Автор Тема: U.S. Muscle Cars  (Прочитано 596664 пати)
Отсутен Marko-bmw
  • Пораки: 227
Одг: U.S. Muscle Cars
« Одговори #330 на: 09 Јуни 2012, 20:59:56 pm »
let`t talk about sex :)
I hooked up my accelerator pedal in my car to my brake lights. I hit the gas, people behind me stop, and I'm gone :)
Z06 - Automatic
« Одговори #331 на: 12 Јуни 2012, 21:43:10 pm »
2007 Z06 - Automatic Deposit
An unlikely trans swap yields a one-of-a-kind z06.
From the June, 2012 issue of Vette
By Christopher R. Phillip
Photography by Kevin DiOssi
It's not unusual for Corvette owners to describe their cars in tongue-in-cheek fashion as their "personal savings accounts," but in VETTE's quest to bring you some of the most unique Corvettes in the world today, we've tracked down one owner who signed his late-model Z06 up for an automatic deposit, literally.
"Corvette hobbyists know that the 21st century Z06 doesn't come with an automatic transmission, and the option isn't offered from the factory," Thomas Heinrichs, a financial advisor in Tampa, Florida, says. "Though rare, there are Corvette hobbyists like me who don't drive stick shift, yet want to spend every day behind the wheel of a Z."
01 As below, so above: Sic...
     read full caption
Heinrichs purchased his '07 Velocity Yellow Z06 from a dealer in Tampa, and describes it as "slightly used with 20,000 miles on its odometer." It was his fourth Corvette. Since he felt uncomfortable with the manual shift, he sat in the passenger seat and let the salesman testdrive it for him. He didn't even drive it off the dealer lot after signing the sales contract; instead, he had it trailered to performance-transmission specialists RPM Transmissions in Anderson, Indiana. RPM's automatic conversion is primarily requested by Corvette owners who have physical disabilities and can no longer use the manual stick, clutch pedal, or both. "It was a rare request to pull the manual trans out of the Z06 and do a full 6L80-E conversion on it for a person without a disability," RPM sales tech TJ Strange says. "It's one of only six that we've performed on the current-generation Z."
To begin the transmission transformation, RPM's techs extracted the Z's manual-shift-specific components--not just the T56 trans, clutch, flywheel, bellhousing, and shifter assembly, but the brake-pedal assembly and steering wheel, too. Then, using only brand-new GM parts, they installed all of the driveline components specific to the automatic C6, including Tap Shift. To make it work, RPM added wiring to the main harness to integrate it to the OE rear wiring harness, then custom programmed the Corvette's ECM to control the auto trans.
02 Big brakes and big bucks:...
     read full caption
03 Inside, high-end touches...
     read full caption
04 Transplanted 6L80-E auto...
     read full caption
"The conversion package delivers the full factory functionality of an automatic-trans C6, while retaining the Z06's differential cooler and track package, including the 3.42:1 rear-gear ratio for performance purposes," Strange says. "A stock Z with a good driver versus a Z with our automatic conversion is almost identical in quarter-mile performance, with the advantage going slightly to the automatic for consistency."
The 6L80-E conversion takes approximately three weeks. That gave RPM's techs enough time to bolt a Lingenfelter Performance Engineering (LPE) cold-air intake, mass-airflow sensor, and 90mm throttle body onto the Z's LS7. Before they shipped the Z back to Heinrichs, they also documented its power on the dyno--452 hp and 437 lb-ft at the rear wheels.
Heinrichs says his Z was delivered to him in May 2010, but he wouldn't let it sit in his driveway for long. "From the day I bought my Corvette, I always knew the automatic-trans conversion was just the start of the mods I'd do for it," he says. "I already had a Brembo Big Brake Kit, HRE P40 wheels, and Caravaggio Daytona race seats on order."
He called upon Chris Chapas at C2 Design in Tampa (who had previously worked on his '06 Vette) for the next chapters in this Z's mod odyssey. "I wanted more power out of the car," Heinrichs says.
Shortly thereafter, Tampa-based Corvette tuner Jeremy Formato suggested and installed a head, cam, and intake package--Livernois Motorsports LS7 Ported Stage 2 heads, a custom-grind Comp hydraulic-roller bumpstick, and a ported LS7 intake. C2 Design then added Dynatech headers, a custom 3-inch exhaust, and CES mufflers for even more power gains, along with a Katech carbon-fiber chin spoiler and rocker panel side skirts, and a Breathless Performance C6 GT2 Rear 2 Tip Diffuser to customize the Z's exterior.
