Автор Тема: PARKSIDE PERFORMANCE 20V Убодна пила  (Прочитано 884 пати)
Отсутен Drive-r
  • Пораки: 7477
  • FB Vlecna Suzba Niko-m
« на: 09 Март 2022, 00:36:19 am »
*Brushless motor (brushless motor) - particularly long service life due to less wear
*Faster sawing progress thanks to 3-stage adjustable pendulum stroke
*Pendulum-free fine-cut adjustment
7-stage adjustable number of strokes: 1 x automatic + 6 selectable stages
*5 selectable cutting angles
*Integrated LED work light with 2 extended functions: 1. Light up before machine start / 2. Afterglow
*SAW LOCK quick-release chuck for easy saw blade changing
*Chip-free cutting line thanks to blower function
*Connection for external dust extraction - incl. adapter
*Folding and detachable, transparent saw protection
*Protection against splintering and line guide adapter
*Ergonomic soft grip equipment
*Surface-protecting sliding shoe attachment made of plastic
*Incl. 3 high-quality saw blades
Includes carrying case
Compatible with all devices in the PARKSIDE X 20 V Team series
Delivery without battery and charger
Included accessories: 2 wood saw blades, 1 metal saw blade, 1 rip fence, 1 line guide adapter, 1 adapter for external dust extraction
Technical specifications
Stroke rate: 800–3800 rpm
Stroke length: 26mm
Pendulum stroke levels: 1-3 and fine cut setting 0
Cutting angle right/left: 0° / 22.5° / 45°
Max. cutting depth: 135 mm in wood / 20 mm in non-ferrous metal / steel (soft) 10 mm
material
Plastic, fiberglass, die-cast aluminum
Dimensions
approx. 25.6 x 7.7 x 19.5 cm
Weight
approx. 1.542 kg
Контакт
 071 334 736 или на вибер
Гаранција 5 години
Цена: 6.000 денари (без полнач и батерија)
Полнач и моќна 20 волти литиум-јонска батерија 2Аh 3000ден.
Сет пила, полнач и батерија 20v 2ah 8.000ден
Достава преку карго низ цела Македонија.
