Автор Тема: KW DDC (Dynamic Damping Control) ECU coilover iSuspension  (Прочитано 3677 пати)
Отсутен Dzo
  • Пораки: 3030
  • GTI®
« на: 28 Септември 2012, 00:02:38 am »
KW DDC ECU coilover
The KW DDC (Dynamic Damping Control) coilover suspension with ECU (Electronic Control Unit) is among the first retrofit coilover suspension that combines height adjusted with electronic damper regulation. This possess motorists the opportunity to upgrade their vehicles with an adaptive damper control and the option to configure per KW DDC app individually. included in the package are a KW "inox-line" coilover suspension with high-quality stainless-steel strut, electronically controlled dampers, a high-performance control device, vehicle-specific wiring harness with KW DDC probe for control of the cockpit and a comprehensive installation manual for easy installation. The DDC coilover has three specific vehicle developed damper setups. This allows the driver to select a button from the sports-ground coordination, a very sporty and performance-oriented Sport + setup as well as the Comfort mode for Bad-way routes. The height adjustment of the KW coilover suspension also allows an individual lowering in the TÜV-tested adjustment.
И еве проверете тука за што се работи .. Секоја им чест KW
http://www.kwsuspension.de/de/kw_ddc.php
Присутен Deni
  • Пораки: 55357
Одг: KW DDC (Dynamic Damping Control) ECU coilover iSuspension
« Одговори #1 на: 28 Септември 2012, 00:23:18 am »
Незнам како пуштаат коли на технички без вакво.
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #2 на: 28 Септември 2012, 00:24:43 am »
И Tein го има одамна ;) EDFC мислам дека се вика кај нив.
Отсутен Rakun4e
  • Пораки: 9200
  • Аstra la vista baby !
« Одговори #3 на: 28 Септември 2012, 01:22:39 am »
How much ? :)
Отсутен Dzo
  • Пораки: 3030
  • GTI®
« Одговори #4 на: 28 Септември 2012, 01:29:17 am »
i guess pretty much
Отсутен Banzai
  • Blitzqueen
  • Пораки: 10000
« Одговори #5 на: 28 Септември 2012, 01:32:59 am »
EDFC на ТЕИН со некоја спортска варијанта на амортизери, не тркачки кошташе околу 1000-1200 евра мислам за Интеграта.
