Автор Тема: 2012 Chevrolet Corvette ZR1 drops ‘Ring time to 7:19.63  (Прочитано 319178 пати)
  • Пораки: 22297
Одг: 2012 Chevrolet Corvette ZR1 drops ‘Ring time to 7:19.63
« Одговори #465 на: 12 Септември 2011, 22:42:56 pm »
0-100 + top speed+ price + Nurburgring laptime = 3:1.
Top Gear test track vremeto ja ne go esapam..ali zatoa cenata bi ja boduval x3 ;)
« Одговори #466 на: 12 Септември 2011, 22:47:49 pm »
fair enough
« Одговори #467 на: 16 Септември 2011, 23:02:30 pm »
Go izgledav videoto na LFA za prvpat. Mi se dopadna kolata i upravuvanjeto. Mi se dopaga sto postavija video po primerot na Corvette na koe se se gleda. Cestitki za prvoto mesto.
Mene malku me cudi slednava recenica:
'In standard trim the Lexus LFA supercar has lapped the notorious Nurburgring-Nordschleife in a reasonable 7:38, but now the car equipped with its optional Nurburgring Package (extra 70.000$) has done the feat in just 7:14.64. Yes, you read that correctly. And here's the video to prove it.'
Sto li ima vo toj paket sto go podobri vremeto za 24 sekundi :o
Kako i da e, mislam deka sega i drugite ke reagiraat so svoj 'paket'. Ke bide interesno :)
  • Пораки: 22297
« Одговори #468 на: 17 Септември 2011, 18:18:12 pm »
Jan Magnussen of Corvette Racing breaks down the difference between the ZR1 street car and the C6. R race car.
« Одговори #469 на: 23 Септември 2011, 11:19:24 am »
“We have to target a very different sort of buyer.”
Anxious to attract the sort of high-performance buyers increasingly drawn to European sports cars from the likes of Porsche, Ferrari and Lamborghini, General Motors is planning some major changes for the next-generation Chevrolet Corvette – starting with a high-revving, small-displacement powertrain, that will substitute for the big V-8s traditionally found under the hood of the Chevy two-seater.
GM has approved the use of a very European-style V-8 that will be only slightly larger than 3 liters in displacement.  The engine will be an overhead-cam, rather than traditional overhead-valve design, using a dry sump oil system that’s particularly well suited to high-performance road courses rather than straight-line acceleration. The engine is expected to feature a narrow 80.5 mm bore and a long stroke, more like a Ferrari or Lamborghini powertrain than the approach used for traditional Motor City metal.
A very senior GM executive also confirmed that the new engine will be turbocharged, which will help yield a broad torque curve and maximum performance under a variety of driving conditions. The engine is expected to deliver in excess of 400 horsepower, which means a specific output in the range of 125 horsepower per liter. That’s the sort of number that would help the next-generation Vette stack up well against the likes of a Porsche 911 or Lamborghini Gallardo.
The engine is likely to be extremely high-revving, perhaps climbing to a near-Formula One-class 10,000 RPMs, suggested one source involved in the project.
The revelation tracks in line with a recent comment by General Motors’ North American President Mark Reuss, who recently promised that the so-called C7 Corvette, due to market in less than two years, will be “completely different” from the very American sports cars that have come before it. Since its launch in 1953, Corvette has been governed by the philosophy, “there’s no replacement for displacement.”
While Reuss and other senior executives have declined to discuss plans for the next Corvette publicly, several well-placed sources have given TheDetroitBureau.com a good sense of what’s to come. The small V-8 underscores what one of those insiders says is the desire to “target a very different sort of buyer for the next Corvette. Let’s face it, the current customer is getting old.” But without making significant changes, that source acknowledged, younger sports car fans will continue to be “conquested” by more modern, high-tech imports.
Significantly, Corvette won’t abandon its more classic powertrain roots entirely.  There will be several different types of engines offered for the C7, including a more classic, big-block OHV V-8 designed to appeal to traditionalists.
