Автор Тема: Opel Calibra Turbo 4x4  (Прочитано 528208 пати)
  • Пораки: 22430
« на: 16 Јануари 2011, 16:09:20 pm »
Eve go i moeto vozilo..
1995 Opel Calibra Turbo 4x4
Fabricki specifikacii..
Engine size: 1998 ccm (121.92 cubic inches)
Seats: 4
Drive: 4WD
Transmission: Manual, 6-speed
Engine and transmission
Engine location: Front, transverse
Displacement: 1998 ccm (121.92 cubic inches)
Engine type: Inline, 4 cylinder
Max power: 203.80 PS (150 kW or 204 HP) at 5600 Rev. per min.
Max torque: 280.00 Nm (28.6 kgf-m or 206.5 ft.lbs) at 2400 Rev. per min.
Compression: 9.0:1
Bore x stroke: 86.1 x 86.0 mm (3.4 x 3.4 inches)
Fuel system: Turbo
Valves per cylinder: 4
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: Manual, 6-speed
Speed and acceleration
0-100 km/h (0-62 mph): 6.8 seconds
0-50 miles: 4.6 seconds
0-60 miles: 6.2 seconds
Power/weight ratio: 0.1359 PS/kg
Exterior and interior
Chassis type: Coupe
Max no. of doors: 2
Passenger space: 4690 litres (1,239 gallons)
Steering, brakes and tires
Turn circle: 11 m (421.3 inches)
Front brakes: Ventilated disks, 284 mm
Rear brakes: Disks, 269 mm
Brake details: Antiblocking system (ABS)
Kolata ima chip so LOTEC STAGE III softver i pojacan boost na turbinata od 0.6 na 0.8 bara (max.1.1 bar) i na prolet ke se meri kolku tocno KS ima dobieno.
Ima smeneto: novi ventiliracki diskovi ( od prethodniot sopstvenik)  pa rebrast kais, klinast kais, hidraulicni podizaci, novi Beru kabli, Bosch razvodna kapa, novi drzaci za motor, chauri, stabilizatori, skoro site dihtunzi pocnuvajki od onoj na glava na motor, gumici na ventili pa se do najsitnite semerinzi. Smeneti se site elektricni relea so se instalacija, termostat i ponekoja plasticna sitnica vo enterier.
Normalno, se e naracano od Germanija ili UK.
Skoro se na nea e fabricko, funkcionalno i planiram taka da ostane so isklucok na zadniot lonec koj bi go zamenil so nekoj poprotocen ( ne mora poglasen) koga za toa ke dojde vreme.
Kupeni se meraci za Boost, Oil Pressure i Oil Temp ( vo fabricko kukiste) no uste ne se staveni..
...kako i USB player za muzika za koj se pomaciv da go najdam so vakov retro (ne sharen ) dizajn:)
Fabrickiot  BLAUPUNKT CD player si go otsluzi svoeto.:)
I toa bi bilo se sega za sega...
« Последно менување: 23 Јуни 2011, 16:11:56 pm Stratro »
Отсутен SceMax
  • Пораки: 111
  • In Diesel We Trust !!!
Одг: Opel Calibra Turbo 4x4
« Одговори #1 на: 16 Јануари 2011, 18:37:21 pm »
Zakon e Calibrata ;)
Merachite isto.
Znaes deka od Sony ni S nema vo playerceto neli ?
« Последно менување: 16 Јануари 2011, 18:57:48 pm Banzai »
  • Пораки: 22430
« Одговори #2 на: 16 Јануари 2011, 20:15:49 pm »
Normalno. :D
Ali ke vrsi rabota so 2GB mp3-ki.
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #3 на: 16 Јануари 2011, 20:27:12 pm »
Доста уредна Калибра, интересно ми е што ја чуваш во оригинална состојба :)
  • Пораки: 22430
« Одговори #4 на: 16 Јануари 2011, 21:26:22 pm »
Toa ke da e najretko izgleda, barem sto se odnesuva do exterierot.
  • Пораки: 34565
« Одговори #5 на: 17 Јануари 2011, 16:06:10 pm »
Супер. Подобро аутце здравје. Како стои со потрошувачка низ Скопје? Иде над 12л?
  • Пораки: 22430
« Одговори #6 на: 17 Јануари 2011, 16:13:21 pm »
Letno vreme od 10.5 do 11.
Zimno vreme nad 12 ne odi.
..isklucivo gradska.
  • Пораки: 34565
« Одговори #7 на: 17 Јануари 2011, 20:02:22 pm »
Ууу маму му. Закон. Најубаво аутце у Скопје. Немој да си го учукал некаде. Ќе даеш кругче кога ќе се видиме на собир. Ја ќе ти даам кругче со мојот Кадет од 67ма година
« Одговори #8 на: 17 Јануари 2011, 22:03:38 pm »
Најзакон кола на форумот!
  • Пораки: 22430
« Одговори #9 на: 18 Јануари 2011, 13:49:41 pm »
haha..za kogo kako, my friend.
Отсутен kalimero
  • Пораки: 1922
« Одговори #10 на: 18 Јануари 2011, 14:41:05 pm »
И јас го делам мислењето со лоши патишта.
« Последно менување: 12 Април 2012, 12:06:21 pm kalimero »
Отсутен SceMax
  • Пораки: 111
« Одговори #11 на: 18 Јануари 2011, 23:21:22 pm »
Me To :)
  • Пораки: 34565
« Одговори #12 на: 18 Јануари 2011, 23:37:21 pm »
Сите крадете мои финти :)
  • Пораки: 22430
« Одговори #13 на: 24 Јануари 2011, 00:00:44 am »
 8)
  • Пораки: 34565
« Одговори #14 на: 24 Јануари 2011, 08:25:50 am »
И коњите трчаат по Калибрата....
