Автор Тема: Ладни свеќици?  (Прочитано 4950 пати)
Отсутен K92
  • Пораки: 725
Ладни свеќици?
« на: 18 Март 2011, 01:05:53 am »
Што е разликата во свеќици и овие ладни свеќици што ги викаат?
« Последно менување: 24 Декември 2011, 00:37:12 am Kiko »
Одг: Ладни свеќици?
« Одговори #1 на: 18 Март 2011, 08:59:33 am »
Што е разликата во свеќици и овие ладни свеќици со ги викаат? Баш ме интересира, извинете што ја отворив тука темата префрлете ја на друго место ако не е на правилно место отворена.  :)
Heat range
The operating temperature of a spark plug is the actual physical temperature at the tip of the spark plug within the running engine. This is determined by a number of factors, but primarily the actual temperature within the combustion chamber. There is no direct relationship between the actual operating temperature of the spark plug and spark voltage. However, the level of torque currently being produced by the engine will strongly influence spark plug operating temperature because the maximum temperature and pressure occurs when the engine is operating near peak torque output (torque and RPM directly determine the power output). The temperature of the insulator responds to the thermal conditions it is exposed to in the combustion chamber but not vice versa. If the tip of the spark plug is too hot it can cause pre-ignition or sometimes detonation/knocking and damage may occur. If it is too cold, electrically conductive deposits may form on the insulator causing a loss of spark energy or the actual shorting-out of the spark current.
A spark plug is said to be "hot" if it is a better heat insulator, keeping more heat in the tip of the spark plug. A spark plug is said to be "cold" if it can conduct more heat out of the spark plug tip and lower the tip's temperature. Whether a spark plug is "hot" or "cold" is known as the heat range of the spark plug. The heat range of a spark plug is typically specified as a number, with some manufacturers using ascending numbers for hotter plugs and others doing the opposite, using ascending numbers for colder plugs.
The heat range of a spark plug (i.e. in scientific terms its thermal conductivity characteristics) is affected by the construction of the spark plug: the types of materials used, the length of insulator and the surface area of the plug exposed within the combustion chamber. For normal use, the selection of a spark plug heat range is a balance between keeping the tip hot enough at idle to prevent fouling and cold enough at maximum power to prevent pre-ignition or engine knocking. By examining "hotter" and "cooler" spark plugs of the same manufacturer side by side, the principle involved can be very clearly seen; the cooler plugs have a less substantial ceramic insulator filling the gap between the center electrode and the shell, effectively allowing more heat to be carryed off by the shell, while the hotter plugs have more ceramic material, so that the tip is more isolated from the body of the plug and retains heat better.
Heat from the combustion chamber escapes through the exhaust gases, the side walls of the cylinder and the spark plug itself. The heat range of a spark plug has only a minute effect on combustion chamber and overall engine temperature. A cold plug will not materially cool down an engine's running temperature. (Too hot of a plug may, however, indirectly lead to a runaway pre-ignition condition that can increase engine temperature.) Rather, the main effect of a "hot" or "cold" plug is to affect the temperature of the tip of the spark plug.
It was common before the modern era of computerized fuel injection to specify at least a couple of different heat ranges for plugs for an automobile engine; a hotter plug for cars which were mostly driven slowly around the city, and a colder plug for sustained high speed highway use. This practice has, however, largely become obsolete now that cars' fuel/air mixtures and cylinder temperatures are maintained within a narrow range, for purposes of limiting emissions. Racing engines, however, still benefit from picking a proper plug heat range. Very old racing engines will sometimes have two sets of plugs, one just for starting and another to be installed once the engine is warmed up, for actually driving the car.
Spark plug manufacturers use different numbers to denote heat range of their spark plugs.
Отсутен marsher
  • Пораки: 3177
    • smchiptuning
Отсутен IvO
  • Пораки: 1676
Одг: Ладни свеќици?
« Одговори #3 на: 21 Март 2011, 01:26:03 am »
i koja bi ja preporacale ?
Одг: Ладни свеќици?
« Одговори #4 на: 21 Март 2011, 08:01:51 am »