To add some tasteful upgrades to the Z's cabin, C2 Design installed LPE gauge faces, a Sic Motorsports carbon-fiber headliner, Apsis USA carbon trim components and a Sport Deluxe steering wheel, and Caravaggio stitched leather for the center armrest and trans tunnel.
Likewise, C2 installed a factory ZR1 rear spoiler and a Halltech Systems GT2 hood (both painted body color, with clearcoat applied to the hood's carbon-fiber center), and carbon side mirrors.
In November 2011, Heinrichs had his Vette dyno'd again. He knew it was making more power, but he was "extremely pleased" when the car's output registered 583 hp and 567 lb-ft on the rollers.
Since then, he's only taken it on the track once--at Sebring International Raceway, where his heroes at Corvette Racing have earned multiple wins since 2002. (Despite his instructor's estimated lap time of 2 minutes, 27 seconds for the auto-shifted Z, Heinrichs made it around the circuit in an impressive 2:22.)
Heinrichs also enjoys showing off his one-of-none Z, and he has driven home with numerous car show best-in-class awards, including two from Florida's famed Festival of Speed. "People freak out when they see it at shows--not all of that is necessarily good," he says. "Some folks their scratch their heads and ask, ‘Why in the world did you put an automatic in a Z06?' Others take a cursory glance at it and think I installed Z components onto a base Corvette.
"I wouldn't trade my automatic-shifting Z for anything in the world," Heinrichs concludes. "It makes logging 2,000 miles a month driving for work fatigue free. Every time I drive it, it puts a big smile on my face--automatically, of course."
http://www.vetteweb.com/features/vemp_1207_2007_z06_automatic_deposit/index.html
Shelby GT500 vs Camaro ZL1
« Одговори #332 на: 13 Јуни 2012, 14:44:56 pm »
  • Пораки: 22393
« Одговори #333 на: 13 Јуни 2012, 14:50:19 pm »
ZL 1 podobar vo krivini, Shelby GT 500 vo se drugo.
  • Пораки: 22393
« Одговори #334 на: 18 Јуни 2012, 12:20:13 pm »
  • Пораки: 11178
« Одговори #335 на: 18 Јуни 2012, 12:51:07 pm »
Туу како би го ставил ова во некој стрип да му се изнавози некој суперхерој. Мислам дека и на Бетмен ќе му легне.
Присутен MartinAlfista
  • Пораки: 18202
« Одговори #336 на: 18 Јуни 2012, 12:58:25 pm »
@LP сакал АУТОМАТИК за да може секој ден да ја вози Корветата...
DAFUQ is wrong with these americans?!
Што праиме ние со мануелни не ми е јасно... Викендашки ги возиме колите?
  • Пораки: 22393
« Одговори #337 на: 18 Јуни 2012, 13:43:08 pm »
« Одговори #338 на: 18 Јуни 2012, 14:11:36 pm »
sekoj den po saat ipol da vozis na rabota po gust soobrakaj ke svatis sto znaci da vozis stick. Automatikot e izmislena rabota za niz grad. Nekoj den ke povozis automatik, ke ja svatis negovata ubavina.
  • Пораки: 18202
« Одговори #339 на: 18 Јуни 2012, 14:16:47 pm »
Би сакал. Повеќе би сакал да имам целосна контрола над колата, но сакам да ја видам и другата перспектива.
Иако, да бидеме искрени, на sporty oriented кола онаков класичен идиотски автоматик едноставно не личи.
  • Пораки: 22393
« Одговори #340 на: 18 Јуни 2012, 14:24:38 pm »
Moze i vaka..
Отсутен Pal Zileri
  • Сијка Пиштолова
  • Пораки: 2464
« Одговори #341 на: 18 Јуни 2012, 16:38:23 pm »
Уште една победа на Корветата на Ле Ман само овој пат во класата на приватни тимови или GTE Ам Category
www.domitalia.mk
  • Пораки: 11178
« Одговори #342 на: 19 Јуни 2012, 08:54:35 am »
  • Пораки: 16807
« Одговори #343 на: 19 Јуни 2012, 13:27:40 pm »
А ова второво што е јапанско што правиме? ;D
  • Пораки: 22393
« Одговори #344 на: 19 Јуни 2012, 15:05:20 pm »
Japonsko wannabe Camaro.
Ne e problem. Primame i vakvi preobrateni, koi smenile vera. ;D
We took a suitably powerful standard Honda S2000 and dropped in a 5.7 Litre Chevrolette Corvette engine just to spice things up a little. The results are truly awesome and a credit to our teams level of ability. This is Luke's day to day run about and truly is a wolf in sheeps clothing to say the least.
