Автор Тема: Formula 1 - Season 2012  (Прочитано 274379 пати)
  • Пораки: 18210
Одг: Formula 1 - Season 2012
« Одговори #900 на: 22 Јули 2012, 02:57:33 am »
Кога е стартот?
Отсутен ace-106
  • Пораки: 3468
Одг: Re: Formula 1 - Season 2012
« Одговори #901 на: 22 Јули 2012, 03:02:00 am »
14.00h
« Одговори #902 на: 22 Јули 2012, 13:11:57 pm »
Red Bull under investigation over engine maps
The Hockenheim stewards are investigating Red Bull after FIA technical delegate Jo Bauer reported that after examining the engine torque maps of the RB8s of Sebastian Vettel and Mark Webber after qualifying, “it became apparent that the maximum torque output of both engines is significantly less in the mid rpm range than previously seen for these engines at other events.
“In my opinion this is therefore in breach of Article 5.5.3 of the Technical regulations as the engines are able to deliver more torque at a given engine speed in the mid rpm range. Furthermore this new torque map will artificially alter the aerodynamic characteristics of both cars which is also in contravention of Technical Directive 036-11.”
Article 5.5.3 says that “The maximum accelerator pedal travel position must correspond to an engine torque demand equal to or greater than the maximum engine torque at the measured engine speed. The minimum accelerator pedal travel position must correspond to an engine torque demand equal to or lower than 0Nm.”
The FIA placed tighter restrictions on engine maps ahead of this season as part of a package of rule changes designed to eliminate the use of exhaust-blown diffusers. Bauer’s statement suggests the FIA may suspect Red Bull have found a way to circumvent the changes.
Отсутен mmm121
  • Пораки: 3799
« Одговори #903 на: 22 Јули 2012, 13:50:10 pm »
и како е времето ? врне ли
« Одговори #904 на: 22 Јули 2012, 14:00:54 pm »
Не, сега за сега...
Отсутен mmm121
  • Пораки: 3799
« Одговори #905 на: 22 Јули 2012, 14:03:28 pm »
Gledam :P
« Одговори #906 на: 22 Јули 2012, 14:05:10 pm »
Аман бре Маса
Кими ЦАР !
Alonso:
Донта вори :D
  • Пораки: 45244
« Одговори #907 на: 22 Јули 2012, 14:55:43 pm »
Ако овој Хамилтон го учука Алонсо поради глупост, ја лично ќе одам да  го најдам и да му акнам 2 бокса!
  • Пораки: 18210
« Одговори #908 на: 22 Јули 2012, 14:56:39 pm »
Малце глупо прашање, али што е тоа као батерија на on-board камерите?
  • Пораки: 45244
« Одговори #909 на: 22 Јули 2012, 14:58:01 pm »
Па колку им се полни батериите од КЕРС-от :) И дали го арчат.
Отсутен Dule_
  • Пораки: 3076
« Одговори #910 на: 22 Јули 2012, 15:04:15 pm »
Слично на нитро :)
  • Пораки: 18210
« Одговори #911 на: 22 Јули 2012, 15:36:36 pm »
8) 8) 8) 8)
Grande, grande!
  • Пораки: 45244
« Одговори #912 на: 22 Јули 2012, 15:46:18 pm »
Многу ми се свиѓа што почнаа изјавите да ги даваат пред публика, а не во прес рум. Се враќа духот од старите времиња на трките, публиката го сака ова!
Отсутен Dekio7
  • Пораки: 2601
« Одговори #913 на: 22 Јули 2012, 15:53:28 pm »
Ај добра душа да кажи во кратки црти најинтересното, ако не  го мрзи, дур да излезат торенти од трката, ме копка шо било ;D
  • Пораки: 18210
« Одговори #914 на: 22 Јули 2012, 16:10:36 pm »
На сред трка Хамилтон од 17то место ги чекаше Алонсо и Ветел за да ги успори, и донекаде му успеа тоа, со што Ветел ја изгуби втората позиција кон Батон, за во претпоследниот круг да си ја врати назад (сеуште неразрешено дали легално или нелегално, затоа што престигнувањето го изврши надвор од линиите на патеката) и да заврши втор. Алонсо прв, Ветел втор, Батон трет, Раиконен четврти... Понатаму не памтам.
