Автор Тема: PARKSIDE PERFORMANCE Laser хоризонтала, вертикала и 360*  (Прочитано 1244 пати)
Отсутен Drive-r
  • Пораки: 7477
  • FB Vlecna Suzba Niko-m
PARKSIDE® PERFORMANCE cordless cross line laser »PKLLP 360 B2«, 4 V, 360 degrees
properties
360° rotating laser with horizontal all-round projection and vertically crossing laser line
Precise, simultaneous marking on all room walls
For the exact placement of wall shelves, wall lights, tiles, strips or pictures
Green laser light with better visibility even in bright areas (4x higher light output than comparable devices with red laser)
Versatile in use thanks to 2 projection modes
Self-leveling plumb alignment with LED status indicator
Freely adjustable angles with a fixed laser pendulum
Automatic flashing when self-leveling with exceeded initial slope (±3°)
Compact housing with 6.35 mm tripod socket (¼") and charging connection (incl. 1.5 m USB-C charging cable)
Tripod with extendable center column via crank and extendable legs (max. height 1.5 m)
Adjustable swivel head and integrated bubble level
Strong magnets on the back of the case for easy attachment to metal surfaces
Accessories included: tripod, charging cable with USB-C connector (1.5 m)
Specifications
Integrated battery: Li-ion 4 V (2.6 Ah)
Accuracy: ±0.4mm/m
Working range: up to 20 m
Projection modes: self-leveling / pendulum fixation
Leveling time: approx. 4 s
Self-leveling range: ±3°
material
plastic, fiberglass
Контакт
 071 334 736 или на вибер
Цена: 6000ден
« Последно менување: 09 Март 2022, 00:09:43 am Drive-r »
