Exide
133 (42%)
Black Horse
32 (10.1%)
Vesna
21 (6.6%)
Topla
61 (19.2%)
било кој...
70 (22.1%)
Вкупно гласови: 316
Автор Тема: Предлог за акумулатор  (Прочитано 616866 пати)
Отсутен Van
  • Пораки: 5223
  • VW Golf MK3 1.9 TDI
Одг: Предлог за акумулатор
« Одговори #2910 на: 20 Март 2021, 08:47:55 am »
Чиста глупост е тоа старт/стоп, демек загадување ќе намалувале.
Мерел некој дали прави некаква заштеда во потрошувачка на гориво?
  • Пораки: 43343
« Одговори #2911 на: 20 Март 2021, 08:55:25 am »
Мереле: https://www.edmunds.com/car-reviews/features/do-stop-start-systems-really-save-fuel.html
Our 328i GT used 3.1 gallons with the system off and 2.8 gallons with it on, a savings of 9.5 percent. That works out to 91 cents saved in 80 miles. Calculated fuel economy rose from 26.2 to 28.7 mpg.
The Jaguar did a little better, which makes sense when you're talking about a thirstier V8. It consumed 4.1 gallons with the system off and 3.6 with it on, a reduction of some 10.9 percent. At local prices that returned $1.47 to our pocket. Corresponding fuel economy increased from 19.7 to 22.1 mpg.
This, of course, begs the question of what would have happened if we had run the air-conditioning on a hot day. We saved that test for the Mini Cooper. We ran both loops with the automatic temperature control set to 74 degrees.
It used 2.7 gallons with A/C on and stop-start off, and that shrank slightly to 2.6 gallons with stop-start up and running. That works out to a modest fuel savings of 2.9 percent, with fuel economy climbing from 30.0 to 30.9 mpg. At this point we ran a third loop with the system engaged and the air-conditioning off and the savings shot up to 9.5 percent at 33.2 mpg.
Има потенцијал за до 10% заштеда, што не е малку, али кога имаш потрошувачи, односно кога ќе треба да се греее/лади кабината (у МК или грееш или ладиш кабина, нема измеѓу), тогаш веќе е минимална заштедата.
Присутен vladic3110
  • Пораки: 4921
« Одговори #2912 на: 20 Март 2021, 09:03:43 am »
Евентуално  10%, со другу зборој ветер со магла,  едно менвање акомулатор ти е 200 евра,  па ќе ослаби нема да работи,  кратки релации,  недоволно време да се наполни.. И да сакаш да го приполниш ти треба фенси полнач и тој кошта и така. Плус од пали гаси 70пати бо денот сигурно и нешто друго со тек на години ќе јави.
Отсутен Van
  • Пораки: 5223
« Одговори #2913 на: 20 Март 2021, 09:50:23 am »
Еве нова тема, да не досаѓаме овде :)
https://forum.carclub.mk/index.php/topic,24771.0.html
Отсутен Ѓорѓи
  • Пораки: 1318
« Одговори #2914 на: 25 Март 2021, 23:31:03 pm »
некако неверојатни ми се бројките особено дека прв пат слушам за брендот
https://www.facebook.com/yuasa.com.mk/photos/a.112106697629653/112106674296322/
https://www.facebook.com/yuasa.com.mk/photos/a.107568324750157/107568261416830
Отсутен M3V8
  • Пораки: 2582
« Одговори #2915 на: 26 Март 2021, 00:12:24 am »
Poveketo japanski koli doagaa  so ovoj brend akumulatori.
Made in japan? prosto neverovatno. Fabrickite traat 10+ godini.
Присутен Silvester
  • Пораки: 1721
« Одговори #2916 на: 27 Март 2021, 11:23:42 am »
Jas vakva marka akumulator imav fabricki na skuter, go smeniv posle 10 godini. No dosega nikade nemav videno da gi prodavaat kaj nas.
Отсутен Marv
  • Пораки: 22
« Одговори #2917 на: 27 Март 2021, 13:32:38 pm »
Ako se orginal top se, t.e. bar bea neznam za sega. Subaruto sto go imav kupeno 1996, smenet bese vo 2011 pred da go prodadam. Zimo leto nadvor, ni garaza videl nit punjac.
Sent from my SM-A505FN using Tapatalk
Отсутен MNikolovski
  • Пораки: 81
« Одговори #2918 на: 31 Март 2021, 17:43:34 pm »
Пред неколку дена сменет акумулатор кај дечките во 11ти Октомври, кај Новус, мислам дека @nidzzo им е претставник на форумов, а не сум сигурен како им се вика фирмата.
Од услугата сум ептен задоволен, позитивни луѓе, супер фини. Прво го проверија стариот акумулатор, па од кога се востанови дека нема ништо живот у него, ми дадоа понуди за 3-4 различни акумулатори (MonBat и Duracell). Бидејќи разликата во цена не беше голема, се одлучив за Duracell Advanced 74 Ah.
Уште на првото палење се осети разликата, имајќи предвид дека некоја будала претходно ставила 60Ah :) За сега нема никаков проблем, ама порелевантно е да пишам после некоја година.
Се на се, задоволен и имаат препорака од мене :)
Отсутен nidzzo
  • Пораки: 234
  • No.1 battery POWER DURACELL
    • www.akumulatori.com.mk
« Одговори #2919 на: 07 Април 2021, 11:27:06 am »
Здраво на сите, поради многу прашања во врска со конекции, паралелни и сериски, направивме една поучна слика да ги разјасниме дилемите и исто така отпочнавме со функционирање со програмата "УЧИМЕ СО ДУРАЦЕЛ" за да НАПРАВИМЕ ПОЈАСНУВАЊЕ НА ДИЛЕМИТЕ И МОЖНИТЕ ЗАБУНИ.
Убав снежен ден :)
DURACELL AUTOMOTIVE POWER
(02) 2783030
078 373414
Отсутен nidzzo
  • Пораки: 234
« Одговори #2920 на: 08 Април 2021, 09:29:12 am »
Денес ќе го објасниме процесот на палење на возило со кабли, тие што се искусни да си повторат лекција :)
download full size image from instagram
(02) 2783030
078 373414
Отсутен Ѓорѓи
  • Пораки: 1318
« Одговори #2921 на: 08 Април 2021, 15:17:33 pm »
глупо прашање: што може да се случи ако пример јас со 45ах помагам на некој мерцедес со 95ах да запали освен шо ќе треба повеќе време веројатно? ;D
Отсутен nidzzo
  • Пораки: 234
« Одговори #2922 на: 08 Април 2021, 15:48:02 pm »
@Ѓорѓи
Тоа ти е слично како да сакаш со Матиз да го шлепаш Мерцедесот, види...генерално ќе запали но има шанси поради големо повлекување на струја од страна на голем дизел мотор да и направи шок на 45ката и добие внатре краток спој.
(02) 2783030
078 373414
Отсутен nidzzo
  • Пораки: 234
« Одговори #2923 на: 09 Април 2021, 11:21:11 am »
Денес овој убав сончев ден ја отвораме темата на start/stop  акумулатори :)
(02) 2783030
078 373414
Отсутен Panda993
  • Пораки: 98
« Одговори #2924 на: 24 Април 2021, 22:54:53 pm »
Zdravo Drustvo.
Ke ve zamolam da mi preporacate polnac za akumulator.
Mi treba da go polnam motorot i nekogash kolata.
Ke ve zamolam da mi pomognete vo izborot i kade moze da se kupi tuka kaj nas dobar polnac😊
Fala odnapred