In fact, some of the design cues of the new car will be borrowed from early generations. There have even been rumors of the C7 going with the split window of the very collectible 1963 Corvette, though TheDetroitBureau.com has not been able to confirm that that particular detail has been given the go.
Meanwhile, expect the interior to be much more modern than the current car’s, which GM’s global design chief Ed Welburn admits “is a disappointment.” The styling boss, a long-time Corvette fan himself, says he is personally overseeing the development of the C7 interior and promises it will be “absolutely world-class.”
Adopting a mid-engine layout, rather than the long-running front-engine design, is considered a strong possibility, though it would be a significant engineering shift for GM. Nonetheless, sources say that wouldn’t be entirely out of line, as the Corvette has often served as the technological test bed for the maker.
GM adopted the then-radical approach of using a fiberglass body when the original 1953 Corvette was launched. The sports car has introduced plenty of other features over the years, including the MagneRide suspension, which uses a magnetically controlled fluid to continuously vary suspension settings to match road conditions and driving behavior.
When migrating from the fifth-generation Corvette to today’s C6 model, GM trimmed weight and brought the sports car’s overall size down to something closer to that of a current Porsche 911. Anticipate further cuts in mass for the upcoming remake of Chevy’s halo car.
GM is investing $131 million in the Bowling Green, Kentucky plant that produces the Corvette to prepare for the C7 launch.
The use of the new small-displacement V-8 is likely to have some knock-on effects at GM, said one source. As with current Corvette powertrain technology, the high-tech engine will find its way into the Cadillac line-up, it appears, where it would help that brand’s V-Series evolve into a more sophisticated offering, rather than the brute-force line-up it is today.
The switch to a smaller, turbocharged V-8 isn’t exclusive to GM, incidentally. Ford made the move with its big F-Series pickup for 2011, offering a downsized EcoBoost twin-turbo V-6 — which delivers the same sort of towing power as the F-150′s biggest V-8, while yielding significant fuel economy improvements.
http://autos.yahoo.com/news/next-corvette-will-be-powered-by-small--high-revving-turbo-v-8.html
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #470 на: 23 Септември 2011, 11:25:58 am »
Што им текнало да мењаат концепт на мотор, па уште ова како Ферари и Ламбо, па она слично како Ферари и Ламбо... Нели беа подобри од нив и имаа подобра технологија? :)
А и сами викаат дека ентериерот е разочарување и ветува дека на новата ќе биде world class :) А вие и за ова не уверувавте дека ентериерот е одличен, модерен, дрн дрн ;D
Во секој случај, браво за GM за идните планови.
  • Пораки: 55275
« Одговори #471 на: 23 Септември 2011, 11:39:47 am »
  • Пораки: 22297
« Одговори #472 на: 23 Септември 2011, 15:34:02 pm »
Vo 2013 ta GM so maliot V8 turbo motor vo Corvette ke pokaze na konkurencijata deka i toa kako moze da proizvede kvaliteten motor koj reva i do 11.000 rpm, ( momentalno nezamislivo za Ferari, Porse ili Lambo atmosferci,  a kamoli so turbo ;D ;D), motor koj ke bide podobar od konkurencijata a ke kosta pomalku... i  ke vadi 450 KS od edvaj 3000 cm3.
Za segasniot enterier nikogas ne sme rekle deka e kako vo Maybach , tuku deka onoj na Ferrari ni od kilometar ne ja opravduva cenovnata razlika so ogled na toa deka Corvette ZR1 se pokaza kako podobro vozilo i vo pogled na performansi i vo pogled na moknost i vo pogled na trajnost.
Ete, bidejki aktuelnite Corvette hejteri nemaat za sto da se fatat osven za segasniot enterier na ZR1 ( lol), GM vo 2013 ta najavuvaat world class enterier...
Za onie koi ne procitale detalno ili gi mrzi..eve skratena verzija.
http://www.worldcarfans.com/111052633689/gm-working-on-a-small-turbo-v8-for-next-corvette
..odnosno...
