Автор Тема: ГМО  (Прочитано 538087 пати)
Отсутен Van
  • Пораки: 5405
  • VW Golf MK3 1.9 TDI
Одг: ГМО
« Одговори #405 на: 23 Март 2014, 16:53:41 pm »
Колку што знам јас, во Македонија нема никакви законски регулации за ГМО.
Што се однесува до македонските закони, ГМО не постои. Соодветно на тоа, во РМ немаме означување на присутност од ГМО во производите.
Одг: ГМО
« Одговори #406 на: 23 Март 2014, 17:16:06 pm »
The policy left gaping communication gaps between agencies, plenty of regulatory ground uncovered, and confusion over who would regulate what.[8,9] But most importantly, the regulations were founded on the false premise that bioengineered organisms used for food and agricultural products are no different from non-engineered, conventional products.10 In fact, to produce genetically engineered foods, researchers take genes from food or non-food organisms and add them to another organism to alter its genetic makeup in ways not possible through sexual reproduction. The process deletes essential proteins or adds entirely new ones, and can modify genetic characteristics in entirely unexpected ways. As long as the new genes come from an approved food source, the government treats new or altered genes in bioengineered foods as natural, not novel, additives. So in most cases regulators are not required to take a precautionary approach when evaluating new genetically engineered food products; products are considered safe until proven otherwise.
As late as 1994, it appeared that the federal government was still playing catch-up in establishing working biotechnology safety regulations. The Union of Concerned Scientists (UCS), which monitors the biotechnology industry and the federal regulatory system, was pointing out big holes in the so-called framework." "Fundamentally, it does not contain sufficient statutory authority to oversee all of the products and activities entailed in genetic engineering," wrote UCS in February 1994. "Where authority does exist, there are problems with implementing regulations and policies." For example, a 1992 FDA policy exempted corporations from having to test bioengineered food for safety and get FDA approval before the foods are put on the market.'2 Unless the corporation determined that "sufficient safety questions exist",'3 corporations could undergo voluntary, private "consultations" with the agency before marketing their product.'4
Отсутен Vasil
  • Пораки: 3759
Одг: ГМО
« Одговори #407 на: 23 Март 2014, 17:29:06 pm »
^ US of A
Имаат многу поголеми проблеми во законите од ова.
Одг: ГМО
« Одговори #408 на: 23 Март 2014, 18:01:26 pm »
More than two decades ago, the U.S. Food and Drug Administration (FDA) granted GMOs “generally regarded as safe” status, meaning the industry had no obligation to conduct long-term safety studies. And while GMOs don’t have what scientists call “acute” effects, what about “chronic” effects — those that come on gradually and can’t easily be tied to one cause? The French study — the most comprehensive GMO safety assessment ever conducted — highlights that concern. It involved 200 rats and spanned two years, the life expectancy of the species of rat used. Previously, the longest study had lasted 240 days, says Michael Hansen, senior scientist at Consumers Union and an expert on GMO research. Industry-funded studies typically last just 90 days.
The researchers investigated how eating Monsanto’s Roundup-Ready corn (and any Roundup herbicide traces that may come with it) affected rats’ health. They separated rats into 10 groups: Three had part of their standard diet replaced at varying levels with Roundup-Ready corn that had been treated with Roundup in the field; three received the same feed protocol, but with untreated Roundup-Ready corn; three ate no GM corn but had tiny amounts of Roundup herbicide in their drinking water; and one control group ate two-thirds standard rat chow and one-third non-GM corn. Each group contained 10 females and 10 males.
The researchers say their results show “severe adverse health effects, including mammary tumors and kidney and liver damage, leading to premature death” from Roundup-Ready corn and Roundup herbicide, whether they were consumed separately or together. Almost all of the ill effects manifested after 90 days. By the end of the study, 50 to 80 percent of the females had developed large tumors, compared with 30 percent developing tumors in the control group. In males, liver congestion and necrosis were 2.5 to 5.5 times higher than in the control group, and there were 1.3 to 2.3 times more instances of kidney disease. Overall, among the rats receiving GM corn and/or Roundup, up to 50 percent of males and 70 percent of females died prematurely, compared with only 30 percent and 20 percent in the control group.
So does the study close the case? Are GMOs dangerous? Predictably, industry-aligned scientists are questioning the study, but even longtime critics of GMOs, including Hansen, have concerns. Hansen says that while the new study was longer and better designed than any of the industry GMO safety studies, the sample size — 10 males and 10 females per group — was too small to draw conclusions from.
Hansen says, however, that while the individual comparisons may not be statistically significant because of sample size, the results still paint a troubling picture. The study made 54 comparisons between treated rats and control rats, and in all but four, the treated rats showed worse outcomes. “That’s suggestive that there’s something going on and that there should be further research,” Hansen says, adding that a possible reason the researchers didn’t use a greater number of rats to get more robust results is because multiyear rat studies are extremely expensive.
That fact highlights how little funding goes to GMO safety studies. Between 1992 and 2002 — a period of rapid GM crop development — the USDA spent about $1.8 billion on biotech research, of which only 1 percent went to safety testing. Meanwhile, the ag industry uses its patent power to maintain tight control over who researches what, and it dominates the research agenda at U.S. agriculture universities. The French study didn’t fully illuminate the situation, but it’s a start.
