Автор Тема: Mazda 323f 1.5i 16v 1996  (Прочитано 68188 пати)
Отсутен Start Up Mac
  • Пораки: 1518
« на: 07 Октомври 2013, 18:36:33 pm »
E taka denes se podnoviv so edno zverce sto stvarno me iznenadi .. se raboti za mazda 323f
Apdejt na specifikaciite okolu autovo poso nemav staveno eve sea tuka pise sve :
Brand   Mazda
Model   323
Generation   323 F V (BA)
Engine   1.5 i 16V (88 Hp)
Doors   5
Power   88 hp
Maximum speed   175 km/h
Acceleration from standstill to 100 km/h   12 sec
Fuel tank volume   55 l
Year of putting into production   1994 year
Year of stopping production   1998 year
Coupe type   Hatchback
Seats   5
Length   4245 mm.
Width   1695 mm.
Height   1355 mm.
Wheelbase   2605 mm.
Front track   1460 mm.
Rear (Back) track   1460 mm.
Minimum volume of Luggage (trunk)   346 l
Model Engine   Z5
Position of engine   Front, transversely
Volume of engine   1489 cm3
Max power in   6500 rpm.
Torque   132/4000 Nm
Fuel System   Multi-point injection
Valvetrain   DOHC
Position of cylinders   Inline
Number of cylinders   4
Diameter of cylinders (bore)   75.3 mm.
Stroke in the cylinder   83.6 mm.
Compression ratio   9.4
Number of valves per cylinder   4
Fuel Type   Petrol (Gasoline) A-95
Wheel Drive   Front
Number of Gear (automatic Gearbox)   -
Number of Gear (mechanical Gearbox)   5
Front suspension   McPherson
Rear suspension   The depreciated rack
Front brakes   Ventilated discs
Rear brakes   Drum
Steering type   Steering rack
Power steering   Hydraulic Steering
Fuel consumption (economy) - urban   9 l/100 km.
Fuel consumption (economy) - extra urban   5.5 l/100 km.
Fuel consumption (economy) - combined   7.2 l/100 km.
Weight   1115 kg.
Max weight   1580 kg.
Tire size   175/70 R13 T
Wheel rims size   13/14
koliceto e zmiiice u krivini u pravini lepi za asvalt ne mrda
vozi 1.5i 16v 90hp motor dohc
ima dosta od oprema
alarm,centralna brava,el.siber krov,el prozorci ,podesiv volan,podesivi farovi,podesivi sedista po visina dlabina,abs,srs,servo volan so napraven servis pred 3000km zapisano od mazda .. taka da sve na sve vredi kolicevo
i normalno ko so vika smicka treba da mu se zabae malce na branicinjata sitnici da se sredat
sedistata mu se koska kao od salon no nemoze da se vidat na sl poso imaat navlaki a navlakite se lajno :D
 eve slikicki :)
voopsto ne e pipano samo isprana e i treba da se fatam za rabota poleka poleka da se dotera :D
« Последно менување: 18 Ноември 2013, 01:15:12 am Start Up Mac »
Отсутен DasAuto.
  • Пораки: 4595
  • ~ Full of soul ~
Одг: Mazda 323f 1.5i 16v 1996
« Одговори #1 на: 07 Октомври 2013, 18:55:08 pm »
Одлична количка Мац ! создравје да се вози :)
↯↯ Don't try to follow me ↯↯
« Одговори #2 на: 07 Октомври 2013, 18:57:58 pm »
Odlicna kolicka mac. Dali prethodniot gazda e Zoran od Butel me zanima. On imase slicna i mislam ovaa e. Ako e taa si zemal NAJDOBRO ODRZAVANA KOLA.
Присутен Boshe
  • Пораки: 5503
  • Пиши лаже
« Одговори #3 на: 07 Октомври 2013, 19:04:13 pm »
Убаво Маздиче, со здравје да си го возиш!
  • Пораки: 1518
« Одговори #4 на: 07 Октомври 2013, 19:11:00 pm »
bugar- Ne ne od centar bese covekot inace uvezena od germanija tamu od prv gaza pa tuka ja zel ovoj i ja se pagam 3gazda
fala momci poubavo da si zemete :D
Отсутен dame
  • Пораки: 3237
« Одговори #5 на: 07 Октомври 2013, 19:17:29 pm »
ajde dosta se falis vikaj na castenka
Отсутен Боби Л.
  • Пораки: 1273
« Одговори #6 на: 07 Октомври 2013, 19:23:05 pm »
Создравје да се вози :D
  • Пораки: 8435
« Одговори #7 на: 07 Октомври 2013, 19:27:10 pm »
Со здравје да се вози. Сега бапни  плинче и господ(Дени) да те види.
Во иднина можеш и бандаши да смениш. Според мој вкус овие не и стојат.
Отсутен Rakun4e
  • Пораки: 9200
  • Аstra la vista baby !
« Одговори #8 на: 07 Октомври 2013, 19:28:54 pm »
Ебати французот !  :D
Со здравје да се вози и дотерува ;)
Отсутен Nino-
  • Пораки: 459
  • Ultimate driving experience
« Одговори #9 на: 07 Октомври 2013, 19:49:26 pm »
Со убаво да се вози и многу безгрижни километри :)
« Одговори #10 на: 07 Октомври 2013, 20:38:38 pm »
добро дојде во japan family ;D
Отсутен Prof. Greenthumb
  • Пораки: 4116
  • MadaFunker
« Одговори #11 на: 07 Октомври 2013, 20:55:58 pm »
Супер количе, со здравје да се вози!
Со потрошња како оди?
New blood of old school
  • Пораки: 30862
« Одговори #12 на: 07 Октомври 2013, 21:04:53 pm »
Со среќа!
Искорни ги навлаките, под хитно.
Отсутен Rakun4e
  • Пораки: 9200
« Одговори #13 на: 07 Октомври 2013, 21:24:23 pm »
Зеро оваа да не е твојата даска за пеглање ?  :D
Отсутен DARK MK1 GTI
  • Пораки: 5087
« Одговори #14 на: 07 Октомври 2013, 21:42:05 pm »
Mi se dopagja ! :)
Za pocetok, menjanje na bandasce , i dobo izduvce, a ponataka i spustanje :)