GM will be offering other engines in the new C7 Corvette with a more traditional Corvette approach including a big-block V8 with overhead valves.
Znaci, pokraj maliot V8, Corvette sprema i big block V8 za onie "tradicionalno" orientitranite.:)
Big block = nad 8000 cm3, sto znaci najgolem motor staven vo Corvette do sega.
« Последно менување: 23 Септември 2011, 15:47:49 pm Stratro »
  • Пораки: 55275
« Одговори #473 на: 23 Септември 2011, 15:47:16 pm »
Дај боже да има над 8000цц. :) А дека ќе врти до 110.000 обртаи тешко. Може да врти до 11.000 евентуално. :) Многу тешко се изведуваат турбини за толку широк опсег на работа, ама не дека не е изводливо. Турбините се добри кога нивната употреба е во мало подрачје, каде може да се осмислат каналите и деталите за да се извадат максимални перформанси и ефикасност. Со други зборови би требало да употребуваат варијабилна геометрија во турбината што не звучи воопшто амерички. Баш ме интересира што ќе искочи од ова. Има голем број на решенија за турбините и голем број се со пренасочување на издувите, особено кај мулти-турбо системи. Мора да е такво нешто. :)
« Одговори #474 на: 23 Септември 2011, 15:54:39 pm »
I dosega Corvette vazese za eden od vodeckite super avtomobili. Vo prilog na kolata odea:
1.performansi
2.cena
3.kvalitet
4.trajnost
5.ogromna tradicija
6.prepoznatliv dizajn
7.ogromni uspesi na patekite
Edinstveno sto nekoi zlobni luge mozea da najdat zamerka:
1. motorot imal mnogu iljadi kubici
2. evtini plastiki
So prvoto voopsto ne se soglasuvam jas i sekoj fan na Corvette. Denes Ferrari i Lambo ja nadminaa Corvette po brojot na kubici, no ne ja podobrija izdrzlivosta na svoite motori. Corvette ima fenomenalni motori, so torque niz celoto rabotno podracje, na kolata mozat da i vgradat avtomatik so 2 brzini i pak ke ima odlicni performansi. No, so cel da gi privlecat i ostanatite kupci, onie sto sakaat visoki vrtezi i 'visoka tehnologija', GM odluci da napravi mal motor sto ke vrti na 11.000 vrtezi, sto patem ke bide potpomognat i so turbo, kombinacija za koja sto  drugite proizvoditeli mozat da sonuvaat. No tuka ne sopira genijalnosta na menadzerite na GM, paralelno so noviot motor si prodolzuva tradicijata na golemite atmosferci. Starite sledbenici na mitot na Corvette ke bidat zadovoleni, ke dojdat i novi. Konecno site ke bidat zadovolni :)
2. Interierot bese soliden, celiot vo koza, so pristoen dizajn. Sepak kupuvas kola od 46k, ne od 1 milion. No ova bese edinstveniot nedostatok na kolata. Ne poveke. Sega ke ima 'absolutely world-class' interier.
Ups, kolava izgleda nema da ima nikakva maana  :o
« Последно менување: 23 Септември 2011, 16:02:21 pm LosiPatista »
Отсутен Tommy
  • Пораки: 7822
« Одговори #475 на: 23 Септември 2011, 16:18:17 pm »
И нема да ја поседуваат 98% од нас ...
« Одговори #476 на: 23 Септември 2011, 16:26:22 pm »
stani amerikanec, za 3-4 godini ke si kupis edna.
Отсутен Tommy
  • Пораки: 7822
« Одговори #477 на: 23 Септември 2011, 16:28:36 pm »
Што мислиш, зошто реков 98%? :P Да не бегам ОТ ...
Отсутен ace-106
  • Пораки: 3468
« Одговори #478 на: 23 Септември 2011, 19:23:27 pm »
Затоа што 98% од луѓето не ја ни посакуваат ...
  • Пораки: 55275
« Одговори #479 на: 23 Септември 2011, 20:35:32 pm »
;D mangup...
