Автор Тема: SET (SUB WOOFER,AMPLIFIRE,SET CABLES,INSTALATION) PROMOCIJA  (Прочитано 3231 пати)
Отсутен DOG SECURITY
  • Пораки: 530
  • CAR AUDIO SPECIALISTS
    • www.dogsecurity.mk
« на: 14 Февруари 2011, 15:26:10 pm »
!!! CENA : 12.190 DEN !!!
Vo cenata e vklucena i profesionalna montaza i 12 meseci garancija
Vo cenata  e veke vklucen klubskiot popust od 10 %
CABLES :
6m power cable (10 mm2)
Power cord - 1.5m weight (10 mm2)
1x Signal cable 5 m double shield
Remote cable 5 m
The holder fuse with a fuse
Connectors
SUB WOOFER :
Principle / DIN-Diameter:     Passive 300 mm / 12 "subwoofer enclosure
RMS:     250 Watts
Maximum load:     800 watts
Impedance:     4 Ohms
Low-frequency limit:     25 Hz
Upper limit frequency:     250 Hz
Sound:     91 dB
Dimensions (WxHxD) mm:     430 x 390 x 355 / 265
Weight:     11 kg
AMPLIFIRE :
Max. power output * into 4 Ω     2x200 W / 1x600 W
RMS power output ** into 4 Ω     2x75 W / 1x220 W
Max. power output * into 2 Ω     2x 300 W
RMS power output ** into 2 Ω     2x 110 W
Frequency response     5 Hz? 50 kHz (-3 dB)
THD     <0.08% (1 kHz)
Signal-to-noise ratio     > 100 dB
Dimensions (W x L x D)     221 x 57 x 236 mm
Input impedance     20 kOhms
Power impedance     12 V minus an Masse
Weight     2,15 kg
« Последно менување: 14 Февруари 2011, 16:12:44 pm DOG SECURITY »
www.dogsecurity.mk
Ул.Борис Трајковски бр.132
02/2461-110
070/380-242
078/402-204
www.facebook.com/dogs.mk
contact@dogsecurity.mk
