Автор Тема: U.S. Muscle Cars  (Прочитано 605659 пати)
  • Пораки: 22422
Одг: U.S. Muscle Cars
« Одговори #45 на: 30 Мај 2011, 00:43:30 am »
  • Пораки: 22422
« Одговори #46 на: 03 Јуни 2011, 12:52:25 pm »
Eve sto vozat americki brachen par..
« Последно менување: 03 Јуни 2011, 15:30:31 pm Stratro »
  • Пораки: 22422
« Одговори #47 на: 06 Јуни 2011, 00:23:23 am »
  • Пораки: 55354
« Одговори #48 на: 24 Јуни 2011, 14:16:46 pm »
Отсутен NetworX
  • Пораки: 929
« Одговори #49 на: 19 Јули 2011, 02:28:21 am »
Dear God. Thank you for providing us with the direct-port nitrous injection, 4 core intercoolers, ball bearing turbos, and titanium valve springs, Amen.
  • Пораки: 22422
« Одговори #50 на: 15 Август 2011, 00:00:03 am »
Spremni?
http://firebreathercar.com/
Only 50 pieces are for sale and will be two versions available: a $ 60,000 and a $ 85,000 one. For 85 large, you get a black fire eaters Camaro SS with a 6.2-liter V8 engine 599hp, equipped with a trans-style body, personalized door panel and got Dash Trim, fire eaters Piano Black interior package, fire eaters floor mats, fire eaters black leather interior, Pirelli Tires, Eibach Springs, Hurst Shifter Systems, a dual exhaust system from JBA and the list goes on.
« Последно менување: 15 Август 2011, 00:47:36 am Stratro »
« Одговори #51 на: 15 Август 2011, 09:58:13 am »
Mozi da gi zemat za Transformers 3...4? DO koj del se sega ? :)
  • Пораки: 22422
« Одговори #52 на: 17 Август 2011, 12:58:35 pm »
Engine V-8
Type 5.0L 4V Ti-VCT V-8
Manufacturing location Essex Engine, Windsor, Ontario
Configuration Aluminum block and heads
Intake manifold Composite shell-welded with runner pack
Exhaust manifold Stainless steel tubular headers
Redline 7,000 rpm (est.)
Valvetrain DOHC, 4 valves per cylinder, variable intake, variable camshaft timing
Valve diameter/lift (mm) Intake: 37/12; Exhaust: 31/11
Pistons Cast aluminum
Connecting rods Forged steel
Ignition High-energy coil-on-plug
Bore x stroke 3.63 in x 3.65 in/92.2 mm x 92.7 mm
Displacement 302 cu. in./4,951 cc
Compression ratio 11.0:1 (est.)
Engine control system PCM
Horsepower 412 @ 7,000 rpm (est.)
Horsepower per liter 82.4
Torque 390 lb.-ft. @ 4,250 rpm (est.)
Recommended fuel 91 octane (unleaded 87 octane minimum)
Fuel capacity 16 gallons
Fuel delivery Sequential mechanical returnless
Oil capacity 8 quarts with filter (10,000-mile service interval)
Suspension
•Front Reverse-L independent MacPherson strut, 34.6-mm tubular stabilizer bar
•Rear 3-link solid (limited slip) axle with coil springs and Panhard rod and 44.0-mm solid stabilizer bar
Steering
•Type Electric Power Assist Steering (EPAS) with rack-and-pinion gear
•Ratio 15.8:1
•Turning circle curb-to-curb 33.4 ft. (est.)
Type Four-wheel power disc brakes with 4-sensor, 4-channel anti-lock braking system (ABS)
•Front 336 (13.2 in) x 36 mm vented discs, twin-piston 43-mm floating aluminum calipers
•Rear 300 (11.8 in) x 19 mm vented discs, single-piston 43-mm floating iron calipers
  • Пораки: 22422
« Одговори #53 на: 21 Август 2011, 21:44:06 pm »
  • Пораки: 22422
« Одговори #54 на: 31 Август 2011, 14:19:24 pm »
Enter 5.0 Coyote engine + superchargers..
A 5.0-liter Mustang with a Vortech supercharger is iconic: Inside Line takes the 2011 version of the 5.0 to the track and runs the numbers....headphones recommended.
2011 MUSTANG 5.0 7 PSI ,3.73 GEARS,AUTO,10.69@129.17 3/30/2011
« Последно менување: 31 Август 2011, 14:22:32 pm Stratro »
  • Пораки: 22422
« Одговори #55 на: 02 Септември 2011, 09:31:41 am »
Ford GT 1000 Twin Turbo tuned by Hennessey.
« Последно менување: 02 Септември 2011, 10:38:31 am Stratro »
  • Пораки: 22422
« Одговори #56 на: 02 Септември 2011, 12:57:38 pm »
FASTEST STREET CAR IN THE WORLD.
Larry Larson proves his car once again to be the fastest street car in the world by completing Hot Rod Magazin'es Drag Week 2010 AND making the first 6 second pass in Drag Week history! Not only did he make a 6 second pass, but he made that pass after driving 1200 miles on country roads, rain, and he did it 20 minutes after a 7.005 pass, hot lapping the car!
  • Пораки: 22422
« Одговори #57 на: 05 Септември 2011, 11:16:33 am »
Bugatti what?
PPR Ford GT World's Fastest Production Car in the Standing Mile at the Top Gun Run Event driven, Built, and owned by Johnny Bohmer of Performance Power Racing in West Palm Beach, Florida
« Последно менување: 05 Септември 2011, 11:24:19 am Stratro »
  • Пораки: 34562
« Одговори #58 на: 05 Септември 2011, 11:21:10 am »
What Bugatti?
Inace ova Street legal li e?
  • Пораки: 22422
« Одговори #59 на: 05 Септември 2011, 11:26:59 am »
What Bugatti?
Not a valid youtube URL
www.performancepoweronline.com
« Последно менување: 05 Септември 2011, 11:29:20 am Stratro »
