Автор Тема: Pojasnuvanje za toa sto e Chip Tuning  (Прочитано 17052 пати)
Отсутен 2fast4you
  • Модератор
  • Пораки: 1797
« на: 16 Јули 2011, 00:16:52 am »
Chip tuning refers to changing or modifying an EPROM chip in a car's or other vehicle's electronic control unit (ECU) to achieve better performance, whether it be more power, cleaner emissions, or better fuel economy.
This was done with early engine computers in the 1980s and 1990s. Today, the term chip tuning can be misleading, as people will often use it to describe ECU tuning that does not involve swapping the chip. Modern ECUs can be tuned by simply upБлокирано their software through a standard interface, such as OBDII. This procedure is commonly referred to as engine or ECU tuning. ECUs are a relatively recent addition to the automobile, having first appeared in the late 1970s.
As technology advanced, so did the electronics that go into cars. The ECU in a modern automobile, together with advanced engine technology, makes it possible to control many aspects of the engine's operation, such as spark timing and fuel injection. The ECU may also control electronic throttle control (drive-by-wire), valve timing, boost control (in turbocharged engines), ABS, the automatic transmission, speed governor (if equipped), and the electronic stability control system.
Performance gains are realized by adjusting the ignition timing advance. Higher timing may result in higher performance. However, to cope with advanced timing, one must run high-octane gasoline to avoid pre-ignition detonation or pinging. Manufacturers design for a specific timing and this may limit performance accordingly.
In addition, changing fuel maps to coincide with the stoichiometric ratio for gasoline combustion may also realize performance increase. Most manufacturers tune for optimum emissions and fuel economy purposes which can limit performance.
Cars with a turbo fitted can have the requested and allowable boost levels raised, these applications usually have the most effect if the turbo fitted is a low pressure turbo which leaves the most room for improvement.
Another reason to change the ECU map is if there are engine, intake, or exhaust modifications to the car. These "bolt-on" modifications alter the way that the engine flows, often causing the air to fuel ratio to change. Without re-mapping the fuel tables, some of the performance gains from the modifications may not be realized.
A poorly tuned ECU can result in decreased performance, driveability, and may even cause engine damage.
The most common way to 'upgrade' the ECU is using either plug in modules as mentioned above or using a specialist tuner who will use an OBD Flash tool. These devices generally plug into the diagnostic port although in some cases the reprogramming is done directly on the circuit board. Maps are supplied by tuners.
An alternative to modifying the on-board chip is adding an external device, often known as a tuning box. The abilities of the external devices generally reflect on-board chip modifications, with the advantage that they can be easily removed to restore the vehicle to standard. Adding an external tuning box is generally only possible on modern engines with external management ports.The increased power will optimise your vehicle increasing your driving experience
« Последно менување: 16 Јули 2011, 00:29:59 am 2fast4you »
Отсутен 2fast4you
  • Модератор
  • Пораки: 1797
Одг: Pojasnuvanje za toa sto e Chip Tuning
« Одговори #1 на: 16 Јули 2011, 00:29:05 am »
    Your vehicle will be much more responsive to your right foot
    Flat spots will be ironed out
    The power will be delivered more smoothly making your town trip much easier with less gear changes
    Quicker acceleration making overtaking much safer
Mobile ECU remapping is done through the Diagnostic socket (OBD Port) of vehicles built around 1999 onwards, using this method there are no add on components or any visible trace of the ECU remapping work having being carried out on the vehicle, we use a laptop running specialist software that can read and make a copy of the original data on your vehicles ECU then we are able to write new data to the EPROM chip inside the vehicles ECU. Stored on this chip are data maps (hence the name ECU remapping) that are used to send the engine instructions such as fuelling, ignition timing and boost amongst others. When we carry out ECU remapping we are reprogramming these maps to optimize the engines performance , torque and MPG
