би ти препорачал
http://www.opieoils.co.uk/p-986-fuchs-titan-supersyn-ll-plus-0w-30-fully-synthetic-oil-for-vw-and-pd-diesel-engines.aspx
овој исполнува 506,01 спецификација
или поефтина варијанта претпоставувам
http://www.opieoils.co.uk/p-60166-fuchs-titan-gt1-xtl-5w-40-synthetic-engine-oil-bmw-mercedes-porsche-vw-more.aspx
исполнува 505,01 спецификација
Единствена разлика е
VW 505.01 oil
The oils in this section meet the VW 505.01 specification. These oils are especially for "Pumpe-Düse" (unit injector or "PD" engines) running on fixed service intervals (15,000km / 12 months).
It is vitally important to use an oil meeting either this, the VW 506.01 specification or the VW 507.00 specification to avoid damaging the diesel pump in PD engines.
For PD engined cars with a DPF, use only an oil meeting the VW 507.00 specification.
VW 506.01 oil
The oils in this section meet the VW 506.01 specification. These oils are especially for "Pumpe-Düse" (unit injector or "PD" engines) running on extended service intervals (30,000 - 50,000km / 24 months). Oil change is indicated by the electronic service indicator.
It is vitally important to use an oil meeting either this, the VW 505.01 specification or the VW 507.00 specification to avoid damaging the diesel pump in PD engines.
For PD engined cars with a (DPF), use only an oil meeting the VW 507.00 specification.
Е сеа малку последново буни работа, демек ако имаш ДПФ користи 507,00, иако C ознаката на ACEA означува C Catalyst compatible or low SAPS
Кај нас во МКД Фукс го имаш во
Отсутен Sportex
  • Пораки: 7879
    • camouflage.mk
« Одговори #2517 на: 13 Август 2014, 11:58:13 am »
Thanks za odgovorot, kaj mene e so DPF pa ako gi sledime preporakite bi trebalo 507.00 specifikacija. Bitno mi e da e masloto kavlitetno (Citaj original), ne Skopsko vo Ambalaza od Heineken.
  • Пораки: 20901
« Одговори #2518 на: 13 Август 2014, 12:25:40 pm »
Треба ли да се интервенира у маслото, кога веќе колата е конвертирана за да вози на плин?
Глеам има некои масла као за "gas-powered vehicles", па ме интересира дали има стварно поента, или е чисто маркетинг?
Отсутен FilipM
  • Пораки: 3999
  • Turbo
« Одговори #2519 на: 13 Август 2014, 12:44:37 pm »
http://testfl.onion.it/iframe_main_catalogo_prodotto.inc.asp?cod_prd=1156&id_lingua=2&id_livello=1&id_canale=1&id_categoria=8
SELENIA MULTIPOWER SPECS - Synthetic lubricant specifically for petrol and diesel engines of the Volkswagen group that require engine oils with low ash content (LOW SAPS). Studied especially for the new engines fitted with particulate filter.
SAE 5W-30, ACEA C3, ACEA A3/B4, VW 504.00-507.00