— Tom Philpott, adapted from Mother Jones
http://www.motherearthnews.com/natural-health/gmo-safety-zmgz13amzsto.aspx?PageId=2#axzz2wnzllOUE
Отсутен Van
  • Пораки: 5405
Одг: ГМО
« Одговори #409 на: 23 Март 2014, 18:17:58 pm »
Погледнувам во мојата кристална топка и гледам голем немир кај про-Монсанто форумџиите!
Време е за бирократски примедби од видот на „10 групи од по 20 пацови не е доволна бројка за оваква студија (nevermind на туморите кај 90% од пацовите)„. ;D
Одг: ГМО
« Одговори #410 на: 23 Март 2014, 18:20:47 pm »
Убаво си пишува дека истражувањето не ја отсликува целосната ситуација, но е добар старт. Монсанто во своето 100 годишно постоење не се потрудил да направи вакво истржаување, или направил но не сакал да ги сподели резултатите, впрочем тоа право му е загарантирано со закон.
Отсутен Vasil
  • Пораки: 3759
Одг: ГМО
« Одговори #411 на: 23 Март 2014, 18:25:47 pm »
Кои се тие про-Монсанто форумџии?
"Overall, among the rats receiving GM corn and/or Roundup, up to 50 percent of males and 70 percent of females died prematurely, compared with only 30 percent and 20 percent in the control group."
За неупатените "control group" ги означува стаорците хранети со стандардна храна. И кај стаорците хранети со храна што не е ГМО се развиле тумори како на сликите на ЛП, затоа што тоа е врста на стаорци добиена со вкрстување која многу лесно развива тумори.
За да се донесе заклучок од разликата на процентите и дали ГМО храната што била тестирана го зголемува ризикот од развој на тумори, потребна е доволно голема бројка на експерименти за да се исклучат статистичките аномалии.
Одг: ГМО
« Одговори #412 на: 23 Март 2014, 18:30:13 pm »
Се убаво си пишува во текстот, или му објаснуваш на оние што не разбираат англиски? Кај ГМО хранетите глувци 2-3 пати повеќе тумор се развива. Каква е, таква, најдолга студија во светот е. Одличен почеток за и другите да почнат да прават студии.
Со црвено ти е подвлечено нешто многу поважно!
Отсутен Vasil
  • Пораки: 3759
Одг: ГМО
« Одговори #413 на: 23 Март 2014, 18:48:58 pm »
Дека на Американците не им го бива законот, мислам дека веќе заклучивме. Уште од почетокот на темава, од никого до сега не сум прочитал дека сака закони како тие што се на сила во САД.
Отсутен Van
  • Пораки: 5405
Одг: ГМО
« Одговори #414 на: 23 Март 2014, 19:03:00 pm »
Ако не се сакаат закони за ГМО како во САД, а воедно сепак сакате ГМО... тогаш имате проблем.
Скоро да не е можно да се купи ГМО прехрамбен производ кој не е произведен во САД.
Значи прашањето е, штом не се сакаат закони за ГМО како што се Американските, тогаш како може да се сакаат ГМО што се произведени според тие ИСТИТЕ ТИЕ закони и стандарди?
Отсутен Vasil
  • Пораки: 3759
Одг: ГМО
« Одговори #415 на: 23 Март 2014, 19:05:16 pm »
Каква врска има каде е произведен и какви се стандардите таму? За да се увезе и продава во ЕУ мора да ги исполнува европските стандарди. Се читаш ли што пишуваш?
Отсутен Van
  • Пораки: 5405
Одг: ГМО
« Одговори #416 на: 23 Март 2014, 19:14:54 pm »
Погледни се во огледало и прочитај си ја сам на себе последната реченица од сопствениот пост. И кажи искрено дека прашањето не ти е лицемерно.
Како можеш да кажеш дека, те цитирам: „на Американците не им го бива законот, мислам дека веќе заклучивме.„ и потоа да подржуваш ГМО производи произведени под истите закони и стандарди?
Отсутен Vasil
  • Пораки: 3759
Одг: ГМО
« Одговори #417 на: 23 Март 2014, 19:21:16 pm »
Тоа што јас за да се запишам на факултетот што сум го одбрал, ми бил потребен просек од 3.45 од средно, не мора да значи дека сум завршил со просек од 3.5. Можеби сум завршил со просек од 4.95 па сум можел да отидам некаде каде што стандардите се повисоки.
Отсутен Van
  • Пораки: 5405
Одг: ГМО
« Одговори #418 на: 23 Март 2014, 19:26:38 pm »
Аааа... Ти всушност си ГМО и планираш да ни легнеш на трпеза да те јадеме?
Одг: ГМО
« Одговори #419 на: 23 Март 2014, 19:29:03 pm »
Европа е Амерички роб, европските политичари се курвички без кичма. Ете пак војуваат за Америка, овојпат против Русија. Колку време ќе му треба на Монсанто (америчката влада) да ги смени законите во европските земји?
